Mon, Feb 3, 3:48 PM CST
Subject: Creating a wall shape
Jack Casement ( ) posted Sat, 28 January 2012 at 3:13 AM · edited Mon, 03 February 2025 at 12:52 PM
Sorry if I seem to be dominating this forum with my novice questions but I am thirsting for knowledge.  Here's today's question.  I am tryin to create the inside of an art gallery and all I want is a blank wall at the back where I will hang a picture.  After many hours this beats me.  All suggestions gratefully received
erosiaart ( ) posted Sat, 28 January 2012 at 4:49 AM
you can cheat.. go to the freebie section.. you'll find lots of walls.. or even rooms.
if you don't want to cheat.. create a cube.. and flatten it.. and resize it... then raise it to where you want.. push it back towards the camera.. if it's just a wall you doing.. then you can texture it..add in skirtings etc. and your paintings, lighting..blah bah.
my though is..if you creating a room..you need three walls... go thru this post..it's a WIP project I started...
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3785923&ebot_calc_page#message_3785923
i hope that works... i'm still logged in..
thre are other posts too..if i remember. I remeber one i put up with the bathroom image that's on my gallery.
jack..this forum is here to help.. just drop any question you want. sometimes..i've put up a silly question..and after posting it..found my answer..and had to reply to my own post. :laugh:  stress not..
TheBryster ( ) posted Sat, 28 January 2012 at 9:55 AM
Good reply, Rosie!
kiwi_gg ( ) posted Sat, 28 January 2012 at 12:42 PM
2d planes work for walls as well, add mats as desired.
Cheers
GG
WHO said Kiwi's can't Fly ?????
Jack Casement ( ) posted Sat, 28 January 2012 at 1:09 PM
Many thanks for all your help and advice.  The attached image is something like what I was trying to improve.  Hopefully I will get better.
wildman2 ( ) posted Sat, 28 January 2012 at 3:58 PM
Make a cube,enlarge to fit your stuff,goto top mode move camera inside cube,shut sun off, use sky that has atmosphere haze and fog that is off.Put whatever lights you want inside cube.Render away.Floor can be a 2d plane or drop cube to just below ground plane.
"Reinstall Windows" is NOT a troubleshooting step.
IO4 ( ) posted Sun, 29 January 2012 at 1:43 AM · edited Sun, 29 January 2012 at 1:48 AM
Yep, there is more than one way to do it as the posters have suggested. I always use a flattened cube, get it to the size I want then copy and paste it to make the remaining 3 walls of the room, and poisition them (using top view is good for that).
Don't forget to resize the texture accordingly- if you have stetched a plane or a flattened cube the texture may appear stretched also, and that may not be what you want, especially if you want to create more realism.
For example, in your image you posted you could try reducing the scale of the brick texture along the 'x' axis (depending how your camera is wall is placed in the scene - it might be the 'z' axis). If you're not sure how to do this see the screen shot above. In the Materials lab you click the radio shown (first one on the top) which will open the Transformation tools as shown in the lower image. The scaling tools are the top set.
The mapping mode chosen can also be important (see my tips on that  here)
I hope that helps.
Beginners tutorials for Bryce
Bryce Arena
karl.garnham1 ( ) posted Mon, 30 January 2012 at 4:26 AM
You can also make a wall using lots of individual pieces (this is good if you want to blow it apart it won't do that on a single cube)
here is an address to a forum called Brycetech it has lots of cool bryce effects you can learn
http://brycetech.daz3d.com/
You can also do lots of other cool effects like blowing space ships up and stuff.
Hope this has helped a bit.
Karl
UVDan ( ) posted Wed, 01 February 2012 at 1:54 AM
Forum Moderator
Check out that Brycetech link above. That has helped me so many times over the years.
