Fri, Nov 22, 12:39 PM CST
Subject: let's go to BENCHMARK Poser 7 all of us !
  • 1
  • 2
usamike ( ) posted Tue, 15 April 2008 at 5:17 AM
Note also, the Cloth Room is single threaded no matter what, so having multiple cores won't benefit you there.
that's why i'm proud of my old architecture and  high natural frequency cpu Pentium D960@3.6GHZ !
Because there is many many tasks to do on a desktop computer that are not multi-core/thread yet !
magoo ( ) posted Tue, 15 April 2008 at 8:12 AM
LOL, I get this graph that automagically shows up in the preview window when I turn on the SLI visual indicators. It's shows how much of the load is being split up to the cards, and the green line will move up and down depending on the load. But you do have to change one setting, to get it to show. Bottom line poser is using SLI, and for me it's faster. SLI is driver and opengl driven.
softcris there was a new bios released at the end of March for the 780i, and new mother board
drivers are due out soon, if not already. Check you bios version on post, then go to the XFX site
and see what the latest is, and look for the MB drivers.
8-)
softcris ( ) posted Tue, 15 April 2008 at 1:49 PM
hello there!
yesterday when I posted here was already over mid night here...got out early  to work so....
yes, guys; I have being since 6 PM till mid night w/ the technician installing the '780i' XFX in the machine.
Poser 7 sp 2. Sli enable.
All good but not higher speed.
Thanks for the support. I continue this in Hardware post under: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2735431&page=2#message_3210408
"'you shut up!  or I'll bring democracy to your country! "
Cris Galvão aka Softcris  - www.crisgalvao.com
(or softcris, SoftCris)
Rendering since 1997 and
at Renderosity since 1999.
OS Win 8.1     64 bit
flaviok ( ) posted Mon, 14 July 2008 at 7:37 AM · edited Mon, 14 July 2008 at 7:40 AM
1"30scs
thread 4 ( separate process)
AMD ATHLOM 64 X2 6.600
4 GB RAM DUAL 800
VISTA 64
ATI RADEON HD 2600
usamike ( ) posted Mon, 09 March 2009 at 4:19 AM
shall somebody with a core i7 CPU make the test please ?
12rounds ( ) posted Mon, 09 March 2009 at 11:03 AM
Processor: i7 920 2,6Ghz (quad core)
Motherboard: P6T Deluxe
OS: Ubuntu Linux 64-bit
Best time: 75 seconds (4 threads)
I agree with the criticism about the benchmark; most of the time goes to non-threaded activities such as loading textures and rendering shadow maps and such.
12rounds ( ) posted Mon, 09 March 2009 at 1:59 PM · edited Mon, 09 March 2009 at 2:02 PM
I  improved the above figure of 75 seconds to 66 seconds by two simple tricks.
I first observed that Poser wants to write every texture it reads before it switches to the rendering engine into it's "PoserTextureCache" folder. In this case the amount of data written is around 1,1Gb (Poser writes ALL the texture data to .exr file format probably because FireFly wants it that way). Poser also behaves very stupidly in this ... if it encounters multiple instances of the same texture file (like in this case "KateShoes" and "KateShirt" etc, it just writes the file again ... and again... and again. That's why you may see some texture files disappear quickly from the "Loading textures" phase and some seem to stay there forever.
Okay. Writing 1,1Gb creates a small amount of i/o traffic. Not enough to choke i/o operations (at least on my system) since the actual process that writes the files is a single thread and even if the disks and busses could take more load, Poser just isn't pushing them to the limit. Nevertheless taking that into notice, I shaved a few seconds by pointing the texture cache to a RAM disk (actually a "tmpfs" filesystem in Linux, but I suppose it's a RAM disk in Windows). That pretty much eliminates any i/o overhead caused by writing the said 1,1Gb.
Next in the general preferences tab the default values for "Memory limit buffer" and "Adaption threshold" are not optimised for my system (I did a fresh P7 install just for this benchmark since I had already deleted most of the needed resources required by the pz3). So I went to the upper limit and put 2047 as the "Memory limit buffer" and "0" as the adaption threshold. With these two things ... over 10% total speed increase.
Normally I wouldn't want to use RAM as the renderer's texture cache because of the obscene file sizes of .exr images.
stewer ( ) posted Mon, 09 March 2009 at 2:20 PM
Quote - Poser also behaves very stupidly in this ... if it encounters multiple instances of the same texture file (like in this case "KateShoes" and "KateShirt" etc, it just writes the file again ... and again... and again.
Are those files dated in the future by any chance?
For managing the texture cache, Poser checks the file dates of the source textures and compares them to the files dates mip maps in the cache. This way it can react appropriately when files get changed in Photoshop between renders.
12rounds ( ) posted Mon, 09 March 2009 at 3:07 PM
Quote - > Quote - Poser also behaves very stupidly in this ... if it encounters multiple instances of the same texture file (like in this case "KateShoes" and "KateShirt" etc, it just writes the file again ... and again... and again.
That's very interesting.
The original files (Kate resource files) referenced by the pz3 are dated 13 of Nov. 2006 on my system so I can't see why that would be happening. Cause for further investigation as it really slows down this benchmark for me (clicking open some of my own pz3 files doesn't make this happen so it's an anomaly and not a norm).
usamike ( ) posted Mon, 09 March 2009 at 5:25 PM
thanks for all your remarks
i knonw that benchmark is not a reference, but it's the one ! And somewhere, it provides any idead of gain by CPU to another; at least a minimal expected performance if nobody did tweak his hardware before the test !
