Sat, Jan 11, 12:39 AM CST
Subject: Creating primitives in Poser
Cyberdene ( ) posted Thu, 24 May 2012 at 8:40 AM · edited Sat, 11 January 2025 at 12:39 AM
How do you create primitives in Poser 7 like you would do for programs such as ZBrush and Maya?
mitzi-CG ( ) posted Thu, 24 May 2012 at 8:50 AM
All versions of Poser have a folder called "Primitives" under Props.
Just pick out the one you want to use
Teyon ( ) posted Thu, 24 May 2012 at 8:50 AM · edited Thu, 24 May 2012 at 8:51 AM
AH! Beat me to it. :)
Cyberdene ( ) posted Thu, 24 May 2012 at 8:58 AM
Yeah but those are basic primitives. I'm talking about  the more high detailed  ones that Maya has. Maya has more primitives than Poser does. I was aware of those primitives but I'm talking about creating things like a cylinder block,  etc. I mean I do have Maya, just not on my machine. Trying to percerive memory usage so I wanted to know if its possible to just custom make primitives from scratch and if so what sort of tools would anyone recommend using for it. Sorry if I wasn't clearer about that the first time.
SamTherapy ( ) posted Thu, 24 May 2012 at 8:59 AM
But to answer the OP's actual question, you can't without a lot of fiddling around.  Poser isn't made for creating models of any kind.  You'd be better off using ZBrush, Maya, Max, Blender, Wings, etc for that kind of thing.
The fiddling around method involves using Poser's grouping tool, exporting bits of existing models and reimporting them.  Poser does not have any built in modelling capabilities.
Cyberdene ( ) posted Thu, 24 May 2012 at 9:04 AM
....Then what the hell is Poser used for????? I mean I already know that its animation tools  aren't that good. But I've seen some people do good with it, not as good as Maya but still a little better than what I could possibly do in terms of animating...Poser sounds quite disappointing when you said that. I mean I use it mostly for rendering and such. But I know that some people will just go into photoshop or some other program and then they'll just pretty much do all the harder work that can't be done in Poser. But it makes me curious as to what people use to design and create the figures and props used in Poser including Daz?
shuy ( ) posted Thu, 24 May 2012 at 9:06 AM · edited Thu, 24 May 2012 at 9:08 AM
For this purpose Wings would be the best. You do not need software with advanced options.
Wings is free, is small (I do not remember but about 10-20MB) and what is most important Wings is very easy.
BTW - Sam I think that you can model something in Poser. I never tried, but I think that you can weld one sided square. It would be difficult and useless but I think possible.
Quote - ....Then what the hell is Poser used for????? I mean I already know that its animation tools  aren't that good. But I've seen some people do good with it, not as good as Maya but still a little better than what I could possibly do in terms of animating...Poser sounds quite disappointing when you said that. I mean I use it mostly for rendering and such. But I know that some people will just go into photoshop or some other program and then they'll just pretty much do all the harder work that can't be done in Poser. But it makes me curious as to what people use to design and create the figures and props used in Poser including Daz?
Poser is a toy.
cspear ( ) posted Thu, 24 May 2012 at 9:12 AM
Quote - ... it makes me curious as to what people use to design and create the figures and props used in Poser including Daz?
Well, not Poser because it's not a 3D modelling app. Modelling would typically be done in the programs you mentioned, imported into Poser and (if required) rigged.
There's no point moaning about Poser's lack of features compared to (say) Maya, because one costs a couple of hundred dollars and the other a couple of thousand.
Why not try Blender or Wings3D? They're both free.
PoserPro 11 - Units: Metres
Adobe CC 2017
PhilC ( ) posted Thu, 24 May 2012 at 9:28 AM
I have a hammer but its totally useless. Every time I try and drive a nail it just bends them over, plus it wont drill holes.
LaurieA ( ) posted Thu, 24 May 2012 at 9:40 AM · edited Thu, 24 May 2012 at 9:42 AM
Quote - ....Then what the hell is Poser used for?????...
It's used to pose and render figures. What did ya think? And if you have Maya, what do ya want with it anyway? Aren't you supposed to be makin your own figures or something?
LaurieA ( ) posted Thu, 24 May 2012 at 9:41 AM
Quote - I have a hammer but its totally useless. Every time I try and drive a nail it just bends them over, plus it wont drill holes.
charlie43 ( ) posted Thu, 24 May 2012 at 9:46 AM
Now that's funny - and you hit the nail on the head, dear Phil, if you read between the lines...
C~
EnglishBob ( ) posted Thu, 24 May 2012 at 9:51 AM · edited Thu, 24 May 2012 at 9:52 AM
Attached Link: http://www.sharecg.com/v/6124/View/5/3D-Model/Enhanced-Primitives
As well as the page I linked to, this author has more helpful stuff than anyone could use.
monkeycloud ( ) posted Thu, 24 May 2012 at 9:52 AM
They're a bit more expensive, but have you tried using a nail gun PhilC?
