Thu, Nov 28, 2:29 AM CST
Subject: Shadow Strength
MNArtist ( ) posted Tue, 28 February 2012 at 8:09 AM · edited Wed, 24 July 2024 at 8:15 PM
I've been trying to find info on this, and can't locate anything.
What drives the ability to change the shadow strength under a light parameter? This is for an infinite light. It seems like sometimes I can change it, and sometimes it's locked at 1.000, and no matter what I change under Properties, it can't be increased. Then other times it changes. I can't figure out the "rhyme or reason" to this. Does anyone know what the "rules" are for this? It doesn't seem to matter if I'm using Ray Trace or Depth map, though for the most part, I'm using Ray Trace shadows. Also, changing the blur radius doesn't seem to impact the ability.
I'm on Poser9 on Windows.
Any info is appreciated.
Plutom ( ) posted Tue, 28 February 2012 at 8:18 AM
It may be this:  right side of shadow thumb wheel small arrow-click on it and check your settings--ensure that the minimum is not set at 1.  Normally minimum is set at 0 and maximum is set at 1.  If both of the values are the same, the dial has no effect.  Jan
MNArtist ( ) posted Tue, 28 February 2012 at 8:24 AM
Thanks, Plutom. I have done that. I guess I was just trying to figure out why the default limits set as they do.
Plutom ( ) posted Tue, 28 February 2012 at 8:33 AM
Is it working the way you want it to now?
Probably because the limits of 0 and 1 are the ones that 98 percent of the folks use.
I've never brought shadow values below below 0 which could bring very interesting results.  BB had an explanation of the results, but I forgot. Hmmm going to give it a try and see what happens....Jan
MNArtist ( ) posted Tue, 28 February 2012 at 8:43 AM
Yeah, I'll be able to get there this way. Just so strange the way the limits change. Really appreciate your help!!
Plutom ( ) posted Tue, 28 February 2012 at 8:46 AM
Gad, it has happened to me more times then I can count.. Jan
MistyLaraCarrara ( ) posted Tue, 28 February 2012 at 11:04 AM
negative shadow gives you flashlight (electric torch) glow.
Plutom ( ) posted Tue, 28 February 2012 at 12:36 PM
Hi Misty, yeah, it sure does...tried it, additionally, boosting shadowing beyond 100 percent gives you that Grim Reaper type of blackness....Jan