You know i own a pentium D960, i will purchase a core i7 (maybe i7 940 or 950). So by reading thi all your score, i guess i will gain x4.5 speed at leastn wheras in cinebench i will gain only x3, and in Blender x5 (http://www.eofw.org/bench/)
In my drawer, i have a compactflash-to-SATA adaptator and a 266x compact flash card. I forecast to build a speed SSD with this (for only 100€) to use for a system cache partition (where poser will be)
thanks again for all !
ghonma ( ) posted Mon, 09 March 2009 at 9:40 PM
Quote - In my drawer, i have a compactflash-to-SATA adaptator and a 266x compact flash card. I forecast to build a speed SSD with this (for only 100€) to use for a system cache partition (where poser will be)
Flash cards are actually much slower then modern hard disks. Any recent HDD of 1+ TB with decent amount of cache can do a burst transfer of over 100MB/s and sustained of over 70MB/s Compared to this flash cards, even the 266x can do only 10-15MB/s max.
IMO you'd be much better off getting a WD caviar 1TB or something like that, which will cost you about the same 100€ and will give you a lot more space to play with.
grichter ( ) posted Mon, 09 March 2009 at 10:49 PM
What can throw the results off is if you render twice without quitting Poser as it appears you now have the textures in cache
MacOSX 10.5.6,  Quad Core Intel Xeon 3 ghz, 16 gigs of 667DDR2 Ram, 8 cores, PoserPro,  4 threads, render as a separate process checked.
First render in background 2:03
Second Render Internal 1:01 (did not quit between renders)
Third Render again in Background 0:58 (did not quit between renders)
Quit and restart Poser
Fourth Render Internal 2:21
Fifth Render again in Background 0:58 (did not quit between renders)
After a fresh launch of Poser, it takes about half the Render time just loading the textures.
Gary
12rounds ( ) posted Tue, 10 March 2009 at 1:33 AM
I would advise against it. Not only flash cards are slow to write to, they have a limited amount of write cycles per memory cell and have no wear-levelling, no write buffers, no read caches etc.
Then again if you're going for a real SSD, THAT I would say will get you get nice big boost - for a pricetag. My experiments with a OCZ 60Gb SSD housing Poser are showing a huge impact on loading times. But I also put caches to a 10000rpm disk since SSD writes don't give the same benefits for writing as they do for reading and also this way also the system doesn't have to read and write the same disk at the same time. While my WD Velociraptor is THE fastest HD I've yet to encounter (for home use, that is), it loses to my SSD in every possible measurement I've made (the most important being a real-time analysis of disk activity during actual Poser use).
usamike ( ) posted Tue, 10 March 2009 at 6:10 AM
well, i guess i need this solution :
http://www.youtube.com/watch?v=96dWOEa4Djs&fmt=22
12rounds ( ) posted Tue, 10 March 2009 at 6:41 AM
Quote - well, i guess i need this solution :
LoL!
In that video they did a defrag on the SSDs... that's just stupid.
Defragmentation is pretty much meaningless when SSDs are concerned and defragging the disk can be even downright harmful - certainly it doesn't give any benefits.
usamike ( ) posted Sat, 02 January 2010 at 10:10 AM
i update the records :
update the list !
Render TIME |   thread  |         CPU              |     MHz     |     RAM    |   OS                  |  User
1"13s             |    4          |  Q6600                      | 2400      |    8GB    |   Vista64 bits | svdl
1"57s             |    4          |  QX6700 (over)        | 3000      |    4GB    |   XP 64 bits     | Magoo
1"58s             |    4          |  Q6600                     |   2400     |    8GB   |   XP 64 bits      | ChippsyAnn
2"01s             |    4          |  CI7-975                   | 3300      |    6GB    |   W7 64 bits     | usamike
2"07s             |    4          |  Q6600 (over)          | 3200      |    4GB    |   XP 64 bits     | ghonma
2"10s             |    4          |  QX6700 (over)        | 3000      |    8GB    |   XP 64 bits     | pjz99
2"11s             |    4          |  E6850 (over)           | 3300     |    2GB    |   XP 32             | Dalroi27
2" 11s            |    4          |  QX6700                   | 2670      |    4GB    |   XP 64 bits     | Magoo
2"15s             |     4         |   T7700                     | 2400      |   ????    |   Vista 64         |   adom
2"23s             |      2        |  Q6600                     |   2400     |    8GB   |   XP 64 bits      | ChippsyAnn
2"25s             |    4          |  Core2Extreme??  |  2800      |    2GB    |   MacOS           | MungoPark
2"46s             |    3          |  Q6600                     |  2400      |    4GB    |    XP 32            | xpac5896
3"                    |    4          |  Q6600                     |  2400      |    4GB    |   XP 64 bits     | ghonma
3"06s             |    4          |  AMD X2 6400+      |  3200       |   4GB     | XP Pro 64       | UrbanArmitage
3"07s             |    2          |  AMD X2 6400+      |  3200       |   4GB     | XP Pro 64       | UrbanArmitage
3"08s             |    4          |  E6600                     |  2700       |    2GB    |   XP 32 bits     | thefunkyone
3"21s             |    4          |  2x  Opteron 285    |  2600       |    8GB    |   XP 64 bits      | renderfred
3"40s             |    4          |  Q6600                     |  2400     |     4GB    |   XP 32 bits      | gsfcreator
3"56s             |    2          |  E6400  (over)        |  2320       |    2GB    |   XP 32 bits      | renderfred
4"41s             |    1          |  AMD X2 6400+      |  3200       |   4GB     | XP Pro 64       | UrbanArmitage
4"43s             |    2+HT  |  T7700                     |  2400       |   4GB     | XP Pro 32-bit   | UrbanArmitage
5"40s             |    4          |  2x AMD X2 5200+ |   2610      |    4GB    |   Vista 64         | tastiger
5"50s             |    2          |  Pentium D960      |   3600      |    2GB    |   XP 32 bits      | usamike
6"03s             |    1          |  T7700                     |  2400       |   4GB     | XP Pro 32-bit   | UrbanArmitage
6"31s             |    1+HT  |  Pentium 4C            |  3400      |    2GB    |   XP 32 bits      | renderfred
7"02s             |     3+HT |      P4                        |   3200      |    2GB    |   XP 32             | xpac5896
8"26s             |    1          |  Pentium D960      |   3600      |    2GB    |   XP 32 bits      | usamike
well ! i you can see ! it is plenty not a good test , neither a good benchmark !
