Wed, Jan 22, 10:26 PM CST
Subject: How to create a dynamic sheet
ElZagna ( ) posted Sat, 03 September 2011 at 10:25 AM · edited Tue, 21 January 2025 at 6:49 AM
I would think this would be easy, but I can't figure it out. I want to create my own dynamic sheet, blanket, towel, etc. that I can place above a reclining figure and let it fall and gracefully conform to the figure. How do I do that?
OS: Windows 10 64-bit, Poser: 10
ErickL88 ( ) posted Sat, 03 September 2011 at 11:02 AM · edited Sat, 03 September 2011 at 11:03 AM
Attached Link: http://my.smithmicro.com/tutorials/1420.html
I found this to be a nice practice (attached link)
Tho, it be much easier to just let the high res square (used as a sheet/towel) fall down on a figure, for the start.
You can positon the figure in frame 1 already, and just let the high res square fall on it for a few frames (like 20, with an additional 10, but no more movements on the figure anymore, to just let it all settle a bit more)
shuy ( ) posted Sat, 03 September 2011 at 11:03 AM
You described everything what you should to do.
"Cloth plane" is good to start. Load it from library, place above reclining figure, go to clothing room, clothify "cloth plane", select collide against "body" and press calculate simulation.
