Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Another Question:I have tried to use Puppet Master Biped with the latest Antonia and I keep getting an error message.I have the Data file for Antonia in the Python script of Poser Pro (which I have the runtime added to Pro 2012. I have not put it in Pro 2012 as I do not know if it has been updated. Any suggestions? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Quote - Another Question:I have tried to use Puppet Master Biped with the latest Antonia and I keep getting an error message.I have the Data file for Antonia in the Python script of Poser Pro (which I have the runtime added to Pro 2012. I have not put it in Pro 2012 as I do not know if it has been updated. Any suggestions? Cheers
I don't know anything about Puppet Master Biped, but Python scripts aren't shared between versions of Poser, when you link Runtimes. Such Runtime linking only covers Libraries, AFAIK. The functionality of Python scripts is dependent on the version of Poser being run and the version of Python used by the version of Poser being run. So the Runtime linking won't have any effect here. If you're relying on that to make the script function, it won't work. :sad:
Some scripts don't need to be updated for Poser 9/Poser Pro 2012. You might try installing the script into the PPro2012 Runtime and running it from there, with the data file installed. If it doesn't run in 2012, is there a reason you can't run it in the earlier version, save the script results, then work with them in 2012? If not, that might solve the problem.
If none of that helps, the details of the error message could help someone determine where things are going wrong.
Cage,Many thanks.Cheers
as far as I know Puppet Master is not compatible with the most recent version of Poser. I work a lot with it and so simply start Poser 7 that still has Puppet Master in it and convert them. Then I move the poses to a new folder (into PoserPro 2012) and finetune everything there.
By the way: I have a new dat-file for Antonia 1.2 that you might like. I have attached it to this message, you just have to rename the txt to zip. And I think that the Joint Limits Pose for Antonia by Netherworks is extremly useful when converting. The converted poses often show extremly twisted feet/toes and fingers. So when fine-tuning everything:
Load Antonia into a fresh scene
Use the limit pose
Choose "Use Limits" from the Poser menue under "Figure"
Apply the converted pose you save
Tweak any bodypart
Uncheck use limits
And finetune everything else until you are satisfied.
This way you do not have to fumble around with rotated fingers and such.
I've updated the file on the Antonia Freebie site as well. I tested it with Antonia 1.2 and Standard, the resulting poses work with the upcoming Antonia WM as well but may require some small tweaks.
I'm not always right, but my mistakes are more interesting!
And I am not strange, I am Limited Edition!
Are you ready for Antonia? Get her textures here:
The Home Of The Living Dolls
I seem to have another question.Someone somwhere in this thread gave a link to a V3 Hair Conversion file for Antonia.When I go to use it in Poser it keeps asking for a haircon obj.Does anyone where this item may have come from so I can re download and put the file in? Also many thanks SaintFox for the Data file. I am hoping to make a few animated poses for Antonia if all goes well. Cheers
Sorry, I have no clue about the haircon.obj and where it may be available. Meanwhile there is a hairconversion for Antonia avaiable at RDNA that works like a charm, even with cr2-hair (with few exceptions that have non body-part bones, at least this seems the reason for me that parts of the hair are not converted).
About the animation: There is a huge request for them here, where Antonia WM is prepared at the moment:
http://poserplace.phantom3d.net/forums/viewforum.php?f=30
You may want to have a look...
Oh and Les?! May I add that I miss you over there, you and your quick little hints and solutions?!
Quote - I seem to have another question.Someone somwhere in this thread gave a link to a V3 Hair Conversion file for Antonia.When I go to use it in Poser it keeps asking for a haircon obj.Does anyone where this item may have come from so I can re download and put the file in? Also many thanks SaintFox for the Data file. I am hoping to make a few animated poses for Antonia if all goes well. Cheers
Is this the Netherworks Conversion kit at RDNA?
Quote - Someone somwhere in this thread gave a link to a V3 Hair Conversion file for Antonia.When I go to use it in Poser it keeps asking for a haircon obj.Does anyone where this item may have come from so I can re download and put the file in?
Might be this one?
http://www.renderosity.com/mod/freestuff/details.php?item_id=59872
Cheers
Poser Pro 11, DAZ Studio 4.9
Well since I have the texture work, the mc6 files and props done on my earrings, I decided to do some extra.
I've braved the set-up room in Poser 6 to add bones and movement to my earring. :)
So far all is going great.
I'm loving this Poser stuff more and more. :-)
Antonia Lace Boots
http://www.runtimedna.com/Antonia-Lace-Boots.html
All the best.
LROG
Joint Content Manger for Antonia WM
Who honors those we love for the very life we live?, Who sends monsters to kill us?, and at the same time sings that we will never die., Who teaches us whats real?, and how to laugh at lies?, Who decides why we live and what we'll die to defend?, Who chains us?, and Who holds the key that can set us free... It's You!, You have all the weapons you need., Now Fight!
Many thanks Haruchai.That was the item.Cheers
Antonia Advanced Morphs
http://www.runtimedna.com/Antonia-Advanced-Morphs.html
Have fun folks!!!!!
LROG
Antonia Advanced Morphs are released now (as a product) at RDNA. I know that many of you have been waiting for this.
lmk
Probably edited for spelling, grammer, punctuation, or typos.