i didn't say that because i have a huge hardware (red line)  and i am not be on the top of the list.
Everybody said that !
It would be good to have a real benchmark for poser like cinebench10 is for c4d !
A benchmark which can handle 8 threads and compiled in 64bits natively (will it be poser pro 2010 ?)
well , let's see now with poser 8, i'm installing it on the same hardware.
usamike ( ) posted Sat, 02 January 2010 at 11:04 AM · edited Sat, 02 January 2010 at 11:08 AM
i updated again  the records :
what did it change ?
i add new columns for poser version (V), and for the number of the successive render (T).
As the scene file can run in both poser 7 and 8 (maybe poser pro ?), it is very usefull to compare.
As the first render (directly after the scene loading) is longer than the second (due to hard drive read and caching), it is important to know when the render had been done.
in my case (usamike), the first  loading of the scene takes 1min before render and light computing. And in the second render, the hard drive didn't run (led is off) so i gess all the texture are been loaded from the memory cache (6 MB is enough to hangle the complete scene and its textures).
That's why in the previous result, the time render vas very curious (very longer than a q6600)
And known, on the same machine i have poser 7 and poser8 trial, and i can have an idea of the factor of render improvement :
seoncd render :
p7 : 47s
p8 : 33s
first render : (same time of hard drive loading, it is stranged..)
p7 : 2"01s
p8 : 1"33s
so at last, with 4 more threads (p8 uses my 8 threads where p7 uses 4), poser 8 renderfirefly is x1.42 quicker than poser 7.
i post there the render image in poser7 and poser8 to be sure it is the same in my eyes.
i looked it very closer, i didn't see any obvious differences except the size of the files.
poser7
poser8
if someone have a picture tool to compare it pixel by pixel, it can be usefull but it is enought for my eyes !
V | T | Render TIME |   thread  |         CPU              |     MHz     |     RAM    |   OS                  |  User
**8 | 2 |  0"33s             |   8           |  CI7-975                 | 3300      |    6GB    |   W7 64 bits  | usamike **
7 | 2 |  0"47s             |   4           |  CI7-975                   | 3300      |    6GB    |   W7 64 bits     | usamike
7 | ? |  1"13s             |    4          |  Q6600                      | 2400      |    8GB    |   Vista64 bits | svdl
8 | 1 |  1"33s             |   8           |  CI7-975                   | 3300      |    6GB    |   W7 64 bits     | usamike
7 | ? |  1"57s             |    4          |  QX6700 (over)        | 3000      |    4GB    |   XP 64 bits     | Magoo
7 | ? |  1"58s             |    4          |  Q6600                     |   2400     |    8GB   |   XP 64 bits     | ChippsyAn
7 | 1 |  2"01s             |    4         |  CI7-975                   | 3300      |    6GB    |   W7 64 bits     | usamike
7 | ? |  2"07s             |    4          |  Q6600 (over)          | 3200      |    4GB    |   XP 64 bits     | ghonma
7 | ? |  2"10s             |    4          |  QX6700 (over)        | 3000      |    8GB    |   XP 64 bits     | pjz99
7 | ? |  2"11s             |    4          |  E6850 (over)           | 3300     |    2GB    |   XP 32             | Dalroi27
7 | ? |  2" 11s            |    4          |  QX6700                   | 2670      |    4GB    |   XP 64 bits     | Magoo
7 | ? |  2"15s             |     4         |   T7700                     | 2400      |   ????    |   Vista 64         |   adom
7 | ? |  2"23s             |      2        |  Q6600                     |   2400     |    8GB   |   XP 64 bits    |ChippsyAnn
7 | ? |  2"25s             |    4          |  Core2Extreme??  |  2800      |    2GB    |   MacOS           | MungoPa
7 | ? |  2"46s             |    3          |  Q6600                     |  2400      |    4GB    |    XP 32            | xpac5896
7 | ? |  3"                    |    4          |  Q6600                     |  2400      |    4GB    |   XP 64 bits     | ghonma
7 | ? |  3"06s             |    4          |  AMD X2 6400+      |  3200       |   4GB     | XP Pro 64       | UrbanArm
7 | ? |  3"07s             |    2          |  AMD X2 6400+      |  3200       |   4GB     | XP Pro 64       | UrbanArm
7 | ? |  3"08s             |    4          |  E6600                     |  2700       |    2GB    |   XP 32 bits     | thefunky
7 | ? |  3"21s             |    4          |  2x  Opteron 285    |  2600       |    8GB    |   XP 64 bits      | renderfre
7 | ? |  3"40s             |    4          |  Q6600                     |  2400     |     4GB    |   XP 32 bits      | gsfcreato
7 | ? |  3"56s             |    2          |  E6400  (over)        |  2320       |    2GB    |   XP 32 bits      | renderfre
