Agree with meatSim. You'll need to have a look in the material room in the advanced tab for anything skin. Certain shaders were designed to have ambient_value > 0. Unfortunately, simply making it zero isn't going to fix the problem.
Depending on your version of Poser, may I suggest VSS by Bagginsbill, which comes with an excellent skin shader.
Yeah, it looks like ambient plus IBL to me as well.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
VSS PR1 PR2 and PR3 were written for Poser 7 or less. They assumed you did not have IDL, did not have GC, etc.
You do not want to use that shader with PP2012. You want to use one of the shaders I have posted at RDNA - the best being the S+B shader I showed on James. I posted a VSS-ready version of that skin shader.
However, you can use PR3 with PP2012 - you must make two adjustments.
One, if render GC is on, then in the VSS skin shader, change PM:Gamma to 1. It is 2.2 by default, which does the GC in the shader. You do not want to double up on GC.
Second, if using IDL, you want to decrease the PM:SSS value. The default is 1 - try .3. This parameter adds red to the shadowed (less lit) areas, particularly armpits, between legs, etc. Because IDL bounces skin-colored light between these surfaces, the additional red makes it appear to glow - you do not want so much of that in the shader.
I believe it's in this thread. Have a read of it, anyway. The whole thing is worth getting your head around.
Im using poser pro 2012. Just wanted to know why this glow around V4 is happining. Also how do i prevent it?
