Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
I checked the figure and it appears that magnets have not been used.
For the morphs you'll need to search for the various morph dials and set their values to zero. Only difficulty here is that DAZ have set all of those dials to be hidden. Probably to prevent users from hurting themselves.
For the amount of poke through you may just want to use a magnet to expand the cloth slightly at those points. Or use the Morph Tool. I'd probably use the morph tool.
Or you could use Wardrobe Wizard to create an Inflate morph over the entire model.
Hope that gives you some pointers to a few of the options that spring to mind.
Quote - yes it conforms fine in Daz, i use 3.1,
although it seems choppy when i move the arms up and down.
The "choppiness" is probably your falloff zones. They likely need to be improved. It may just be that the falloff zones are causing that in Poser, though I've never seen that happen even with bad falloff.
Have you looked at the falloff zones? Your groups look good.
The "bulge" in the 2nd graphic with the arm up, is definitely the falloff zone.
![file_477488.jpg](https://live.cdn.renderosity.com/forum/threads/2842705/file_477488.jpg)
Ok, i made this little dress for the kids4 and conformed it using the figure setup tools. now i deleted the IK chains, but this is what hapens when i try to use it in poser.any idea what my problem is?