7 | ? |  4"41s             |    1          |  AMD X2 6400+      |  3200       |   4GB     | XP Pro 64       | UrbanArm
7 | ? |  4"43s             |    2+HT  |  T7700                     |  2400       |   4GB     | XP Pro 32-bit   | UrbanAr
7 | ? |  5"40s             |    4          |  2x AMD X2 5200+ |   2610      |    4GB    |   Vista 64         | tastiger
7 | ? |  5"50s             |    2          |  Pentium D960      |   3600      |    2GB    |   XP 32 bits      | usamike
7 | ? |  6"03s             |    1          |  T7700                     |  2400       |   4GB     | XP Pro 32-bit   | UrbanAr
7 | ? |  6"31s             |    1+HT  |  Pentium 4C            |  3400      |    2GB    |   XP 32 bits      | renderfr
7 | ? |  7"02s             |     3+HT |      P4                        |   3200      |    2GB    |   XP 32             | xpac5896
7 | ? |  8"26s             |    1          |  Pentium D960      |   3600      |    2GB    |   XP 32 bits      | usamike
usamike ( ) posted Tue, 05 January 2010 at 9:17 AM · edited Tue, 05 January 2010 at 9:19 AM
updated by ricky1:
8 | 2 |  02:00             |    2          |  Athlon 64x2             | 3000      |  8Gb       | w7 64              | Ricky1
8 | 1 |  03:45             |    2          |  Athlon 64x2             | 3000      |  8Gb       | w7 64              | Ricky1
Michael314 ( ) posted Tue, 20 April 2010 at 11:57 AM · edited Tue, 20 April 2010 at 11:58 AM
Hello,
just stumbled over this thread. Here's some data from my PC. I don't have Poser 7 installed any more, so I used P for PoserPro, and 2 for PoserPro 2010.
The data shows how much better the renderer now is, apart from that my system seems to be much slower than comparable boxes. I use standard memory timings, maybe that's the problem.
2 | 2 | 0"37s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314
8 | 2 | 2"06s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314
P | 2 | 5"20s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314
2 | 1 | 1"55s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314
8 | 1 | 2"50s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314
P | 1 | 5"50s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314
Best regards,
   Michael
Michael_REMY ( ) posted Tue, 20 April 2010 at 4:47 PM
thanks you !
i have poser pro 2010 too, i will make the test next week too.
here now, the list :
LostAlien ( ) posted Sun, 09 October 2011 at 6:02 AM · edited Sun, 09 October 2011 at 6:06 AM
Hello, Just ran the test for you...
  • Poser Version : 2012 pro 64bit
  • Render time   : 0 minutes and 20 seconds
  • CPU           : i7-2820QM
  • Threads       : 8
  • MHz           : 2.30
  • RAM           : 8GB + 3GB Video
  • OS            : Windows 7 Ultimate
  • User          : Lost Alien
Hope that helps
LA
usamike ( ) posted Sun, 09 October 2011 at 2:12 PM · edited Sun, 09 October 2011 at 2:12 PM
good Job lost alien ! i will do the same in the week (i just acquire&receive my pp2012) on my same and current workstation (ci7-975).
Your result is stomached me ! nowhere in my dream, i would have exptected a such improvment for a 3d software !
LostAlien ( ) posted Tue, 11 October 2011 at 4:14 PM
usamike,
Glad you are happy with the result.
I do have a bit of a monster PC as well...  It all helps!
Let me know if you want me to test anything else.
LA :biggrin:
Michael_REMY ( ) posted Sun, 26 February 2012 at 5:11 AM
Quote - Hello, Just ran the test for you...
  • CPU           : i7-2820QM
  • Threads       : 8
  • MHz           : 2.30
  • User          : Lost Alien
Hope that helps
LA
you score is wrong because poser2012 miss several texture of the g2 model.
you might had error message while loading p7b file.
i miss this :
G2Casual-TennisShoes
G2Casual-T-shirt
G2Casual-CasualPants
G2_Pants
G2_T_shirt
G2_Tennis_Shoes
so, 2 models (of 4) are nude, without clothes textures. Then the render is obviously faster !
i have to find out where these texture are gone ?
aRtBee ( ) posted Sun, 26 February 2012 at 7:15 AM
Glad to give some info too. Scene downloaded, unpacked and run, no flaws.
Score: 14-15 seconds to render, either internal or as external process (consistent over 6 runs).
When rendering external, shadow maps have to be calculated first unless re-used from an earlier run (check the menu option), this adds 5 to 10 sec and seems to be a 1-thread process. When rendering internally, things seem to be slightly different (= much faster).
When rendering the first time textures have to be found, this takes 40-50 sec additionally. Its a 1-thread process whether you render internally or externally. Speed depends on the size of the Poser Runtime folders which have to be searched, mine are 45-50Gb, the default Poser one is about 10% of this. The search result is stored in a Temp folder, so the search has to be redone only when this is cleared between scenes or Poser launches or - as in my case - machine reboots.
