Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 2:19 pm)
Material requires P9/PP2012 - don't bother downloading if you don't have that. It uses scatter.
it looks a little phallic to me, but i haven't gone out much lately
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
it's that dash at the tip of the sphere --
i can't imagine how to map a sphere or easter egg, without seams resulting with tiling jpgs;
or geosphere without a 'horizon' line.
i had to make a special trip to the vending machine to sublimate creeps with a Twix bar.
I didn't know how creepy until I went to the full size picture. yiiiikes. Downloading.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
My PC is not high-end and my render was a few minutes. I have an Intel I7-860.
multiple IBL lights?
Its a just freebie light set I've downloaded at some point that I used there... I'd have to check the source. So not sure why 3 IBLs are used... or checked if all 3 do actually benefit the result in some way.
I only noted there were 3 IBLs when I was posting that in fact...
I will experiment some more there... ;-)
Would a single IBL usually be enough?
If you're using my EnvSphere and IDL is enabled, IBL does nothing at all. When IDL is enabled, IBL is like an infinite size EnvSphere. Since the actual EnvSphere you're using is not infinite, it is closer than the virtual one associated with IBL.
If you disable IDL, then IBL will change modes and illuminate everything, even things inside a box or sphere.
i've always thought of IBL light as a universal light and aiming it tells firefly where to gather the ambient shadows.
Quote - If you're using my EnvSphere and IDL is enabled, IBL does nothing at all. When IDL is enabled, IBL is like an infinite size EnvSphere. Since the actual EnvSphere you're using is not infinite, it is closer than the virtual one associated with IBL.
Ah, cool - I see now. I wondered about that... thanks for illuminating me :-)
So using that IDL setting with your BB envsphere, should I therefore get the same result with just having the spot and the point light in that scene... without those IBLs being added at all?
Am I understanding that much correctly?
Please click for full size.
