I'm not familiar with the product you are using to make the INJ, you might try contacting its author. If this is just for your own use, not for distribution, you could try using svdl's free "SpawnCharacterP6 update" to make the INJ. It's simple to use, and the resulting INJ morph should be WYSIWYG (so long as no scaling is involved). Because the INJ produced via SpawnCharacterP6 contains true morphs (deltas, not dial-spins), you can't distribute them if any copyrighted morphs were used.
Thanks for that. I contacted them and hope to find out what I am doing wrong. I have got the SpawnCharacterP6 update downloaded, did it before, but can't get it to work, it says it needs Poser 6 SR2 or later, and even though I am using Poser 8 it just doesn't open up, hence I thought I try to other INJ builder. will keep trying :)
IIRC, there was a Python script change with P8/PP2010, that may explain why it is not working.
Now I have tried running the Advance Figure Randomizer in PP2010 and it appears to work without any problems for face morphs. Are you sure that you haven't selected other body parts when creating you INJ? Also, if you want to include other dial-morphs, you do need to specify that when creating the INJ/REM files. Otherwise, you wiil wipe out and remove previous morphs. Maybe if you outline your workflow through screencaps, we might notice something you are overlooking.
And, as les posted, you can try contacting them @ RDNA. They do have an excellent track record with customer service.
I got EXACTLY the same problem when I was making my Asharru character. Turns out I had forgotten to apply that morph to one of V4's empty channels... Let me try to explain:
In your injector, you have to find where your morph begins. If it goes something like this:
actor head:1
channels
targetGeom YourMorphName
name YourMorphName
initValue 0
forceLimits 1
min -100000
max 100000
trackingScale 0.02
((etc))]
then you'll have problems. It won't know in which dial it should insert the morph, and it will deform. V4 comes with empty dials so that you can insert custom morphs into them, there's PBMDC_00 to PBMDC_50 (will show up under Daz Morphs in V4) and PBMCC_00 to PBMCC_50 (will show under Community in V4). So you'd have to do it like this:
actor head:1
channels
targetGeom PBMCC_30
name YourMorphName
initValue 0
forceLimits 1
min -100000
max 100000
trackingScale 0.02
((etc))
That way, it'll use the PBMCC_30 channel, but to the user it'll appear as YourMorphName. You'll also have to change that in your hide, unhide and rem files, if existant, with the same channel name.
Most injection making tools give that option and will do that for you, though. I haven't used the one you mentioned, but looking at its page's images... it prompts you with a "select channel" upon saving, you should pick one of the PBMCC_ there (try for a random number, avoid the first numbers, because it'll replace anything already in the channel you chose - and a lot of people use low numbers, then your user wouldn't be able to mix those two faces).
Also, something to remember: don't INCLUDE the morphs++ shapes into your custom morph. They're not a Merchant Resource. Any use of the morphs++ has to be in the form of mere dial values, so that your end user would need to have bought the Morphs++ pack too.
Feel free to call me Ohki!
Quote - i use the "OLD" method for single item morphs, export to .OBJ and import as MT, not as hi-tech but quite effective, seldom any probs , may want to export neck MT also in this instance as a seperate .OBJ to make sure the seams match.
MT=Morph target... just in case :O)
JAFO
Not very doable if the person intends to distribute the character at all.
![file_478376.jpg](https://live.cdn.renderosity.com/forum/threads/2844198/file_478376.jpg)
Hi, hope someone knows what I am doing wrong….I created this face-morph and are using this to export the morph: http://www.runtimedna.com/Advanced-Figure-Randomizer-and-INJ-Builder.html
However when I then try to import it into an unmorphed V4 I find that while the head is ok, however the neck plays up as shown in the pictures…. Sorry using my laptop to make the circles and not the most steady hand….. I created the morph over and over exported it via the INJ Builder, still it plays up at the neck. Even when I try and create it including the neck, then nothing works. I don’t know what I am doing wrong. I normally create my morphs with the Morph+++ dials, but wanted to add some of the morphs I bought with it, so I need to somehow export the morph and create the INJ/REM file (one that loads instantly and doesn’t need for the dial to be used after injection) but keep hitting a brick wall with it… any idea what I am doing wrong…. Oh and I am using poser8.
Any help will be much appreciated.
Fred :)
