Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
First - ZBrush doesn't make material groups. You can paint polygons with materials but you can't group them the way you would in say, UVMapper, as ZBrush does NOT have a way to name groups.
Second - the MatCaps in ZBrush don't translate to other applications. Many applications support ZBrush's PolyPaint feature - where you assign a COLOR to a polygon - but the MatCaps are NOT transferable.
Hope that helped.
Hi there,
been playing with sculpting and in zbrush and attempting to export a model to Poser, but I can't work out how to carry over material groups?
The closest I've found is exporting the polygroups and then manually assigning materials to the groups inside Poser?
Is there a way to directly have Poser recognsize Zbrush material groups? Also is it the same work flow for DazStudio?
thanks in advance :)