Specs:
win7 Pro Sp1 64-bit, PPro 2010 64-bit, CPU: i990X @4GHz (6 cores, 12 threads), RAM: 24Gb incl 4Gb Ram-disk for Temp, C: on SSD (program only, no data), Data on 9x2Tb disk unit, nVidia GTX560Ti OC/1Gb.
Indirect Lighting anyone? I just checked the box in Render Settings.
4.5 min (=270 sec) preparation, 95 sec rendering = 365 total. That's say 25 times as long compared to No IDL. No additional memory required. CPU temp ramped up to 75C = 170F (Idle=45*C). This is fun. Note that using LuxRender might need 30 mins to get a full blown photoreal result (well, not for this scene I guess), which is again 5 times longer.
Michael_REMY ( ) posted Sun, 26 February 2012 at 9:37 AM
Quote - Glad to give some info too. Scene downloaded, unpacked and run, no flaws. Score: 14-15 seconds to render, either internal or as external process (consistent over 6 runs).(...)
Specs:
so, according to your specs, i guess you use poser pro 2010 (not 2012) to run the test. that's explan why you did not have the miss texture file problem.
And for the record, with your i990X @4GHz and 12 threads and SSD configuration, you reached a x2 factor faster than my cpu (i7-975 3.3Ghz and 8 thread and hard drive). What is pretty much not bad at all !
aRtBee ( ) posted Sun, 26 February 2012 at 10:23 AM · edited Sun, 26 February 2012 at 10:24 AM
yeah, PPro2010 was mentioned in the specs.
And indeed: (12 threads * 4GHz) / (8 threads * 3.3Ghz) = 180%. Disks don't do much in this scene, and if any: Ram-disk beats all. Its simply a matter of horsepower. I guess UsaMike is aware of this (by now).
In reverse: my 14 sec * 180% = 25.2 which is 5 sec above your 20, hence PPro2012 might be 20% faster when taking the HW-factor out. Nice to know. I'm curious what they did to the IDL handling, perhaps you can give it a try. Total prep+render should take my 365 sec * 180% HW-factor * 80% PPro2012-factor = 525 sec.
usamike ( ) posted Sun, 26 February 2012 at 12:01 PM
updated on 26 february 2012
For whom wants to redo the test, i remember links (with textures fixed):
for poser pro 2012 only users : http://www.michael-remy.fr/forum/pro2012.zip
for poser pro 2010 users : http://www.michael-remy.fr/forum/pro2010.zip
for other poser (7,8 maybe 6) users : http://www.michael-remy.fr/forum/poser7.zip
legend :
v (version) :
2 : poser pro 2012
0 : poser pro 2010
8 : poser 8
7 : poser 7
p : poser pro (release before the 2010 one)
0 | ? |  0"14s             |   12         |  Ci7-990X              | 4000      |   24GB    |   W7 64 bits  | Artbee (poser p2010 and SSD)
2 | ? |  0"20s             |   8           |  Ci7-2820QM           | 2300      |    8GB    |   W7 64 bits  | Lost Alien (maybe missing texture)
2 | 2 |  0"22s             |   8           |  CI7-975                 | 3300      |    6GB    |   W7 64 bits  | usamike
2 | 1 |  1"11s             |   8           |  CI7-975                 | 3300      |    6GB    |   W7 64 bits  | usamike
0 | 2 |  0"25s             |   8           |  CI7-975                 | 3300      |    6GB    |   W7 64 bits  | usamike
0 | 1 |  1"15s             |   8           |  CI7-975                 | 3300      |    6GB    |   W7 64 bits  | usamike
WandW ( ) posted Sun, 26 February 2012 at 1:05 PM · edited Sun, 26 February 2012 at 1:19 PM
AMD Phenom X6,  3200 MHz, 16 GB, 6 threads  Poser Pro 2012; 1' 37"
For this to be a true CPU benchmark, rather than a disk benchmark, one should hit Cancel after it starts rendering, so the textures remain loaded in RAM, and then rerender.  Doing that, I got 38 seconds.  Going from a 64 pixel to 128 pixel bucket size cut off 0.3 seconds... 😄
EDIT Switching light 2 to Raytraced shadows cut it down to 28 seconds.
WandW ( ) posted Sun, 26 February 2012 at 1:27 PM
Oops; too late to edit.
I inadvertently turned shadows off above 😊  It took 1' 2" with raytraced shadows...
aRtBee ( ) posted Sun, 26 February 2012 at 1:32 PM
T=2 in my case (0'14"). The T=1 case takes about 50"longer, and therefor reads 1'04"
@WandW: dont press cancel, just finish the initial render. Your T=1 was 1'37" while T=2 lasted 0'38". Values make perfect sense.
The observation on raytraced shadows is interesting, as compared to shadow maps: better=faster in this case.
aRtBee ( ) posted Sun, 26 February 2012 at 1:57 PM
so better = slower still. That's a relief.
bevans84 ( ) posted Sun, 26 February 2012 at 4:26 PM · edited Sun, 26 February 2012 at 4:27 PM
i7 2600, 3400 mhz, 8 gig ram     19s     PP2012
It started at 3800 mhz (turbo boost) settled down to 3500mhz for most of the render, and sped up to 3700 towards the end
JimTS ( ) posted Sun, 26 February 2012 at 4:50 PM
Unzipped obz"s
Config i7 970 w 24G ram
Poser 7 T2 render 1:43
Pro 2012 T2 render 0:24
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
Eric Walters ( ) posted Sun, 26 February 2012 at 11:17 PM
 Your image is very amusing. No P7 so I cant join the race!
