Fri, Jan 10, 3:42 PM CST
Subject: Vue 10 Infinite - Build 10008535 - BETA
  • 1
  • 2
Mazak ( ) posted Thu, 10 May 2012 at 7:10 AM
Vue 10 Infinite - Build 10008910 - BETA The following is a list of bug fixes and improvements included in this update:
Publishing Date: EEF 05/07/2012
  • Fixed the position of cloud layers when reloading scenes or atmospheres (X,Y coordinates were reset to 0,0).
  • Fixed potential crash in the atmosphere thread, after a render in top or front view.
  • Fixed potentially wrong automatic clipping planes when the scene containts displaced objects.
  • Fixed a possible crash in the material editor, when switching from the child of a mixed material to another material.
  • Fixed the parameter publishing tab which was not refreshed when changing the selected material layer.
  • Fixed a potential crash with plants, when the material uses Fade Out.
  • Improved keayframe animation system.
  • Fixed EcoSystem instances that could be dissociated from their underlying object on Undo.
  • Improved distributed rendering to avoid small differences between local and remote rendering tiles.
  • [MacOS] Fixed a possible crash when adding a new material layer (in really specific circumstances).
  • [MacOS] Fix possible, rare crash when using expandable button controls.
  • [MacOS] Fixed huge memory peaks at the end of renders (especially with many multi-pass buffers).
  • [RenderNode] Improved compatibility of modifed .veg files when the content is not installed.
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Wed, 16 May 2012 at 4:35 AM
First 10.5 Update is here :)
Vue 10.5 Infinite - Build 10501386 - BETAThe following is a list of bug fixes and improvements included in this update:
Publishing Date: EEF 05/14/2012
  • Fixed distributed rendering problem (difference between local and remote rendering tiles).
  • Fixed potential OpenGL errors when Vue is creating the EcoSystems specimens.
  • Improved Pan Camera icon response (under scene preview) which was too fast.
  • Fixed a potential crash when editing a material (with automatic material preview rendering on).
  • Removed useless separator in material contextual menus.
  • Fixed published tabs which were sometimes not editable (volumetric or EcoSystem materials, with animation).
  • Material Editor/ EcoSystem Painter: Completed tooltip to explain the meaning of EcoSystem display quality.
  • Fixed updating of the color blend parameters in the material editor.
  • Material EcoSystem Editor: fixed a small UI glitch (right of the tab).
  • Fixed potential issues when populating spline effects involving the spline's own geometry (Influence ratio 0% for spline, but plenty of instances on it).
  • Fixed a crash when previewing a Dynamic Population using EcoSystem Stacking.
  • Fixed EcoSystem Stacking Limit: was not well taken into account during population.
  • Fixed default name and description when saving a single material layer from material editor.
  • Added a message to avoid losing user modifications or animation with Plant/Rock variations from .vob files (Wue will offer not to regenerate variations if the plant/rock was modified).
  • Fixed a possible crash when closing Vue with material summary open, and a material editor previously opened from the summary.
  • Fixed Text object saving which did not work if the text had several lines.
  • Fixed Macros using EcoSystem painter.
  • Fixed Effect on 2D brush flow behavior.
  • [MacOS] Fixed a possible crash when adding a new material layer (for specific configurations).
  • [MacOS] Fixed possible, rare crash when using expandable button controls.
  • [MacOS] Fixed memory peaks at the end of renders (especially with many multi-pass buffers).
  • [RenderNode] Fix potential crash/hangup at exit (related to license server disconnection).
Mazak
Google+ Bodo Nittel
ShawnDriscoll ( ) posted Wed, 16 May 2012 at 11:06 AM
They went back an update for Vue 10 Infinite.  Someone give the e-on webmaster a whack.
  • 1
  • 2
