Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
You can't force Bryce to do anything really.. I have play a lot with the Distance rendering, and I think its a WIP for Corel. I think they need a patch to get rid of many little glitches. I have done 4 distance renders and never noticed that fact, but I went back and looked at some of mine and I see what you mean.... I played with it a little to see if I could get an results that were exceptable. If I get your question you want the "foreground tree" to have a transparant look to the leaf. The only way I was able to get that look somewhat was to really make it transparant and add a little bit of light near the object. Hope that helps..
Hi, community... The distance renders I do from Bryce 4 do not use the transparancies of the materials within the scene... this means that I have to spend hours touching up the distance render to get rid of the "halo" of clarity around each leaf (if I have a foreground tree). Is there any way to force bryce to look at the transparancies of object when doing a distance render?? Help!