Quote - Like pjz99, I built my machine 10 months ago and the only quad available was the QX6700. But
if I were going to built today, I'd go for the QX9650. Only because it's a 45nm architecture chip,
and the extreme chips are unlocked (better for overclocking). Now if money was an issue, I'd
wait for the regular quads to come out with the 45nm, these 65nm chips run hot, way HOT.  But
all in all, I'm very happy with what I have now. Haven't been able to bring it to it's knees yet. And I
love loading up scenes. 8-)
prixat ( ) posted Mon, 27 February 2012 at 2:17 AM
Where can I find a timer in Poser Debut?
regards
prixat
LostAlien ( ) posted Mon, 27 February 2012 at 2:33 AM
> Quote - > Quote - Hello, Just ran the test for you... > > > > - Poser Version : 2012 pro 64bit > > - Render time   : 0 minutes and 20 seconds > > - CPU           : i7-2820QM > > - Threads       : 8 > > - MHz           : 2.30 > > - RAM           : 8GB + 3GB Video > > - OS            : Windows 7 Ultimate  > > - User          : Lost Alien > > > > Hope that helps > > > > LA  > >   > > you score is wrong because poser2012 miss several texture of the g2 model. > > you might had error message while loading p7b file. > > i miss this : > > G2Casual-TennisShoes > G2Casual-T-shirt > G2Casual-CasualPants > G2_Pants > G2_T_shirt > G2_Tennis_Shoes > > so, 2 models (of 4) are nude, without clothes textures. Then the render is obviously faster ! > >   > > i have to find out where these texture are gone ?
Michael,
Thank you for your e-mail.
I believe my results are sound and are valid for the following reasons:
  1. I use all the poser libraries from several previous versions of poser as well as 2012
  2. I had no error or warning messages
  3. All characters in the scene were skinned and the render was complete
  4. The scene looked good to me
  5. I have been using poser for over 12 years and am very familiar with the product
  6. I have just opened Poser, added both male and female G2 tennis shoes
        This worked without issue and rendered perfectly... See attached image.
G2 Tennis Shoes
If you are having issues with missing components and have legitimate copies of previous versions of Poser, I would suggest using your backups to restore your runtimes and include them in the list of libraries.
If you don't have backups available, install the earlier versions on another computer, create a backup of the Runtime then deinstall poser on that computer.
You will need to do this for each version.
Do not leave Poser installed on another computer unless you are licensed to do so.
If you do not have another computer available, you could try the following (at your own risk):
  1. Take a backup
        Full image if possible or copy the poser folder to another location.
  2. Remove Poser 2012
        This will be restored as it is in step 8 below.
  3. Install earliest version of poser that you have
        This will create the runtime folders with the missing content.
  4. Make a copy of the runtime in another location
       This is done so that you can use them once Poser 2012 is restored.
  5. Remove this old version of Poser
        Do this by using the uninstall, do not just delete the folder.
  6. Repeat steps 3 to 5 for all your versions
    This will result in all runtimes being restored and saved.
  1. Reinstall Poser 2012
        This will be a "Vanilla" build of Poser 2012
  2. Overwrite the new Poser 2012 folder with the one taken in step 1 above
        This will restore your poser folder to how it was when you removed it...
  3. You should now be back to where you started but with all your runtimes
        Add them to your library list in poser.
Note that I have not performed these steps as I use my backups.  If you undertake these actions, you do so at your own risk.  This is, in my opinion, a valid way to do this although you might want to check with SmithMicro to see if it would cause any issues or if they have a better solution.
You mentioned that the following files were missing:
  • G2Casual-TennisShoes
  • G2Casual-T-shirt
  • G2Casual-CasualPants
  • G2_Pants
  • G2_T_shirt
  • G2_Tennis_Shoes
On my computer, these are currently in my Poser 7 libraries so, unless I moved them from somewhere else, I assume that these came with Poser 7?  Not sure, don't really care - They are there.
I have 5 libraries in my version of Poser 2012 - 3 are from earlier versions of poser (Poser 7, Poser 2010 and Poser 2012) and the others I created myself to keep my own content separate.
Having multiple libraries is a great feature of Poser.
Thank you for your concern.
I hope that this helps you.
LA
prixat ( ) posted Mon, 27 February 2012 at 4:52 AM
I got a message window asking me for those specific files.
I noticed Debut has them installed as OBZ and the P7 scene was looking for OBJ.
regards
prixat
WandW ( ) posted Mon, 27 February 2012 at 7:07 AM
If you point the request for the shoes' obj to the clothing for Simon and the pants to Sydney clothing (both under libraries/props) and select the appropriate obz, it will load fine.
One additional note; I have a scene with a lot of transparency and an SSS skin texture.  In PP2012 with my Phenom X6 at 3200 MHz it rendered in 57' 35".  Bumping it up to 3500 MHz cut the render time to 54' 2", which is about a 5% decrease in render time for a 10% increase in processor speed.
Max CPU temperature was 52 C at the higher speed, as compared to 46 C at stock speed...
aRtBee ( ) posted Mon, 27 February 2012 at 7:51 AM
@WandW
  1. did the CPU ran at full 100% in both cases? Memory should have matching speeds too.
