??? Does your Vicky have unconventional scaling??? I mean by that: If for ex. you scaled her thighs in the y axe to 120%, then for sure you'd need to make the same adjustments on the boots thighs manually... Yeap!! Conforming does not do those adjusments automatically! Give you an example: Load a default Vicky, conform some clothes to her, then scale Vicky at 200%. In Most cases, the clothes stay at 10o%... Have you tried looking at different angles but, with the "shading w/lines" option?? That way it's easy to see if your clothing is confroming to vicky properly... Oh!! i just thought of something! You must make sure that Vciky has "inverse kinetics" turned off for the legs prior to conforming boots, shoes.... i know that others will say that it's not necessary! But, after many experiments... Anyhow, Hope this info helps a bit... Marco
DAZ would like to thank all those who purchased the Victoria 2.0 Morphing Clothing Pak 1 by John Brugioni. We particularly wish to express our appreciation for the patience of the few people who have had a problem with the pak. The free June 2000 update released by DAZ for the initial Clothing Pak 1 is required for John Brugioni's morphs to work. For anyone who purchased the Victoria Clothing Pak 1 before June 2000, please see the Clothing Pak 1 product page in order to get the update. This update must be installed on your system in order for the Victoria 2.0 Morphing Clothing Pak 1 to work properly. If you have any further problems or concerns please contact Betsy at tech@daz3d.com. Again we apologize for the confusion and appreciate your patience. Thanks, AnneMarie DAZ
