Tue, Jan 28, 5:36 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Object not visible - help please
mykyndryd ( ) posted Tue, 11 October 2011 at 5:42 AM · edited Tue, 28 January 2025 at 5:36 PM
Hi.
This will be incredibly simple but I'm stuck ...
I created a landscape in VistaPro. Exported the elevations to .obj (via .dxf which Poser couldn't read for some reason, but Blender could and then from Blender to .obj)
I can import the obj file into Poser but can only see it if it is selected or the view is 'outline'.
Nothing renders. I'm sure this is a texture / map issue but don't know where to go from here. Any ideas please ?
Regards.
Mike.
Poser 8
Windows 7 / 64 bit Home premium
Quad / Duo / 4Gb Ram
RedPhantom ( ) posted Tue, 11 October 2011 at 6:11 AM
Site Admin
If you think it's a texture issue it helps to post a screen shot of the material room. It's hard to find problems without knowing what you're doing.
bagginsbill ( ) posted Tue, 11 October 2011 at 6:28 AM
It's probably upside down.
mykyndryd ( ) posted Tue, 11 October 2011 at 6:43 AM
Hi. Thanks to both for replies.
I was hoping you were right Bill but nope - I've loked at it from every angle. I don;t think it has any texture at all if that's possible.
Thanks for the tip Red - here's the snapshot of the material room ...
TrekkieGrrrl ( ) posted Tue, 11 October 2011 at 6:50 AM · edited Tue, 11 October 2011 at 6:50 AM
I'll go with Bill and say the normals are inverted.
Try selecting the whole thing with the Grouping tool (easiest done when in Outline/wireframe mode) and then click Inverse Group Normals. And see if that doesn't bring it forth :)
mykyndryd ( ) posted Tue, 11 October 2011 at 6:55 AM
Thanks Trekkie - Tried that - plus a few variants and still seems to be in stealth mode ...
markschum ( ) posted Tue, 11 October 2011 at 10:21 PM
could you post the obj file ?
