Sat, Jan 11, 6:16 AM CST
Subject: Vampires in My Runtime
shorterbus ( ) posted Thu, 01 March 2012 at 11:27 AM · edited Sat, 11 January 2025 at 6:15 AM
I'm trying to do a reflection of V4 in a mirror, but nothing shows up in the render - no reflection is cast. P-2012, raytracing checked, reflective material in the mirror, firefly render, IDL and a single specular light. What gives?
shorterbus ( ) posted Thu, 01 March 2012 at 1:00 PM
I'm checking my breath and sniffing my armpits.
LaurieA ( ) posted Thu, 01 March 2012 at 1:03 PM · edited Thu, 01 March 2012 at 1:03 PM
Try this for your mirror material. And make sure you have some raytrace bounces in your render settings ;).
That material was posted by BB awhile back.
Eric Walters ( ) posted Thu, 01 March 2012 at 1:22 PM
How many bounces? Do you have transparency? It is 4 for reflection through transparency.
Quote - I'm trying to do a reflection of V4 in a mirror, but nothing shows up in the render - no reflection is cast. P-2012, raytracing checked, reflective material in the mirror, firefly render, IDL and a single specular light. What gives?
shorterbus ( ) posted Thu, 01 March 2012 at 1:28 PM
Thanks Laurie, I'm giving it a try now.
shorterbus ( ) posted Thu, 01 March 2012 at 1:30 PM
Eric, I'm trying Lauie's settings, so no transparency. I've got it set for 8 bounces. (?)
hborre ( ) posted Thu, 01 March 2012 at 2:06 PM
Visible in raytracing?
LaurieA ( ) posted Thu, 01 March 2012 at 3:01 PM
8 bounces is too many. 2 should be sufficient since the glass is a mirror and not transparent ;).
shorterbus ( ) posted Thu, 01 March 2012 at 3:29 PM
Okay, I thinkI have it figured out. The angle of the mirror - though right in front of the character I was trying to reflect, was wrong. Had to turn the mirror to a much less than obvious angle. At least it is working in test renders.
aRtBee ( ) posted Sat, 03 March 2012 at 3:15 PM
is this just an angle-of-incidence = angle-of-reflection thing? Then the normal of the mirror should point to something in the middle of Vicky and the camera. Just try it at home, with a real girl and a real mirror. It's basic optics / geometry.
As the material is concerned, I don't know why one should have reflection = 1  AND Specular = 2 as all channels together should not exceed 1 in the first place. I would say: reflection = 0.95 + specular = 0.05 and the reflection color might be a bit cyanic dus to the glass (again, try this at home; put a colored object in front of a mirror and compare the colors).
SteveJax ( ) posted Sat, 03 March 2012 at 3:40 PM
Depending on how many "Mirrors" you use your bounces should be set to between 2 and 5. A Room with four walls of mirrors would be 5 bounces. Two walls is 3 bounces. etcetra... this way they reflect not just the scene but also each other.
Eric Walters ( ) posted Sat, 03 March 2012 at 3:47 PM
WAIT! Are you saying that Vicky is not real??
Interesting details- does the glass absorb some of the red? I'd not noticed that.
Quote - i Just try it at home, with a real girl and a real mirror. It's basic optics / geometry.
