Sat, Jan 11, 9:17 AM CST
Subject: Help With Poser Docutment Window Size
shorterbus ( ) posted Thu, 15 September 2011 at 3:33 PM · edited Fri, 03 January 2025 at 9:19 AM
Poser 8, Windows 7.
Somehow I managed to change the size of my docked document window and now it runs of the right edge of the monitor and I can't change it back. I can undock it, adjust the size, but then when I dock it goes off the screen again. Help me, Obiwan!
vilters ( ) posted Thu, 15 September 2011 at 5:16 PM
Start Poser
Goto  Edit
Goto General Preferences
Goto Interface
Select Launch to factory state
Save
Close Poser
Restart Poser
Your Interface should be at factory state again.
JunkoH ( ) posted Thu, 15 September 2011 at 5:25 PM
you just need to check "floating" on document window.  that way it won't dock and will stay the size you set it for
shorterbus ( ) posted Thu, 15 September 2011 at 5:29 PM
Vilters, thanks for the suggestion, it makes sense, and it was one of the fifty or so things I tried before coming to the forums. Unfortunately, it didn't work.
May if I approach the question from a different angle - how do I set the size of a docked window?
millighost ( ) posted Thu, 15 September 2011 at 5:36 PM
After you remove the file:
c:/users/millighost/Application Data/Poser/8.0/English/Poser UI Prefs_1280x1024.xml
(username and screensize can vary) the settings are reset after a restart of poser. If you feel experimental, you can also poke around in that file, the window geometries are somewhere in it.
seachnasaigh ( ) posted Thu, 15 September 2011 at 10:19 PM
> Quote - May if I approach the question from a different angle - how do I set the size of a docked window?
Look for the icon (which looks like a barber pole, or maybe it's a piece of braided rope, or a screw jack) along the border of the window.  Click on it and drag it leftward.
shorterbus ( ) posted Fri, 16 September 2011 at 8:46 AM
Sorry, got called away for work. I'm off to try thee suggestions. THanks!
