Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
If you think it's a texture issue it helps to post a screen shot of the material room. It's hard to find problems without knowing what you're doing.
I'll go with Bill and say the normals are inverted.
Try selecting the whole thing with the Grouping tool (easiest done when in Outline/wireframe mode) and then click Inverse Group Normals. And see if that doesn't bring it forth :)
![file_473864.jpg](https://live.cdn.renderosity.com/forum/threads/2837173/file_473864.jpg)
Hi.This will be incredibly simple but I'm stuck ...
I created a landscape in VistaPro. Exported the elevations to .obj (via .dxf which Poser couldn't read for some reason, but Blender could and then from Blender to .obj)
I can import the obj file into Poser but can only see it if it is selected or the view is 'outline'.
Nothing renders. I'm sure this is a texture / map issue but don't know where to go from here. Any ideas please ?
Regards.
Mike.
Poser 8
Windows 7 / 64 bit Home premium
Quad / Duo / 4Gb Ram
