Been waiting for that. Thanks.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
can it make james's feet hit the steps walking, without collapsing into the ragdoll?
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Can you pls explain a little more what you mean by this and I'll try to respond in full? Foot collisions should not result in a "Hit" for "Keyframed until hit" animations.
To everyone else.....pls let me know what tutorial video's you'd like. I need to do a few on the new fixed, ball and hinge joints, but let me know if there are specific things you'd like covered.
Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
I asked face-off recently about soft body physics, is it possible in Poser, ever. He asked me to elaborate on what I meant by that, so here goes:
It is the same as your current product, but when objects collide, they deform to a lesser or more degree based on rigitity controls you set for them. For instance, a jello-filled cube falling on the floor would self-deform as it hits and bounces, compressing and deforming, then reasserting its shape over several cycles of self-decompression until it stops.
http://www.youtube.com/watch?v=btTmXAl2Ghs
Paul, congratulations on the release of your new version of Poser Physics!
::::: Opera :::::
Attached Link: youtu.be/ThJwSEjJxxY
Thanks for the link Opera. I'll need to have a think about that! The first challenge would be actually deforming the cube Poser primative.See the above link for an example of doing a simular thing with joints in PoserPhysics.
Creator
of OctaneRender
for Poser
Blog
Facebook
"can it make james's feet hit the steps walking, without collapsing into the ragdoll?"
HI a figure walking up a flight of stairs would require manual key frame animation
I did a tutorial on this a few years ago
Cheers
I purchased it yesterday. But I miss a documentation. Can't find it?
Poser Pro 2012 [or Poser 9]/Documentation/PoserPhysics/help.html
Sample scenes are in The Scenes library (in the Poser Libraries window) under PoserPhysics.
Creator
of OctaneRender
for Poser
Blog
Facebook
In my 1st hour of using it, I have managed to get some unhelpful errors:
File "C:Program FilesSmith MicroPoser Pro 2012RuntimePythonposerScriptsPoserPhysicsPhysicsWxP9.py", line 435, in endSimulation
AttributeError: 'NoneType' object has no attribute 'endSimulation'
assertion "bNormalizationResult" failed in ....includeode/odemath.h:444
timarender - Would it be possible for you to email me on support@physicalc-software.com your Poser build number, OS, 32 or 64 bit, and if possible the scene too (or at least details of the propr in the scene)? I can then track the issue down.
Creator
of OctaneRender
for Poser
Blog
Facebook
Quote - I purchased it yesterday. But I miss a documentation. Can't find it?
Thank you :)
Mazak
Quote - "can it make james's feet hit the steps walking, without collapsing into the ragdoll?"
I did a tutorial on this a few years agoCheers
it's very tedious to manually keyframe feet collisions. was hoping the physics could help.
Is there any limitations for Poser9 versus Poser2012? I just got some serious animation inspiration from the link below, but I want' to make sure I won't be missing something using Poser9?
Quote - I asked face-off recently about soft body physics, is it possible in Poser, ever. He asked me to elaborate on what I meant by that, so here goes:
::::: Opera :::::
It's not just the collison deformations that would be helpful. I'd like to be able to add springiness or jiggle to props and figures. A magnet can be used to manually push-pull the mesh, but I want something to automate the inertial damping when animating transmap hair, antennae, soft-body parts... Magnets that "lazily" trail their parents' motions and slowly come to rest (while over/undershooting their rest point) would be most welcome.
Having given it some thought, a normal magnet which is strongest in the centre and falls-off toward its perimeter should be able to do the breast/belly jiggle that is so difficult to animate now. OTOH, springy transmap hair seems it would need a magnet that is strongest at the edge and weakest at the centre, and I'm not even sure if such magnets can currently be created.
3doutlaw : Is there any limitations for Poser9 versus Poser2012?
PoserPhysics 2012 runs the same on both products. Thanks for that link - ghidghid is a great animator!
Thanks Greg : I will post a video tutorial on the new joint system in the next 12 hrs or so.
