Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
It looks to me like the paws of the creature have been translated some how. Normally this is caused by saving a pose whilst IK is turned on. You say the figure has no IK, so I guess there must be another reason for the translations having a none zero value.
The only thing I can think to suggest is that you edit the pose file to set any translation channels from the offending parts to zero. You can use the free CR2Builder, or CR2Editor, or one of the commercial editors such as PhilC's PZ3editor, or D3D's Poser file Editor, or even a text editor at a pinch.
Normally all the translations in all parts of the pose, except the sub-root actor (usually "hip"), should be zero. If any part (except the sub-root) has a none zero value, it will cause the sort of stretching shown in your image.
Thank you so much for the through explanation. I was about to give up on Poser compatibility for this product but with this I'll try to see if I can squeeze the time to do this to each file since its A LOT of frames. 16 PZ2 motions in total. I wish there was a script I could use to automate this. Thanks again for taking the time to explain this.
go find a program called EditTabLite
then open all your files. all poser files are text files at their heart so any simple text editor can read and edit them
If you are lucky its the same number so you can do a search and replace on all instances in all files in one operation
If its several numbers you may have to manually edit each one, but the search will make it easier to get there.
I use NoteTabLite to edit mass loads of pz2's and suchlike if I for example have to change a texturefile name, and then all the MAT files that refer to it.
Lyrra
Sorry sort of hijacking this thread, but...
Does anyone know the correct way to smooth out the sub division on the subdragon in poserpro 2012??? I have both LE and Full versions of him.
I have tried to smooth the polygons and to reduce the crease angle and the sub division issue is still so apparent. Has anyone found a good tut or resolution to this issue?
Ariana
Is there water in your future or is
it being shipped away to be resold to you?
Water, the ultimate
weapon...
www.futurefantasydesign.com
Did you try increasing the crease angle on the beast? I use 170 for Genesis...
"Oh - the manual says that? I have never read the manual - this must be why."Use Snarly's Scenefixer script to smooth figures or props.
YES, UPWARDS is the way to go to smooth more.
I use crease angle of 180° on all figures and or props I want smoothed.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Posers Smoothing options are very detailed in the manual.
in general preferences
in the render settings
In the group editor
In the Smoothing parameters palette
Most information is on pages 407 till and including 411
Dev
"Do not drive
You know with 2012, I only rec'd a small pamphlette! Not like with poser 7 where I rec'd a full on book! Did you get a book with your copy? I was told they no longer included one. And I did not buy one from the bookstore. If you are reffering to the PDF, gads I have a real issue being able to see those... bad vision and it is glitchy on Win7 for me. I have never fell, in love with Win7...
But your help is appreciated! :)
HugZ!
Ariana
Oh I have Poser' 5/6/7/2010/2012
Water, the ultimate
weapon...
Yes, I was referring to the pdf manual. :-)
Open the pdf an do a search on smoothing or crease angle .
all relevant infomation should surface.
Page 403, and 407 till 411 come to mind. There are some examples too.
Happy Posering.
Dev
"Do not drive
I was wondering, do you know how to convert the crease angle into a little python script to save the angle to all parts? Or does Snarly's Scene fixer do this? I found it has to be done to every single part, and that is very time consuming. Really takes a long time!
I downloaded the scene fixer two times, but it keeps installing outside of the Python structure, and I do not know where each seperate file belongs in able to correctly fix this issue. Is it possible for you to help me with that? If so and it is extensive, or has SS's, I can send you my e-mail through site mail here...
Thank you!!!
Ariana
Water, the ultimate
weapon...
Quote - Scenefixer is just one file and you can place it in it's own folder within the scriptmenu of the Python folder. That way it will be available from the taskbar above.
It will not do subdivisions.
I will go redownload it and send you a SS of what it does when it installs... Maybe it is some weird glitch from windows? o0
Ariana
Water, the ultimate
weapon...
