Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 6:38 am)
Appologies, I was a little vague.
I need a cr2 cos I want to use it for rigging. When you add the cr2 to a new figure in the pose room, it comes in at zero, even if you posed it before saving the cr2.
It's not a common use I know, I would only use it under certain circumstances. Mosly when the zero pose make it tricky to model a garment. The most obvious usage being shoes of course. Even if a figure has flat feet at the zero pose, that's not helpful when modelling heals. And of course v4's bent feet don't help much either :)
I'd like to be able to model a shoe as it would fit a posed foot, if that makes sense.
Even some regular cloth garments would benefit from being modelled in a posed position.
All things are of course doable when making cloth/shoes on a zeroed figure. It's just that sometimes it would be easier to make them posed.
John.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Question just to be sure.
Actually, you want to export a Posed figure from poser to model shoes or clothing around.
Correct?
File, export, => Wavefront obj, select what parts you want exported but do NOT vink export as morph target.
The obj or parts of it you selected will be exported in their posed position.
And you can import those in your modeling app to model around.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
You are better off posing the foot the way you'll want it for the shoe, exporting those feet to model around (but save the foot pose in Poser for later.
Refer to this thread (which helped me a lot) :).
Thanks Laurie
I fink I get it, I will experiment lots :)
John.
Hi Guys
This is going to sound odd I know but it's driving me a little nutty.
Can you pose a figure (eg V4), save a new cr2 such that when the figure loads back in again it is posed, and not at the Zero pose?
I hope that makes sense.
John