  2. you can check the real net clock speeds with TMonitor from cpuid.com (freebie).
Thanks to Turbo Boost Technology, clock speeds are dynamic and temp dependant. So if your 3200-setup actually ran at 3400, and your 3500 setup could make 3600, then that's just a 5% diff. Or: overclocking requires over-cooling to get the real benefits out. Although your 52C is quite low, actually. PhenomX6 is quite nice.
WandW ( ) posted Mon, 27 February 2012 at 10:08 AM · edited Mon, 27 February 2012 at 10:15 AM
When Poser renders, it uses all 6 cores at 100% of the base CPU clock speed.  Turbo Boost doesn't kick in because all of the cores are being used.
At 3500 I'm running at 1.32 Volts at full load, compared to 1.26 V at 3200.
EDIT I should add that I could overclock the bus as well, but since it is an unlocked chip It's simpler to tweak the multiplier...
aRtBee ( ) posted Mon, 27 February 2012 at 10:59 AM
Might be. My i7-990X (factory: 3,46GHZ, overclock: 4GHz) says 99% for the Poser process, cores charged at 3997.4 MHz turbo included (yellow bars) but incidental dips and peaks (see Core4) happen. Turbo off runs at 3,46HGHz. TMonitor performs 20 samples / sec.
Individual threads however perform different, turbo off make most (!) of them run at 3464.5 (next image), but with turbo on none (!) of them made the full 4GHz (image after that). I am loosing some 4% there.
So, run TMonitor with the -T option (threads), and find out if your 3500-setting really delivers.
I'll stop this now, as we are sort of sidetracking this forum thread.
aRtBee ( ) posted Mon, 27 February 2012 at 11:00 AM
Showing Threads, turbo off
aRtBee ( ) posted Mon, 27 February 2012 at 11:01 AM
Showing Threads, turbo ON
WandW ( ) posted Mon, 27 February 2012 at 3:29 PM
I have Turbo mode disabled at 3500.  I looked at the CPU utilization with AMD Overdrive, and its charts look much like yours.  The difference could be memory timing related, as 3200 is a multiple of the 800 MHz memory speed...
usamike ( ) posted Sun, 20 September 2015 at 2:36 AM · edited Sun, 20 September 2015 at 2:40 AM
updated on 20 september 2015 since i update my configuration hardware, i redo this old test (not perfect, but the only poser benchmark on the internet!)
Please post your result with this form to help me tu update the tab array
V | T | Render TIME  |   thread  |         CPU              |     MHz     |     RAM    |   OS                  |  User & small comment
4 | 2 |  0"11s             |   12         |  Ci7-980X             | 3300        |   12GB    |   W7 64 bits      | usamike (poser p2014 and SSD evo850)
it is awsome to see that poser pro 14 make my render quicker than the higher cpu (i7 990x) with older poser pro release (pp2012)
for poser pro 2012 and 2014 only users : http://www.michael-remy.fr/forum/pro2012.zip
Legend :
v (poser version) :
4 : poser pro 2014
2 : poser pro 2012
0 : poser pro 2010
8 : poser 8
7 : poser 7
And T means 1 or 2. When first render (load texture to disk) then it is 1, and when second render next, it is 2 (texture are already preload in memory)
2 | 2 | 0"38s              | 6             |Phenom X6                  | 3200      | 16GB      | XP 64 bits     |   WandW
2 | 1 | 1"37s              | 6             |Phenom X6                  | 3200      | 16GB      | XP 64 bits     |   WandW
usamike ( ) posted Thu, 28 December 2017 at 3:06 PM · edited Thu, 28 December 2017 at 3:08 PM
updated on 27 december 2017 since i update my configuration software, i will redo this old test (not perfect, but the only poser benchmark on the internet!)
