Tue, Nov 26, 6:06 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 5:46 am)
Subject: Ghostly renderings in Poser?
igohigh ( ) posted Tue, 28 August 2001 at 12:16 AM · edited Tue, 26 November 2024 at 5:19 AM
Hi, I'm trying to render a ghostly aperition with a 'see through' look but not getting anywhere. Any suggestions? I'm looking for the kinda look like the librarian scene in Ghostbusters and with a 'glowing look'. When ever I play with the transparancy levels Anton's robe becomes see through and that's not the effect I'm shooting for. I know post rending with layers would make it easy but then any type of animation would be out. Trying to get the effect in Poser it's self??
atthisstage ( ) posted Tue, 28 August 2001 at 12:32 AM
Did you try working with transparency and ambient settings at the same time?
rodpanther ( ) posted Tue, 28 August 2001 at 1:24 AM
Try these settings.
rodpanther ( ) posted Tue, 28 August 2001 at 1:26 AM
This is what it does so i dont know if thats the look you want. Just play about with the colours and make sure all settings are for all parts of model
amp-three ( ) posted Tue, 28 August 2001 at 2:58 AM
First of all, you can export it to Photoshop, and change the opacity level. That solves the "see-through" problem instantly. Then for the halo/ambiance, you can screw with colored lens flares, etc. I would just use the Eyecandy4000 corona filter for it, but the best things in life arent free, so... a3-ro2.gif
hauksdottir ( ) posted Tue, 28 August 2001 at 3:13 AM
Check out the "glass people" tutorial at this link. By making it not quite so transparent, you may get the effect you are looking for. http://www.geocities.com/bjshaven/Poser.html Carolly
Marque ( ) posted Tue, 28 August 2001 at 8:33 AM
And I would start off with just a sphere prop or something simple til you get the look you like, then write the numbers down and bring in your model. Always did like that robe. Marque
atthisstage ( ) posted Tue, 28 August 2001 at 10:34 AM
Guy, I think the problem is a little more complicated than that. What igo is looking for isn't just transparency; there's also that "glow" thing. And I don't know that Poser can really do that for animation. As drudging as it may sound, you may have to do it on a frame by frame basis in Photoshop.
igohigh ( ) posted Tue, 28 August 2001 at 10:45 AM
Here I used rodpanther's settings (actually this is where I started). The problem I get is in RED: it's too "glass-like" rather than a 'transparent ghostly aperition' (dead guy looking over my shoulder agrees ;-) I can play with positioning and lights and get close the effect but any attempt move or animate her and it's back to this (especially in the hip/body areas where the sense of depth goes right out the door. And the GREEN mark is where I try to make her eyes glow, trouble is that the traparancy/reflection combo shines the light 'inside' her (could probably fix that with two tiny lights and a gell filter - but would be easier/nicer in Bryce) My brain's been kicking around the possibilities of full-body transparancy maps.....maybe... (hmmmm, wonder if that librarian from Ghostbusters is looking for a new gig...)
rodpanther ( ) posted Tue, 28 August 2001 at 10:56 AM
Only thing would be too make the transparacy not so strong on the leg closer or something like that. Its gonna be a tough cookie to crack but patience reaps its rewards. It does look very ghostly though :) Also maybe change the light colours to a yellow or a light blue that might help a bit too
igohigh ( ) posted Tue, 28 August 2001 at 11:03 AM
Here's the same settings but with Reflection turned off on all. The effect I am trying to counter-act is the multiplying of light intensity 'inside' the model(s). I need the 'internal light' the cancel, not multiply......? I have EyeCandy 3.0 and some other filters but post-working several frames can be a real pain, especially if you don't want a lot 'light flickering' during an animation. Even more so if you attempt to reduce the colors for web posting.
rodpanther ( ) posted Tue, 28 August 2001 at 11:14 AM
try turning off the multiply through lights and multiply through object instead. Or turn them both off.
igohigh ( ) posted Tue, 28 August 2001 at 11:24 AM
Both are OFF in the last pic above :-( Gotta go fix the truck now but I think I'll try playing with the texture transparancies next. Looks like there's no way around it with the 'slider' settings....
ShadowWind ( ) posted Sat, 01 September 2001 at 10:05 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=79407&Start=1&Artist=ShadowWind&ByArtist=Yes
You can do this in Bryce via my Pepper's Ghost technique. I'm having trouble putting together a host for the tutorial at the moment, but if you email me or IM me with your email address, I will be glad to send the tutorial to anyone who needs it. PS: There is no setting that I could find that gets rid of the "X-Ray" transparency effect in Poser or Bryce. Because Poser does not have an external mesh only option, the internal meshes reflect when made transparent. For Poser only, unless you can find a standard glass material, Photoshop is probably your only hope. Included is the URL to the picture that demonstrates the Pepper's Ghost/Glass technique in Bryce.
