Tue, Feb 11, 1:25 AM CST
Subject: conforming beads
Arah ( ) posted Thu, 10 November 2011 at 1:40 PM · edited Tue, 11 February 2025 at 1:15 AM
ok, here's another question, i think the image is pretty self explanitory, any ideas on how to fix the streatching? i tried confomring the streatched beads to the collar and then the shoulder, but that didn't seem to help.
I also tried fixing it in the Hierarchy editor, but that didn't help either.
can someonw please help me out with this!
nruddock ( ) posted Thu, 10 November 2011 at 3:09 PM
If the beads' geometry is part of a body part group, then you'll get distortion.
The only way you can solve the problem is to add extra bones and groups, in this case one per strand, however this is a nightmare in the making if you are planning to have any morphs that affect the attachment point for the bead strings.
Arah ( ) posted Thu, 10 November 2011 at 4:26 PM
sounds like one, well i could just conform it the normal, and hope people won't mind beans instead of beads, :P
Thanks anyway though.
Acadia ( ) posted Thu, 10 November 2011 at 6:31 PM
Maybe they should be dynamic instead of conforming?
bantha ( ) posted Fri, 11 November 2011 at 11:41 AM
Should be worth a try. Do they behave properly in the cloth room? Maybe you will have to add a simple strip for each bead, set to invisible, as the collision part, and make the beads soft decorative.
-"Amazing Grace" Hopper
Arah ( ) posted Fri, 11 November 2011 at 2:44 PM
in the cloth room they all fall apart, but maybe that's because i didn't group them properly. well i'm trying several different methods, and hopefully one of them will work!
Thank you!
