Tue, Nov 5, 5:55 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 04 10:34 pm)
Subject: Glass?
meltz ( ) posted Thu, 12 January 2012 at 12:59 PM · edited Tue, 05 November 2024 at 5:53 PM
Ok i have a vial with liquid in it and also an eye dropper. I need to texture them as glass. How should i go about doing this in the matrial room? Any good advice?
Kendra ( ) posted Thu, 12 January 2012 at 1:40 PM
There should be some glass materials in the Basic Materials folder.
...... Kendra
markschum ( ) posted Thu, 12 January 2012 at 1:43 PM
I would check runtimedna freestuff. There were some materials there for glass. It depends on how realistic you want to be with reflections and refraction which will depend in part on how your stuff is modelled.
hborre ( ) posted Thu, 12 January 2012 at 1:48 PM
I would also do a forum search for Bagginsbill and glass and check the Node Cult @ RDNA for more forum information.
RobynsVeil ( ) posted Thu, 12 January 2012 at 2:36 PM
Glass that actually looks like glass is one of those rare and elusive things with our current renderer (Firefly), unfortunately. Depends on just how picky you are...
Metaphor of Chooks
meltz ( ) posted Thu, 12 January 2012 at 2:45 PM
Thanks i think i found some good stuff =-)
Miss Nancy ( ) posted Thu, 12 January 2012 at 3:04 PM · edited Thu, 12 January 2012 at 3:19 PM
this benzo uses several glass posersurfaces.  search this forum, "thin glass shader", user bagginsbill.  some of them aren't actually glass, but polycarbonate, however buyers prefer that the plastic look like glass AFAIK.
bagginsbill ( ) posted Thu, 12 January 2012 at 10:20 PM
meltz ( ) posted Mon, 16 January 2012 at 4:50 PM
What diffuse collor did you use for that BB if i may ask?
bagginsbill ( ) posted Mon, 16 January 2012 at 5:00 PM
There is no diffuse, so that doesn't matter. Diffuse_Value is 0 - no diffuse.
But it is white. White times 0 is 0 = black. So the effective diffuse color is black.
Miss Nancy ( ) posted Mon, 16 January 2012 at 8:30 PM · edited Mon, 16 January 2012 at 8:32 PM
use refract node if coloured glass desired ( ~ transparency colour).  however, no info yet on transmissive colour in poser, e.g. directional lite source passes thru coloured transparent posersurface, which acts as lite gel.
MistyLaraCarrara ( ) posted Thu, 19 January 2012 at 12:01 PM
i did a cararra 7 render a while back with a fishbowl, the props behind the fishbowl looked magnified through the 'glass'.  is it possible for PP12 to do something similar?
... still trying to find the render ...
MistyLaraCarrara ( ) posted Thu, 19 January 2012 at 12:41 PM
the radio behind the fishbowl is effected
bagginsbill ( ) posted Thu, 19 January 2012 at 1:01 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3817563
![](http://www.renderosity.com/mod/forumpro/media/folder_10/file_470832.jpg)
MistyLaraCarrara ( ) posted Thu, 19 January 2012 at 1:20 PM
Yayy.  Thanks.