Creator
of OctaneRender
for Poser
Blog
Facebook
Quote - 3doutlaw : Is there any limitations for Poser9 versus Poser2012?
Thanks for the response, I am in for one! I got more to learn in Poser animation. My last big animation project was in Carrara, so I got some learning to do!
timarender - Further to my earlier bug report, I am (currently) unable to reproduce them at will.
Without more detail, I can only speculate that maybe you had a prop in the scene which perhaps had some odd geometry in it, or reversed normals, which has tripped up the creation of a trimesh prop. Also, (and I will fix this in SR1), don't open two PoserPhysics windows at the same time (there is no need to).
Again, pls email me if you have any issues.
Creator
of OctaneRender
for Poser
Blog
Facebook
I don't do animation (at least, not at present). Does Poser Physic offer any significant benefits for rendering stills?
______________
just my 2 cents, but ...once you created an animation using Poser Physics, you could then go back & select images from possibly hundreds of stills (depending on how long your animation was),, but also via the PoserPhysics animation you would wind up with eventually tons of free poses which you could save to your Pose library (& as another plus, most all of the poses would be poses that you probly wouldn't be able to buy because they would be unique or created from your own animations)
"I don't do animation (at least, not at present). Does Poser Physic offer any significant benefits for rendering stills?"
To be honest this plugin for creating realistic
Dynamic animation events that would be very difficult if not impossible to key frame by hand.
If you have no immediate plans to start rendering animations this plugin is probably not a good option for you.
Cheers
Thanks, Wolf. It would be nice to see something like soft-body physics even for stills. I know there is the morph tool, and the cloth room, but one can't do everything with those....
______________
Attached Link: http://poserphysics.blogspot.com.au/2012/06/new-joint-system-tutorial.html
A new tutorial is now available detailing the new joint system in PoserPhysics 2012.Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
EXcellent work Paul!!
I just wanted to say the I have been animating characters for over 13 years
and have used expensive apps like Lightwave3D and Maxon Cinema4D
and with the exception of Autodesk $$motionbuilder$$ and a few other expensive game engines I have not seen any pro app that can take it existing character rigs and
apply ragdoll physics to them on demand at a specific frame combining them with "rigid body" object collisions.
Even the older poser physics ,that I still use, far,exceeds anything I have seen in this area of ragdoll physics
this VIDEO says it all IMHO
Cheers
Thanks for the nice words Wolf!
For stills, IMO, soft-body physics effects are far better off being done manually in something like ZBrush (and word is that GoZ integration is coming to Poser, which would make this a snap).
Thanks Opera - that's a good suggestion. One of the challenges of this approach is that the simulator would need to modify the underlying vertex positions of the props being deformed, rather than the position and rotates that it currently does. So it's possible, but complex to implement.
PoserPhysics is already very feature-rich, with the inclusion of the new joint system. I am wary of adding even more features because it may shift it from being a "very simple and easy app to use" into being a "complex app with a big learning curve". But all feature requests are still most welcome.
Creator
of OctaneRender
for Poser
Blog
Facebook
Bonjour
I have bought Poser physics 2012 just friday
Since i test it ok with ball and v4 character
But i failed , after many try, to set V4 character fall down on a chair beside her
Someone can suggest a mini tutor on it ? like step one,step two etc
I use Poser for many years but just for static illustration
I have tried to begin some animation for fun with this Poser physics
Thanks
Attached Link: http://youtu.be/N-2ibTq-p8g
Hi **martial**. There is a fairly detailed tutorial at the attached link (although I would call it "mini").If you have specific questions, pls feel free to post screenshots of what you are trying to do and I can then help out.
Creator
of OctaneRender
for Poser
Blog
Facebook
"Since i test it ok with ball and v4 character
But i failed , after many try, to set V4 character fall down on a chair beside her"
Hi I cannot speak for poser physics 2012 as I use the older original poser physics with poser version 6
But I do Know that DAZ V4 & M4 are NOT compatible with the previous poser physics
unless you alter certain lines in their CR2 files.
