Fri, Nov 15, 1:54 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: GND4 pulled from the marketplace.
Hana-Hanabi ( ) posted Fri, 20 July 2012 at 2:38 PM
I am too slow, heh.
The morph only needs to be active on frame 1 of the sim before it's started. You can dail it back to 0 sometime in the simulation, and it works just fine, or you can go in and dail it back after the simulation ends. Either works just fine.
花 | 美 | 花美 | 花火
...It's a pun.
operaguy ( ) posted Fri, 20 July 2012 at 2:42 PM
the lady has great bones in her face.
::::: Opera :::::
operaguy ( ) posted Fri, 20 July 2012 at 2:53 PM · edited Fri, 20 July 2012 at 2:56 PM
[click for full]
This shows it off even better.
Notes: this is Blackhearted's head morph, but I manipulated the eyes a little. Skin maps are not his. Otherwise, this is all bh.
nightgown by carib98
::::: Opera :::::
Hana-Hanabi ( ) posted Fri, 20 July 2012 at 3:50 PM
Tips for the Cloth Room:
You can make more than one Dynamic Group. By making a second one and adding the straps to it, you can give it completely different cloth parameters than the body. (If you wanted the main cloth area to be stretchy or floaty, but the straps to have different properties, you can do that!)
I like to bump up the Collision Offset to be larger than the Collision Depth. An additional 0.1 is good in this case.
I'm going to do some sims with different cloth paramaters and post them.
花 | 美 | 花美 | 花火
...It's a pun.
Hana-Hanabi ( ) posted Fri, 20 July 2012 at 9:24 PM
Here are the settings that are shipped with the chemise. This is a nice charmeuse.
花 | 美 | 花美 | 花火
...It's a pun.
Hana-Hanabi ( ) posted Fri, 20 July 2012 at 9:25 PM
Fold Resistance 50 Shear Resistance 150 Stretch Resistance 50 Stretch Damping 0.01 Cloth Density 0.01 Cloth Self-friction 0.2 Static Friction 0.01 Dynamic Friction 0.1 Air Damping 0.04
This is an approximation of a stiff acetate organza.
花 | 美 | 花美 | 花火
...It's a pun.
Hana-Hanabi ( ) posted Fri, 20 July 2012 at 9:26 PM
Fold Resistance 50 Shear Resistance 150 Stretch Resistance 50 Stretch Damping 0.01 Cloth Density 0.015 Cloth Self-friction 0.2 Static Friction 0.01 Dynamic Friction 0.1 Air Damping 0.04
Silk organza is slightly less stiff than acetate.
花 | 美 | 花美 | 花火
...It's a pun.
Hana-Hanabi ( ) posted Fri, 20 July 2012 at 9:27 PM
Fold Resistance 10 Shear Resistance 150 Stretch Resistance 50 Stretch Damping 0.01 Cloth Density 0.02 Cloth Self-friction 0.2 Static Friction 0.01 Dynamic Friction 0.1 Air Damping 0.04
Heavier momme charmeuse or crepe-back satin.
花 | 美 | 花美 | 花火
...It's a pun.
Hana-Hanabi ( ) posted Fri, 20 July 2012 at 9:28 PM
Fold Resistance 5 Shear Resistance 150 Stretch Resistance 50 Stretch Damping 0.01 Cloth Density 0.02 Cloth Self-friction 0.2 Static Friction 0.01 Dynamic Friction 0.1 Air Damping 0.04
Another charmeuse.
花 | 美 | 花美 | 花火
...It's a pun.
Hana-Hanabi ( ) posted Fri, 20 July 2012 at 9:29 PM
Fold Resistance 1 Shear Resistance 750 Stretch Resistance 250 Stretch Damping 0.01 Cloth Density 0.02 Cloth Self-friction 0.2 Static Friction 0.3 Dynamic Friction 0.1 Air Damping 0.4
This is more chiffon or georgette.
花 | 美 | 花美 | 花火
...It's a pun.
Hana-Hanabi ( ) posted Fri, 20 July 2012 at 9:41 PM · edited Fri, 20 July 2012 at 9:42 PM
For silk (which I suspect is what most people will want to approximate with this garment), you want to keep a fairly high shear resistance. Silk is a very long-staple fiber, and the threads spun from it tend to be strong and very lustrous. Dupioni, shantung, tussah, and especially noil are all shorter silks, but because of the shorter staple, the yarns (and thus fabrics) are usually thicker, negating the effect of the loss of strength in the fiber. The shear resistance doesn't have to be cranked quite so high as I have it, but  you want to be careful going very low with it.
花 | 美 | 花美 | 花火
...It's a pun.
operaguy ( ) posted Fri, 20 July 2012 at 10:11 PM
what does "shear resistance" actually mean? I thought it meant resistance to tearing.I usually set it to 500.
