Tue, Feb 4, 9:51 PM CST
Subject: Problem with Victoria (1 & 2) and Clothing Pak
Trapper ( ) posted Wed, 05 September 2001 at 9:27 PM ยท edited Tue, 04 February 2025 at 7:46 PM
I have been having a problem with Poser/Victoria 1 & 2 that no one seems to know what to do with. Ive posted on dozens of newsgroups ever since I first encountered it (last year), and no luck. The problem I am having is with Victoria and Clothing Pak 1. Ive included an image with the problem, so please refer to it. I cant seem to get any of the clothing to conform to Victoria correctly. When I view the character from the front, everything looks fine (The render on the left). However, when I use the parameter dials to rotate her (i.e. yRotate) the clothing gets all funky (The middle and right renders) I have installed all updates, so that isnt it. And this problem appears on every OS I have installed (Win 9x, Win 2K, Win XP). Please Help! I've paid a lot of money for Victoria 1 & 2 and the Clothing Pak, and so far I've been unable to use any of them.
djthomas ( ) posted Wed, 05 September 2001 at 9:44 PM
Just out of curiosity, if you change your camera view and look at Vicki from behind, instead of rotating her, then render THAT image, are things still screwed up?
Trapper ( ) posted Wed, 05 September 2001 at 9:48 PM
No. If I change the camera view and look at her from behind, everything works fine. However, that isn't really a good option for obvious reasons. Kinda limits the scene. :) Any other ideas/suggestions???
djthomas ( ) posted Wed, 05 September 2001 at 9:56 PM
Have you tried (just for the hell of it) rotating the boots the same amount as you rotate Vicki? I know that if you select the boots to conform to vicki they should rotate as well, but...
Trapper ( ) posted Wed, 05 September 2001 at 10:04 PM
Yup. Thought of that. No luck. Only makes things worse. This is very FRUSTRATING! Thanks for trying to help!
Viomar ( ) posted Wed, 05 September 2001 at 11:25 PM
??? Does your Vicky have unconventional scaling??? I mean by that: If for ex. you scaled her thighs in the y axe to 120%, then for sure you'd need to make the same adjustments on the boots thighs manually... Yeap!! Conforming does not do those adjusments automatically! Give you an example: Load a default Vicky, conform some clothes to her, then scale Vicky at 200%. In Most cases, the clothes stay at 10o%... Have you tried looking at different angles but, with the "shading w/lines" option?? That way it's easy to see if your clothing is confroming to vicky properly... Oh!! i just thought of something! You must make sure that Vciky has "inverse kinetics" turned off for the legs prior to conforming boots, shoes.... i know that others will say that it's not necessary! But, after many experiments... Anyhow, Hope this info helps a bit... Marco
Taura Noxx ( ) posted Thu, 06 September 2001 at 3:30 AM
I found this aswell, sometime if I select the offending top boot part and go into it's properties, I can uncheck bend with figure or whatever that thingy is and it seems to pop back. :) Doesn't work all the time but it does sometimes ;-)
Questor ( ) posted Thu, 06 September 2001 at 5:55 AM
One thing you could try. Turn all IK off for the Vickie figure and then rotate her by rotating the hip not the body.
Trapper ( ) posted Thu, 06 September 2001 at 5:28 PM
Thanks for all the ideas! I tried 'em all, but the one that worked was from Taura Noxx. Thanks, buddy!! I can actually start using Vicki...like I should have been able to ever since I first purchased her last year. Tons of lost time to make up!!! Thanks guys/gals.
annemarie ( ) posted Wed, 03 October 2001 at 5:07 PM
DAZ would like to thank all those who purchased the Victoria 2.0 Morphing Clothing Pak 1 by John Brugioni. We particularly wish to express our appreciation for the patience of the few people who have had a problem with the pak. The free June 2000 update released by DAZ for the initial Clothing Pak 1 is required for John Brugioni's morphs to work. For anyone who purchased the Victoria Clothing Pak 1 before June 2000, please see the Clothing Pak 1 product page in order to get the update. This update must be installed on your system in order for the Victoria 2.0 Morphing Clothing Pak 1 to work properly. If you have any further problems or concerns please contact Betsy at tech@daz3d.com. Again we apologize for the confusion and appreciate your patience. Thanks, AnneMarie DAZ
