Thu, Dec 19, 11:16 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 19 10:29 pm)
Subject: walk designer or manual
Artchitect ( ) posted Tue, 16 August 2011 at 12:03 AM ยท edited Wed, 11 December 2024 at 1:37 PM
i do wonder which one is seen as most beneficial for making figures walk.
rokket ( ) posted Tue, 16 August 2011 at 12:32 AM
Quote - i do wonder which one is seen as most beneficial for making figures walk.
Ummmm, both. I usually tweak the walk designer, then when I have something usable, I go into the animation layers and tweak it further.
To me, doing it manually can take HOURS, and I don't really want to spend that time. But, to qualify that, I have done it manually, and the results are usually not as good as what I could do if I spend a fraction of that time doing the above process.
wolf359 ( ) posted Tue, 16 August 2011 at 10:34 AM
Agreed use the WD to quickly get the figure from point A to point B
then go and Make global Changes/ adjustments using your graph editor.
Cheers
My website
Artchitect ( ) posted Fri, 02 September 2011 at 3:43 PM
ok thanx
jaguarmma ( ) posted Sat, 03 September 2011 at 11:00 PM
I ended up doing it by manual. I got a high heel effect with walk designer. Be sure to check out all of the camera angles to make sure your model is walking normal.