Zaarin ( ) posted Fri, 20 July 2012 at 10:12 PM
Thanks for all that great info, Hana-Hanabi. You should create a thread with settings for non-silk fabrics--you seem to have a great knowledge of cloth, and getting the right drape settings can sometimes be trying. :)
Hana-Hanabi ( ) posted Fri, 20 July 2012 at 11:31 PM · edited Fri, 20 July 2012 at 11:37 PM
Shear resistance is hard to explain. Shearing is different from folding, but similar. Smith Micro defines it as "how much the cloth tends to retain its shape as it folds." I think of it as more the resistance to buckling or crinkling.
The picture above is all the base settings that come with the chemise, save for the Shear Resistance, which I have set to 1. It surprisingly doesn't look all that bad, but when you compare it to the base settings above, you can see that the folds are less defined...they start to buckle and crumple in places.
Zaarin, I might do that one of these days...I spin, knit, and sew IRL, so I kind of soak up fiber knowledge, ehehehe. I'll have to do lots of tests with parameter combinations, though. All scientific-like. ^_~
花 | 美 | 花美 | 花火
...It's a pun.
shante ( ) posted Fri, 20 July 2012 at 11:51 PM
So cool to have extensive experience in actual hands on work with fabrics and then learning the ins and outs of the 3D applications of fabrics and transfering real world skills and experience to the software. Enviable skills. I am so jealous. ;)
After years of using Poser I am still having problems trying to figure out magnets or adding a second Runtime Folder without garnering the ire of some frustrated otherwise helpful folks in the community, never mind learning the cloth room. Now having recently migrated from Poser4 to Poser 7 the idea of getting through this cloth dynamics makes me break out in a cold sweat.   I am going to have to mark this thread as urgent and output it as a pdf file to print later for reference if and when I do try learning it  You made it sound this aspect of it easy. :(
operaguy ( ) posted Sat, 21 July 2012 at 12:39 AM · edited Sat, 21 July 2012 at 12:41 AM
[click for full]
i left the specular a little high, she's under intense lights for this photoshoot.
Fold Resistance 2.5
Shear Resistance 50
Stretch Damping 0.1
Cloth Density 0.05
Static Friction 0.5
Air Damping 0.04
on shader, transparancy .6
::::: Opera :::::
operaguy ( ) posted Sat, 21 July 2012 at 2:46 AM
what a shape. what a face. thanks Gabe.
Good night all.
::::: Opera :::::
meatSim ( ) posted Sat, 21 July 2012 at 12:14 PM
Thanks Opera Guy,  I never realized what a great job BH did on her face.  Really considering picking this up just for that.
Blackhearted ( ) posted Sat, 21 July 2012 at 5:59 PM
very cool -- thank you so much Hana.  i learned a lot about cloth :)
for the cloth room savvy, youll notice that the nipples are a constrained group. this is the best way ive found to hold the cloth in place on the breasts and eliminate the 'breats bags' underneath them without having to bump up the elasticity and thus 'iron out' the wrinkles. the downside is in some extreme sims you may get some wrinkling around the nipples: this is easily fixed by using the morphing tool set to smooth (use a high number like 3.0 or 4.0).
btw - those of you using gamma correction are going to have to tweak the transparency settings of the chemise.
cheers,
-Gabriel
operaguy ( ) posted Sat, 21 July 2012 at 8:37 PM
yes, i had to change the transparancy setting.
Inspired_Art ( ) posted Mon, 23 July 2012 at 10:28 PM
Attached Link: Anastasia
![Anastasia](http://www.inpulsearts.com/Art_Gallery/var/resizes/Poser-Art/Anastasia.jpg "Anastasia")
Eddy
Eric98 ( ) posted Tue, 31 July 2012 at 11:43 PM
OK, I'll just whack myself across the back of the head later if I missed something simple, but wanted to get the Anastasia update.   Purchased the original already in the Marketplace, and tried what was said about re-downloading/re-installing, but the website wouldn't allow this (something I've never had a problem with over on smithmicro or daz), and email to the contact there resulted in a 'huh?'.   So, can anyone point out where this went wrong?
Blackhearted ( ) posted Wed, 01 August 2012 at 5:25 AM
heya,
the update is for The Girl Next Door 4: Athletic (vicky4).
GND: Anastasia is a completely different character, for Alyson 2.  shell be getting an update too though very soon :)
Hana-Hanabi ( ) posted Thu, 02 August 2012 at 1:21 AM
Attached Link: Late night at 127.0.0.1
So, we're still posting our renders in appreciation of Gabe's fantabulous awesome genius, right? That's what I thought. ^_~
花 | 美 | 花美 | 花火
...It's a pun.
