Wed, Dec 4, 8:56 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 3:06 am)
Subject: Problems with Poser Pro 2012
Taylor-Made ( ) posted Sat, 12 May 2012 at 9:52 PM · edited Wed, 04 December 2024 at 8:53 AM
I installed Poser Pro 2012 when it first came out.  I run it on an i7 computer with a Nvidia FX3800 and 24 gigs of ram.  When i first installed it (64bit) it was running on Vista Business.  I never had a problem.  Sometimes it took a while to go back to preview after a render, but the serevice pack 2 took care of that.
Recently I had to upgrade to Windows 7 Professional to upgrade my video editing program.  I had to do a clean install of Windows.  After the install, I installed all my programs.  Everything (Avid, Vue, AfterEffects, Photoshop, Illustrator) works fine - except Poser.  For the first time since I began using Poser (Poser 7) I'm having nothing but trouble.  I hangs up every two minutes.  I get a white screen, or a washed-out screen and everything freezes.  Going between preview and reneder is a major undertaking.  If it will even do it, it takes five minutes.  Usually it causes the application to fail.
I just tried to render a PNG amimation sequence - something I do almost everyday without any problems.  Now a few frames may render, then I get this message:
The instruction at 0x407c3e referenced memory at 0x000001a0 memory could not be written.
I tried it with and without the service pack 2.1 and it makes no difference.  My always dependable Poser has failed me for the first time.  It is basically impossible to work with the program in its current state.  I've done dozens of animated cartoons with Poser and now I can't even get more than five frames to render.  I'm renedering in Firefly with the same settings I've always used.
GeneralNutt ( ) posted Sat, 12 May 2012 at 10:06 PM · edited Sat, 12 May 2012 at 10:06 PM
Video Card Drivers?
LaurieA ( ) posted Sat, 12 May 2012 at 10:15 PM · edited Sat, 12 May 2012 at 10:17 PM
Where did you install it and do you have UAC turned on? I run it on Windows 7 Ultimate and it runs fine. I have UAC turned off and I didn't install it to Program Files.
bagginsbill ( ) posted Sat, 12 May 2012 at 10:47 PM
Video card driver.
Taylor-Made ( ) posted Sat, 12 May 2012 at 11:38 PM
If it's the driver, I'm in trouble.  Avid has to run on a specific Nvidia driver.  It was the same situation with Vista and Poser worked fine.  If this updated (Avid) driver isn't compatible with Poser, then my animating days are over.  I make my living editing and relax with Poser projects.  Life is never easy.
hornet3d ( ) posted Sun, 13 May 2012 at 3:55 AM
Quote - Where did you install it and do you have UAC turned on? I run it on Windows 7 Ultimate and it runs fine. I have UAC turned off and I didn't install it to Program Files.
Same thing here, Windows 7 Ultimate and no issues, which I guess supports the video driver suggestion.
vilters ( ) posted Sun, 13 May 2012 at 4:47 AM
Must be video card driver.
What happens when you run Poser in SreeD?
What are your hardware settings? Render => Preview tab?
In the end? Only solution will be to upgrade your video card drivers.
shvrdavid ( ) posted Sun, 13 May 2012 at 8:14 AM · edited Sun, 13 May 2012 at 8:16 AM
There is a new driver for the Quadro's, but it does not work right on my workstation either.
You might try that and see if it works for you, this is a stability driver, not a performance one. It has increased virtual space, etc...
http://www.nvidia.com/object/quadro-tesla-win7-winvista-64bit-296.70-whql-driver.html
shvrdavid ( ) posted Sun, 13 May 2012 at 8:20 AM
You might want to clean out the drivers you have in there now as well.
phyxion.net/item/driver-sweeper.html
Taylor-Made ( ) posted Sun, 13 May 2012 at 10:39 PM
I would update the drivers if I could.  Avid will only work with an older legacy driver.  If try to open Avid with the updated driver, all I get is an error message.  As I make my living as a video editor, I can't afford to lose my editor to make Poser work correctly.  Buying another powerful computer (I do render heavy animation) just for Poser just isn't an option.  The fact that After Effects, Photoshop, Blender, and Vue all run fine on my system with no problems makes me wonder if the driver is the culprit.  As I said, if it is the driver, then my Poser days are over.  A bummer since I just shelled out a bundle for PoserPro 2012, and really liked it when it was running great on Vista.  My Vista system also required an older legacy video driver to run my old Avid system.  No problems then.  If Poser ran fine with even an older video driver than I have now, it may be the Poser - Windows 7 combo that is fouling things up.
Thanks everyone for the help.
Teyon ( ) posted Mon, 14 May 2012 at 7:58 AM · edited Mon, 14 May 2012 at 7:58 AM
Have you tried switching to SreeD as a display option within Poser? That may allow you to use Poser without updating your drivers.
Taylor-Made ( ) posted Mon, 14 May 2012 at 9:09 AM
I'll give it a try when I get home tonight.  Thanks for the help.
lmckenzie ( ) posted Tue, 15 May 2012 at 9:50 AM
Maybe you can dual-boot with another install of 7 or Vista - a bit inconvenient but it should work. I'm not sure if there's a way to use an alternate hardware profile to run a different driver for a device.
