Tue, Nov 26, 10:12 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: DAZ Subdragon in Poser flying limbs problem
SimonWM ( ) posted Thu, 21 June 2012 at 9:26 PM · edited Tue, 26 November 2024 at 9:56 AM
When building an animation for the DAZ Millenium Subdragon in Poser and trying to save such animation as a PZ2 for distribution once you apply the PZ2 the dragon's feet and arms deform and fly away.  Does anyone knows if it exists a phyton script to fix that?
Lyrra ( ) posted Fri, 22 June 2012 at 10:03 PM
I'm not as familiar with this figure .. but have you checked for IK ? that tends to make feet come off
Lyrra
SimonWM ( ) posted Fri, 22 June 2012 at 11:21 PM
Thank you Lyrra.  I thought at first it had to do with it too but the subdragon doesn't have IK in Poser, its grayed out.
lesbentley ( ) posted Sat, 23 June 2012 at 11:00 AM · edited Sat, 23 June 2012 at 11:04 AM
It looks to me like the paws of the creature have been translated some how. Normally this is caused by saving a pose whilst IK is turned on. You say the figure has no IK, so I guess there must be another reason for the translations having a none zero value.
The only thing I can think to suggest is that you edit the pose file to set any translation channels from the offending parts to zero. You can use the free CR2Builder, or CR2Editor, or one of the commercial editors such as PhilC's PZ3editor, or D3D's Poser file Editor, or even a text editor at a pinch.
SimonWM ( ) posted Sat, 23 June 2012 at 11:30 AM
This is something to try. Thank you, lesbentley.
lesbentley ( ) posted Sat, 23 June 2012 at 1:11 PM · edited Sat, 23 June 2012 at 1:13 PM
The attached image shows the bit you need to change, as it appears in CR2Builder. The 'keys' section of each channel contains two values (separated by a space). The first value is the frame number (used in animations), and the second value is the parameter value. It is the parameter value that you need to change to zero. You need to do this for each translation channel in the part that is causing the problem, in your case this will probably be the "hands" and "feet", or whatever they are called in the Subdragon.
Normally all the translations in all parts of the pose, except the sub-root actor (usually "hip"), should be zero. If any part (except the sub-root) has a none zero value, it will cause the sort of stretching shown in your image.
SimonWM ( ) posted Sat, 23 June 2012 at 1:31 PM
Thank you so much for the through explanation.  I was about to give up on Poser compatibility for this product but with this I'll try to see if I can squeeze the time to do this to each file since its A LOT of frames.  16 PZ2 motions in total.  I wish there was a script I could use to automate this.  Thanks again for taking the time to explain this.
Lyrra ( ) posted Sun, 24 June 2012 at 4:19 AM
go find a program called EditTabLite
then open all your files. all poser files are text files at their heart so any simple text editor can read and edit them
If you are lucky its the same number so you can do a search and replace on all instances in all files in one operation
If its several numbers you may have to manually edit each one, but the search will make it easier to get there.
I use NoteTabLite to edit mass loads of pz2's and suchlike if I for example have to change a texturefile name, and then all the MAT files that refer to it.
Lyrra
SimonWM ( ) posted Sun, 24 June 2012 at 5:17 AM
I use EditPad Lite which should be the same.  Thanks again Lyrra.
FutureFantasyDesign ( ) posted Wed, 04 July 2012 at 3:39 PM
Sorry sort of hijacking this thread, but...
Does anyone know the correct way to smooth out the sub division on the subdragon in poserpro 2012??? I have both LE and Full versions of him.
I have tried to smooth the polygons and to reduce the crease angle and the sub division issue is still so apparent. Has anyone found a good tut or resolution to this issue?
Ariana
Is there water in your future or is it being shipped away to be resold to you?
Water, the ultimate weapon...
www.futurefantasydesign.com
WandW ( ) posted Wed, 04 July 2012 at 5:41 PM
Did you try increasing the crease angle on the beast?  I use 170 for Genesis...
FutureFantasyDesign ( ) posted Wed, 04 July 2012 at 7:23 PM
Oh so you go up not down! I will definitely try this!!! Thank you!!!!
HugZ!
Ariana
vilters ( ) posted Thu, 05 July 2012 at 5:06 PM
Use Snarly's Scenefixer script to smooth figures or props.
YES, UPWARDS is the way to go to smooth more.
I use crease angle of 180° on all figures and or props I want smoothed.
FutureFantasyDesign ( ) posted Thu, 05 July 2012 at 6:34 PM
and who knew! I always thought it was less!
Thank you all so much!!! :D
Ariana
vilters ( ) posted Thu, 05 July 2012 at 7:21 PM
Posers Smoothing options are very detailed in the manual.
in general preferences
in the render settings
In the group editor
In the Smoothing parameters palette
Most information is on pages 407 till and including 411
FutureFantasyDesign ( ) posted Fri, 06 July 2012 at 9:19 AM
You know with 2012, I only rec'd a small pamphlette! Not like with poser 7 where I rec'd a full on book! Did you get a book with your copy? I was told they no longer included one. And I did not buy one from the bookstore. If you are reffering to the PDF, gads I have a real issue being able to see those... bad vision and it is glitchy on Win7 for me. I have never fell, in love with Win7...
But your help is appreciated! :)
HugZ!
Ariana
Oh I have Poser' 5/6/7/2010/2012
vilters ( ) posted Fri, 06 July 2012 at 9:56 AM
Yes, I was referring to the pdf manual. :-)
Open the pdf an do a search on smoothing or crease angle .
all relevant infomation should surface.
Page 403, and 407 till 411 come to mind. There are some examples too.
Happy Posering.
FutureFantasyDesign ( ) posted Fri, 06 July 2012 at 10:30 AM
I was wondering, do you know how to convert the crease angle into a little python script to save the angle to all parts? Or does Snarly's Scene fixer do this? I found it has to be done to every single part, and that is very time consuming. Really takes a long time!
I downloaded the scene fixer two times, but it keeps installing outside of the Python structure, and I do not know where each seperate file belongs in able to correctly fix this issue. Is it possible for you to help me with that? If so and it is extensive, or has SS's, I can send you my e-mail through site mail here...
Thank you!!!
Ariana
hborre ( ) posted Fri, 06 July 2012 at 11:45 AM
Online Now!
Scenefixer is just one file and you can place it in it's own folder within the scriptmenu of the Python folder.  That way it will be available from the taskbar above.
It will not do subdivisions.
FutureFantasyDesign ( ) posted Fri, 06 July 2012 at 12:03 PM
Quote - Scenefixer is just one file and you can place it in it's own folder within the scriptmenu of the Python folder.  That way it will be available from the taskbar above.
I will go redownload it and send you a SS of what it does when it installs... Maybe it is some weird glitch from windows? o0
Ariana