Please post your results with this form to help me to update the tab array
V | T | Render TIME | thread | CPU | MHz | RAM | OS | User & small comment 4 | 2 | 0"11s | 12 | Ci7-980X | 3300 | 12GB | W7 64 bits | usamike (poser p2014 and SSD evo850)
for poser pro 2012 and 2014 only users : http://www.michaelremy.fr/pro2012.zip for poser pro 2010 users : http://www.michaelremy.fr/pro2010.zip for other poser (7,8 maybe 6) users : http://www.michaelremy.fr/poser7.zip
Legend :
v (poser version) :
11: Poser Pro 2011 4 : poser pro 2014 2 : poser pro 2012 0 : poser pro 2010 8 : poser 8 7 : poser 7 p : poser pro (release before the 2010 one)
And T means 1 or 2. When first render (load textures from hard drive) then it is 1, and when second render next, it is 2 (textures are already preload from memory or cached)
4 | 2 | 0"11s | 12 | Ci7-980X | 3300 | 12GB | W7 64 bits | usamike (poser p2014 and SSD evo850) 0 | ? | 0"14s | 12 | Ci7-990X | 4000 | 24GB | W7 64 bits | Artbee (poser p2010 and SSD) 2 | ? | 0"20s | 8 | Ci7-2820QM | 2300 | 8GB | W7 64 bits | Lost Alien (maybe missing texture) 2 | 2 | 0"22s | 8 | CI7-975 | 3300 | 6GB | W7 64 bits | usamike 0 | 2 | 0"25s | 8 | CI7-975 | 3300 | 6GB | W7 64 bits | usamike 8 | 2 | 0"33s | 8 | CI7-975 | 3300 | 6GB | W7 64 bits | usamike 2 | 2 | 0"37s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314 2 | 2 | 0"38s | 6 |Phenom X6 | 3200 | 16GB | XP 64 bits | WandW 7 | 2 | 0"47s | 4 | CI7-975 | 3300 | 6GB | W7 64 bits | usamike 2 | 1 | 1"11s | 8 | CI7-975 | 3300 | 6GB | W7 64 bits | usamike 7 | ? | 1"13s | 4 | Q6600 | 2400 | 8GB | Vista64 bits | svdl 0 | 1 | 1"15s | 8 | CI7-975 | 3300 | 6GB | W7 64 bits | usamike 8 | 1 | 1"33s | 8 | CI7-975 | 3300 | 6GB | W7 64 bits | usamike 2 | 1 | 1"37s | 6 |Phenom X6 | 3200 | 16GB | XP 64 bits | WandW 2 | 1 | 1"55s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314 7 | ? | 1"57s | 4 | QX6700 (over) | 3000 | 4GB | XP 64 bits | Magoo 7 | ? | 1"58s | 4 | Q6600 | 2400 | 8GB | XP 64 bits | ChippsyAn 7 | 1 | 2"01s | 4 | CI7-975 | 3300 | 6GB | W7 64 bits | usamike 8 | 2 | 02:00 | 2 | Athlon 64x2 | 3000 | 8Gb | w7 64 | Ricky1 7 | ? | 2"07s | 4 | Q6600 (over) | 3200 | 4GB | XP 64 bits | ghonma 8 | 2 | 2"06s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314 7 | ? | 2"10s | 4 | QX6700 (over) | 3000 | 8GB | XP 64 bits | pjz99 7 | ? | 2"11s | 4 | E6850 (over) | 3300 | 2GB | XP 32 | Dalroi27 7 | ? | 2" 11s | 4 | QX6700 | 2670 | 4GB | XP 64 bits | Magoo 7 | ? | 2"15s | 4 | T7700 | 2400 | ???? | Vista 64 | adom 7 | ? | 2"23s | 2 | Q6600 | 2400 | 8GB | XP 64 bits |ChippsyAnn 7 | ? | 2"25s | 4 | Core2Extreme?? | 2800 | 2GB | MacOS | MungoPa 7 | ? | 2"46s | 3 | Q6600 | 2400 | 4GB | XP 32 | xpac5896 8 | 1 | 2"50s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314 7 | ? | 3" | 4 | Q6600 | 2400 | 4GB | XP 64 bits | ghonma 7 | ? | 3"06s | 4 | AMD X2 6400+ | 3200 | 4GB | XP Pro 64 | UrbanArm 7 | ? | 3"07s | 2 | AMD X2 6400+ | 3200 | 4GB | XP Pro 64 | UrbanArm 7 | ? | 3"08s | 4 | E6600 | 2700 | 2GB | XP 32 bits | thefunky 7 | ? | 3"21s | 4 | 2x Opteron 285 | 2600 | 8GB | XP 64 bits | renderfre 7 | ? | 3"40s | 4 | Q6600 | 2400 | 4GB | XP 32 bits | gsfcreato 8 | 1 | 03:45 | 2 | Athlon 64x2 | 3000 | 8Gb | w7 64 | Ricky1 7 | ? | 3"56s | 2 | E6400 (over) | 2320 | 2GB | XP 32 bits | renderfre 7 | ? | 4"41s | 1 | AMD X2 6400+ | 3200 | 4GB | XP Pro 64 | UrbanArm 7 | ? | 4"43s | 2+HT | T7700 | 2400 | 4GB | XP Pro 32-bit | UrbanAr P | 2 | 5"20s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314 P | 1 | 5"50s | 4 | Q9550 | 2800 | 4GB | XP 64 bits | Michael314 7 | ? | 5"40s | 4 | 2x AMD X2 5200+ | 2610 | 4GB | Vista 64 | tastiger 7 | ? | 5"50s | 2 | Pentium D960 | 3600 | 2GB | XP 32 bits | usamike 7 | ? | 6"03s | 1 | T7700 | 2400 | 4GB | XP Pro 32-bit | UrbanAr 7 | ? | 6"31s | 1+HT | Pentium 4C | 3400 | 2GB | XP 32 bits | renderfr 7 | ? | 7"02s | 3+HT | P4 | 3200 | 2GB | XP 32 | xpac5896 7 | ? | 8"26s | 1 | Pentium D960 | 3600 | 2GB | XP 32 bits | usamike
willyb53 ( ) posted Thu, 28 December 2017 at 8:17 PM · edited Thu, 28 December 2017 at 8:17 PM
I will play :D
2 | 2 | 0"14.5s | 24 | X5670 (2) | 2930 | 48 gig | win7 pro | willyb53
bantha ( ) posted Sat, 30 December 2017 at 9:00 AM · edited Sat, 30 December 2017 at 9:02 AM
11| 2 | 0"12.8s | 16 |Ryzen 7 1700 | 3000 | 16 gig | win10 pro | Bantha
11| 2 | 0"10.6s | 16 |Ryzen 7 1700 | 3800 | 16 gig | win10 pro | Bantha
I don't think that this scene is complex enough to get good results from a lot of cores.
-"Amazing Grace" Hopper
  • 1
  • 2
