Forum Moderators: RedPhantom
Attached Link: http://youtu.be/2t3BUBV22u8
Hi Can this video help you for your question? I have just purchased Poser 9, so I would be interested to know what is the utility of weight mapping in Poser 9 version...I am completely beginner in Rendering painting.
IIRC, SmithMicro has a quick tutorial on transferring WM from figure to Clothing. And I believe that the assessment is correct, you would be able to transfer WM from character to clothing in P9. However, as stated before, you would not be able to create or modify any WMing in this version, only in the Pro series.
Actually, you can.
Download Antonia WM from DNA: the instructions are there in the PDF. They should apply to any figure.
Poser 9 should be able to transfer weight mapping, using the Setup Room or the Figure --> Copy Joint Zones from option. However Poser 9 will not allow editing of weight maps using the joint editor tool. That feature is unique to Poser Pro 2012.
Thank you for the replies from all of you. I think I need Poser Pro 2012, but it is $$$! I wonder if Poser 9 is good enough. Does anyone has experience of making the conforming clothing with weight map for the character with weight map, such as Antonia WM? Is it necessary to edit the weight mapping after it is transferred from the character to the conforming clothing? If not, I think I will go for Poser 9.
I gave up on making Antonia WM to work with DAZ Studio 4. In DAZ Studio 4, bones below the hip of Antonia WM work fine. The bend, side-side, twist for the chest bone of Antonia WM break the top.
The weight map transfer to clothing or other figures seems to work fairly well, but with some limitations. The transfer only works between actors with the same names in both figures. So if you have an atypical figure setup (say, a figure with an extra actor layer over one of the normal body parts), the maps won't be transferred to actors not found in the cr2 from which you're transferring the weights. As far as I can tell, this is true with any Wardrobe Wizard weight transfers, as well.
The transferred weights can also require extensive editing if the figure and the clothing are not cut similarly to one another. I've tried converting some pants for Antonia-Standard to Antonia-WM, but the shins on the pants are cut too high and the resulting weights are unusable.
I rather hope they'll refine the weight transfer processes a bit in future updates, or someone will write a utility which can more effectively project the weights from one figure to another in circumstances like these. I think the basic mesh comparison portions of Morphing Clothes could be effective for this (Dimension3D, are you listening?), but the comparisons would be too slow to be feasible without some kind of compiled program. Which is to say, the process probably isn't a good candidate for a pure Poser Python script, unless a .dll or .pyd is written to speed things up. :(
Quote - Thank you for the replies from all of you. I think I need Poser Pro 2012, but it is $$$!
There are options, Amy. Not huge, but definitely a bit better.
Yes, I saw a full version of Poser Pro 2012 on Amazon.com is even cheaper than the Poser 9. I wonder if it is from trustworthy or legal source. I'm not sure if they ship outside the U.S. Then, I have to figure out how much taxes/custom fee will be on the bill when I receive it.
I just found that DAZ offers a set of contents creation tools for DAZ Studio 4 for free! Now I have the DAZ Studio 4 Pro license key and some other tools waiting for me to download and try.
The introduction of weight map on both DAZ Studio and Poser seems to make it harder to share contents between the two apps.
I noticed that the current DAZ Studio 4 I have doesn't import the weight map created by Poser Pro 2012 correctly. I noticed it imports something because the result of importing Antonia WM to DAZ Studio 3 is not the same as DAZ Studio 4.
First thing I will try to make Antonia WM works in DAZ Studio 4 Pro. Maybe, I better post a message at DAZ forum to see if someone interest in doing that too.
HI Amy,
Amazon is a trustworthy source; they are the largest online retailer. They have sites around the world; try your country's suffix, such as http://www.amazon.co.jp/
You can export weightmapped characters from Studio in Poser format, but it cannot import Poser weightmapped figures.
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi all,
I'm considering to purchase the latest version of Poser to use the weight mapped characters and create clothing for them. I would like to know the proper way to make the weight mapped conforming clothing for the weight mapped character. I hope there is no need for JCM. Can Poser 9 transfer the weight map from the character to clothing?
