I meant to say adding material zones, I might give it a try tomorrow and see how it goes. If I do this, will I just need to make the cr2 file point to the object with the new material zones for it to work properly? Thanks :)
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
Quote - I meant to say adding material zones, I might give it a try tomorrow and see how it goes. If I do this, will I just need to make the cr2 file point to the object with the new material zones for it to work properly? Thanks :)
Yes, use the figure's object file, add the material zones, save under a different name. Copy the original cr2, name it something different and point it to your new object file. Set everything up in Poser and resave to the library.
Thanks ;o)
System Ram: 8GB
Anceata-Semil was pretty easy to add new zones too, Nursoda has everything seperated, so all I had to do was select the parts and add the new material zones :) Hope his others are as easy to do!
System Ram: 8GB
Thanks Gareee :) I got the e mail too, there were some nice changes to her.
System Ram: 8GB
Nursoda has some new freebies at his site :) http://www.klopfholz.de/
System Ram: 8GB
Okay, there is a problem when I add the new material zones, when I save the new figure to the library, or as a PZ3 when I load it into poser, it has added back some of the old materials on top of the new ones I made. Now I am stumped on how to do this :(
System Ram: 8GB
Thank you both, I think I got it fixed now :)
System Ram: 8GB
Has anyone remapped any of Nursoda's characters, to work better with ezskin? Most of them don't have seperate material zones for teeth lips etc.
System Ram: 8GB
