Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
Quote - i do wonder which one is seen as most beneficial for making figures walk.
Ummmm, both. I usually tweak the walk designer, then when I have something usable, I go into the animation layers and tweak it further.
To me, doing it manually can take HOURS, and I don't really want to spend that time. But, to qualify that, I have done it manually, and the results are usually not as good as what I could do if I spend a fraction of that time doing the above process.
Agreed use the WD to quickly get the figure from point A to point B
then go and Make global Changes/ adjustments using your graph editor.
Cheers
