Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
If you're trying to render a relatively tight shot of the riverbed; I'd recommend using the surface replicator. In a nutshell; model the rocks and boulders first; then create a terrain in the basic shape you're after. Use the surface replicator to disperse the rocks on the terrain, all nice and random.
Carrara's terrain editor won't give you that much detail up close. If you're new to Carrara; Mark Bremmer's tutorials cover the process and are well worth picking up :)
If you have some pictures of what you're after; you could also convert them to grey-scale and make displacement maps as an alternative. (You may have to actually model the terrain in that case)
JT
Ha! Thanks for the props JT!
Yes, the surface replicator is the wat to go. You can control distribution very accurately with Terrain shader. My last series has a specific tut on that. In brief, you create a custom channel in the terrain shader and then control distribution (black and white) with altitude. Use that shader with the replicator and then the replicator will take care of the random placement within the river bed.
Quote - Okay, here's my first attempt that even gets close (with really poor rocks, but again its just a first attempt). As you can see, its doing the exact opposite of what I want. How do I get the replicator to switch from white to black in the shader?
You can edit the shader and in the shader options, if your black and white distribution is a texture map, you can just check the "Invert Color" option in the texture properties. If your black/white distribution is procedural, then it might be trickier, because it will depend on the type of procedural shader you are using.
I've read just about every tutorial there is on the terrain editor in C8 pro, but I still can't make heads or tails of it. I'm trying to make a relatively simple rocky river bed (gravel and sand and occasional small boulder on the river bottom). I'm trying to make a scene on the bottom of a river and just can't figure out how to do it.
Any help would be immensely appreciated!