Rima for Antonia Polygon http://www.runtimedna.com/Rima-for-Antonia-Polygon.html
Congratulations to Raine!!!!
All th best.
LROG
Congratulations on the lanuch of the morphs!!!!!
Time for Antonia to shine!!!
Love the morphing promos!!!! Lol.
All the best.
LROG
I am slowwww!
Still got work to do to ge tmy new character out there...sob.
But I got distracted by these earrings I working on.
I want to have the earrings ready for the Christmas party but they will be static props only for now.
And the texture has to be applied in the material room, won't work as a pz2 mat for some reason. And now there's company filling up the house to do pre-cooking for tomorrow.
Got Antonia Polygon - Standard? Got Antonia Advanced Morphs???
AntiTonia
http://www.sharecg.com/v/57176/view/11/Poser/AntiTonia---Requires-Antonia-Advanced-Morphs
Poser 6 upwards
All the best.
LROG
OOOPSIE!!!! Bad eyes due to allergy!!! LOL.
All the best.
LROG
Joint Content Manager for Antonia Polygon -WM
Aargh! I can't keep up. I have had to update my Antonia Polygon links thread 6 times today to add products and freebies!
Thanks!
lmk
Quote - I am slowwww!
Ah, go enjoy your company, Poser stuff isn't nearly as important.:biggrin:
Congrats to Afrodite and Raine on the new things for Antonia. Nice to see Antonias page filling up with products.
Quote - These morphs look really tempting. :-)
Oh shrugs idiotic me didn't send them to you, of all people! Check your PMs xD
Feel free to call me Ohki!
Quote - > Quote - These morphs look really tempting. :-)
Aw, thanks! I guess now I'll be obligated to fire up my rusty old PP2010 again and try them out?
If only the latest wine could find it in its heart to cooperate...
http://www.ShareCG.com/v/57203/view/11/Poser/Antonia---Hair-Fits-I
Antonia Hair fits for: Aether Hair, Akaste Hair, Alexios Hair, Alkyone Hair, All Time Hair, Amaltheia Hair, Amphitrite Hair, Anemone Hair, Apollonia Hair and Athanasia Hair.
>>> 2nd Face - a cool way to change a figure's face | Renderosity
Hi SaintFox, Many thanks for the data file for Antonia.Sorry to be a pest but according to the data files in Puppet master I need both a txt file and a data file. How do I achieve both with your file? Cheers
Quote - Aw, thanks! I guess now I'll be obligated to fire up my rusty old PP2010 again and try them out? If only the latest wine could find it in its heart to cooperate...
I haven't found a single wine that won't cooperate after the 3rd glass or so, odf... :biggrin:
Oh, you meant WINE (WINE Not An Emulator)... keep forgetting you're on Ubuntu...
Quote - as far as I know Puppet Master is not compatible with the most recent version of Poser. I work a lot with it and so simply start Poser 7 that still has Puppet Master in it and convert them. Then I move the poses to a new folder (into PoserPro 2012) and finetune everything there.
What happened? Another change in Python?
Quote - What happened? Another change in Python?
Poser 9 and Poser Pro 2012 use Python 2.7. Posers 7,8, and Pro 2010 used Python 2.4. Posers 5 and 6 used Python 2.2. The original Poser Pro Pack used... umm. I don't know what. Possibly Python 1.4. :unsure:
Any change of Python version breaks .pyc and .pyd files from previous versions. The move from 2.4 to 2.7 has required a change from Numeric to Numpy, which will leave older scripts which used Numeric broken unless they're updated for Numpy. Python 2.7 introduces a few bugs, too, which need to be corrected (notably a bug in Tkinter's askopenfilenames, which requires a workaround).
http://www.sharecg.com/v/57221/view/11/Poser/Antonia---Hair-Fits-II
Antonia Hair fits for: Bandua Hair, Bolina Hair, Classic Cut II, Cleone Hair, Damaris Hair, Dodona Hair, Enzio Hair, Erato Hair, Ersa Hair and Eudora Hair.
http://www.ShareCG.com/v/57219/view/11/Poser/Templates---Antonia
SainFox, Many thanks again! Cheers
Quote - XD - CrossDresser by EvilInnocence is now on sale at EvilInnocences site.
3Dream thanks for the hair fits and templetes. You are keeping me busy updating my links thread for Antonia Polygon at PoserPlace. :)
lmk
Waiting until I get back to my main computer to install Antonia and AntoniaWM when released. I hope the merchants and or freebee providers keep you swamped for a long time to come!!!!! :laugh:
Gary
Quote - Waiting until I get back to my main computer to install Antonia and AntoniaWM when released. I hope the merchants and or freebee providers keep you swamped for a long time to come!!!!! :laugh:
We're hoping that too, grichter! And people doing heaps and heaps of renders of Poser favourite new girl! :biggrin:
If you are in the US, later this week (Thursday) we celebrate Thanksgiving Day or as can be nicknamed "Turkey Day", because that is the traditional meal served.
As we sit down to our Thanksgiving dinners, lets not forget to say a special "Thanks" to the Antonia crew. And also remember because of all their hard work, Antonia is no "Turkey!"
Drooling all over myself waitng for the tasty treat called Antonia-WM with visions floating in my head that Christmas might just come early this year!
Gary