...if that doesn't work, then screw it.
hborre ( ) posted Thu, 24 May 2012 at 9:57 AM
@EnglishBob: Those primitives look great, however you will need to search the site to find the Poser compatible content.  Those in the link are exclusive to Bryce and cannot be imported into Poser as is without converting them first.
monkeycloud ( ) posted Thu, 24 May 2012 at 10:01 AM · edited Thu, 24 May 2012 at 10:03 AM
In terms of modelling, Hexagon is also still free at present. Personally I've found it quite useable, on OS X.
So regardless of which one you end up using, assuming you don't have access to Maya at all times, on all computers(?), its probably worth snapping that up too...?
EnglishBob ( ) posted Thu, 24 May 2012 at 10:04 AM
Attached Link: Spacebones' ShareCG downloads
> Quote - Those in the link are exclusive to Bryce and cannot be imported into Poser as is without converting them first.
Oops, my bad. I knew I had loads of bits 'n' bobs from Spacebones and just posted the first page that had the word "primitives" on it.
cspear ( ) posted Thu, 24 May 2012 at 10:21 AM
And those of us with Poser 8 and above will have checked out Dimension3D's primitives (which ship with the program, in Props > Primitives > Morphing Primitives in P9 and PP2012) - quite a few of which will morph - haven't we?
Incredibly useful, they can be.
Adobe CC 2017
SamTherapy ( ) posted Thu, 24 May 2012 at 3:55 PM
Why on earth would anyone with Maya want or need Poser?
RedPhantom ( ) posted Thu, 24 May 2012 at 3:55 PM
Site Admin
IIRC geep built a house with poser, or at least a room.
Gremalkyn ( ) posted Thu, 24 May 2012 at 4:21 PM
Quote - IIRC geep built a house with poser, or at least a room.
A couple years ago, in Poser 5, I built a no-frills octagon arena (no roof so I could shoot from above), stands for holding spotlights, spotlights (with "real" lights set inside so the prop worked like a light), and what sorta kinda looked like a movie camera for a behind-the-scenes shot of a catfight video.  No idea where I named or put the final scene, but I am sure I saved it on the old computer somewhere.
No idea how I would make something new, but it is fairly easy to modify the primitives in the Props library to end up with something else.
nruddock ( ) posted Thu, 24 May 2012 at 5:39 PM
If you want to create geometry using only Poser, then you need to use Python.
For non-programmers, using a modelling app is generally easier.
lesbentley ( ) posted Thu, 24 May 2012 at 5:43 PM
I tried building a house with Poser. They are much lighter than bricks, but very much more expensive.
Gremalkyn ( ) posted Thu, 24 May 2012 at 6:00 PM
Quote - > Quote - IIRC geep built a house with poser, or at least a room.
"Virtually" impractical. :D
Probably better looking than some in my neighborhood, though.
Miss Nancy ( ) posted Thu, 24 May 2012 at 6:21 PM
it's possible to do alot of modelling in poser, if morphing(waves/magnets/et al.) qualify as modelling, and cage even wrote a UVmapping script for poser IIRC.  the poser group editor has some functions that are similar to modelling.
lmckenzie ( ) posted Thu, 24 May 2012 at 6:32 PM
So install Maya and make some primitives. IIRC from your previous posts, d___ing with Poser seems to be holding you back from learning what would seem to be a more powerful and certainly lucrative application. You're always going to be disappointed in Poser  comparing the two. If you haven't figured out "....what the hell is Poser used for?????" by now, give it up.
moriador ( ) posted Fri, 25 May 2012 at 12:04 AM
Quote - Why on earth would anyone with Maya want or need Poser?
So they can post about how awful it is in the Poser forums?
parkdalegardener ( ) posted Fri, 25 May 2012 at 6:00 AM
Both. It was me he was teaching this to.
pdg
SamTherapy ( ) posted Fri, 25 May 2012 at 12:42 PM
Well, my first answer still stands.  You can't model in Poser without a lot of fiddling around.  Better to use a proper modelling app.
For example, I can do some great, really intricate drawings on an Etch A Sketch but why on earth would I want to?  There are far better tools for the job.
bagginsbill ( ) posted Fri, 25 May 2012 at 10:41 PM
Blackhearted ( ) posted Sat, 26 May 2012 at 12:13 AM · edited Sat, 26 May 2012 at 12:13 AM
primitives are primitives... ie: cube, sphere, cylinder, torus, plane.
what else do you need? a teapot? a Bryce dolphin? :D
if you want more complex objects they are no longer 'primitives'.  but there is nothing stopping you from importing whatever free 3D meshes you want into your Poser/Props/Primitives folder and then using them.
BB: nice job with the primitives, you have way more patience than i do :)