.....and that introduces a new issue we can address later
Perhaps Paul can confirm compatibility with the DAZ V4/M4 Figures in Poser physics 2012??
Cheers
Hi Wolf - I'm pretty sure I fxied that at some point, because I've been running V4/M4 ragdolls with the new system without modification to the CR2 file.
Creator
of OctaneRender
for Poser
Blog
Facebook
With Poser physics 2012 the DAZ generaton 4 figures are fully supported (V4,M4)
See http://www.physicalc-software.com/
Everytime i try to set V4 to fall ON the chair she fall down beside on the floor
The way a ragdoll falls will largely depend on their starting stance. Try bending her thighs forward, and calves back a bit at frame 1. There are also a range of joint tuning parameters to adjust how the ragdoll falls - which are covered in the documentation, but I will do a tutorial in the next few days which provides more detail.
Regardless, when you DO get Victoria to fall onto the chair, she will probably then fall onto the ground from there, unless you use a very big friction number.
Ragdoll physics, as the name suggests, has the figure falling like a ragdoll. A ragdoll is unlikely to fall into a seated position in a chair and then stay there.
Creator
of OctaneRender
for Poser
Blog
Facebook
Creator
of OctaneRender
for Poser
Blog
Facebook
Creator
of OctaneRender
for Poser
Blog
Facebook
martial - as Timarender indicated, you can safely ignore the "Reparent Props" button unless you are joining props together (with hinge, ball or fixed joints). It is not relevant for figures.
I'll let you know when the new tutorial is available.
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://poserphysics.blogspot.com.au/2012/06/tower-builder-script.html
The python script used to create the Tower in my Tower animation is available in the attached link.Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://poserphysics.blogspot.com.au/2012/06/poserphysics-sr1-notes.html
Details on SR1, incl a video showing the new features. The Motors are super cool!Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://youtu.be/dFKZblRPFpM
Check out the cool video of chain link simulations....Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://youtu.be/iwZ0iJ3sJjg
Ryan falling through a glass window at the above link.Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://poserphysics.blogspot.com.au/2012/08/final-sr1-release-notes.html
Final SR1 release notes are available at the above address.Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
The lock feature has my curiousity peaked. Using the lock feature, let's say I have a figure sitting on a couch and want to simulate a small earthquake. If I get the couch moving a bit does that mean the figure would wobble on the couch (sway may be a better word) and stop wobbling when the couch stops moving all while retaining the original pose?
If so, that would be amazing.
I have playing with this for a while now, and think that there may be a viable way to simulate a lot of the soft body and collision stuff with what is there now. Some can be done fairly easily, others require a little thought on how to set it up.
If you look at the video for the Joint Anchors, you can use them for some of it, by attaching a magnet or wave deformer to one or both of the props. Collision deformations could be set up in a similar way as well.
Video is here that shows how the joint system works if you have not seen it.
http://www.youtube.com/watch?v=52CW8KPzYn4&feature=plcp
I am still playing around with how to set a lot of it up, but even without true soft body physics, a lot of it can be simulated with the tools we have now.
On another note about getting characters to do certain things in a simulation. Forcing scene specific limits is your friend. I have not played around with the ragdoll a lot in Poser yet. But in other programs, the joint limits allow you to choreograph reactions and still have some randomness as well. You can also add constraints.
I wonder if you can key constraints to a simulation with this? I need to play around with that as well. I didn't even think about it till just now, lol...
The joint system is a welcome addition, and will probably end up having more uses that we realize right now. If you are familiar with another physics engines abilities. Think outside the box and see what you come up with this one.
Some things are easy to explain, other things are not........ <- Store -> <-Freebies->
Hi for poser 9/2012
users needing hardbody and ragdoll physic animation
read all about it
*poser9/poser 2012 only
Cheers
http://blog.smithmicro.com/2012/06/20/poser-3d/just-released-poserphysics-2012-physics-simulation-ragdoll-dynamics-for-poser-9-and-pro-2012/
My website