Blackhearted ( ) posted Fri, 10 August 2012 at 8:26 PM · edited Fri, 10 August 2012 at 8:27 PM
**[the bikini update is up :)](http://www.renderosity.com/mod/bcs/index.php?ViewProduct=63635)**
took a bit longer than id anticipated to both match all of the GND4.2 morphs as well as add some new feature morphs.
anyone thats already purchased it can just re-download it and get all the new content for free.
have a great weekend folks,
cheers,
-Gabriel
Lyrra ( ) posted Fri, 10 August 2012 at 9:10 PM
that teeny yellow bikini needs polka dots :)
Lyrra
Blackhearted ( ) posted Fri, 10 August 2012 at 9:28 PM
btw a couple of people have asked me what face i used in my GND4/GND promos...
its the base GND4 head:  i just added a couple of the stock V4 dials, namely LipsPartCenter, LipsPucker and EyePupilDialate (Daz's spelling error, not mine :)).
DCArt ( ) posted Fri, 10 August 2012 at 10:04 PM
::::: Opera :::::
Gorgeous render
operaguy ( ) posted Fri, 10 August 2012 at 10:25 PM
thanks Deecey
shante ( ) posted Sun, 12 August 2012 at 1:17 PM
I tried re-downloading the bikini and I keep getting an error message:
You Have Exceed The Maximum Number of Downloads allowed for this item.
Never seen that before. What does it mean?
Inspired_Art ( ) posted Sun, 12 August 2012 at 1:32 PM · edited Sun, 12 August 2012 at 1:32 PM
Contact RMP supprt team and request a download reset.
Store@Renderosity.com
Eddy
LaurieA ( ) posted Sun, 12 August 2012 at 3:00 PM
Yeah, I think they allow 3 or 4 times and then they make it a PITA...lol.
shante ( ) posted Sun, 12 August 2012 at 3:04 PM
Hi Laurie!
????What's a PITA????
I have only downloaded it once when I first bought the original. Never until now having gotten the update notice in the mail yesterday tried to download it again. That is why I found it strange.
I did email sales to see what the deal is though. Thanks Inspired_Art.
LaurieA ( ) posted Sun, 12 August 2012 at 3:09 PM · edited Sun, 12 August 2012 at 3:11 PM
PITA=Pain in the ass....lol.
shante ( ) posted Sun, 12 August 2012 at 3:42 PM
Quote - PITA=Pain in the ass....lol.
Oh!?!?
Duh!!!   LOL
All sites are becomming that it seems.
They keep changing things only to make them worse.
toastie ( ) posted Sun, 12 August 2012 at 5:27 PM
Quote - They keep changing things only to make them worse.
If it ain't broke - fix it 'til it is!
shante ( ) posted Sun, 12 August 2012 at 5:36 PM
Yeah....that seems to be the current philosophy in everything in our society no different on-line.
If you must update something (Like what DAZ has done for instance), please make sure it actually works before you make it ready for the consumer. My experience there really sucks of late and I was always ok with what DAZ did.
Blackhearted ( ) posted Sun, 12 August 2012 at 6:04 PM
"If you must update something (Like what DAZ has done for instance), please make sure it actually works before you make it ready for the consumer. "
it has always been like that - three downloads and then you need to request a download reset.
i havent bought anything from Daz in eons but im pretty sure its like that there too.
shante ( ) posted Sun, 12 August 2012 at 7:06 PM
OK......but it still is a fact I have only downloaded once when the first version of GND and her Bikini were first purchased. THis is an UPDATED version which means it should have already been RESET. And I have not yet been able to DL it. Not three times but barely twice...if we can count the original DL of the original older version of the product.
Quote - "If you must update something (Like what DAZ has done for instance), please make sure it actually works before you make it ready for the consumer. "
Lyrra ( ) posted Sun, 12 August 2012 at 8:22 PM
If you use a download resumer or speeder it may have made several attempts without you knowing it - thus using up your alottment. That is one of the reasons most sites discourage download utilities like that
Lyrra
shante ( ) posted Sun, 12 August 2012 at 9:01 PM
But I don't.
Got the emailed update notice and came right to my account to download the update....clean and simple.
Quote - If you use a download resumer or speeder it may have made several attempts without you knowing it - thus using up your alottment. That is one of the reasons most sites discourage download utilities like that
Lyrra
LaurieA ( ) posted Sun, 12 August 2012 at 9:19 PM
You let the store know you can't download?
shante ( ) posted Sun, 12 August 2012 at 10:00 PM
Yes.
I emailed sales today but not expecting a response until tpmorrow or tuesday.
Quote - You let the store know you can't download?
LaurieA ( ) posted Sun, 12 August 2012 at 10:05 PM
Yeah, probably not ;). They'll take care of it tomorrow for ya tho.
