Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 12:42 pm)
That's a lovely render. So - have I read this right (it's gone midnight here) ;) I can have my V4 in a separate folder (as originally) but install the script in either the users/Poser 9 Content folder - or Program Files (x86) SM/Poser 9. Sorry to be so obtuse
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
Quote - Only the script needs to be in the central runtime. I used it with all my V4 files in a Version 4 runtime and it worked just fine. It made a character file in the same folder that my originals (one preloaded with morphs, one from the plain base) were in.
I'm running W7 - still having difficulty re V4-WM scripts locations - V4 and M4 are in an external 'Daz People' folder on an external HDD and have been added to the library in P9. As I've said, W7 doesn't like anything being added to SM/Poser 9/Runtime ... etc. I've tried installing scripts to that (with admin privileges) and to the C: users/public documents/Poser 9 Content Runtime. No success.
I'm sure I'm missing something really simple here. For the life of me I can't think of it :(
It's OK after much messing around I think I've finally installed it right. I've run it to create a V4-WM figure which I'll get accustomed to over the next weeks
does running the script on the V4 Dev figure turn it into a wmv4 dev figure for making wmv4 clothes?
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
I'm not that good at posing, but I've found weightmapped figures quite easy to pose by dragging various body parts. they seem to almost naturally fall into good poses.
Love esther
I aim to update it about once a month. Oh, and it's free!
Quote - Just to be clear, this conversion will work in Poser 9, and PoserPro 2012.
The task of staying within the limits set by DAZ3D, so as to protect their intellectual property, required a lot of creativity, and made this project particularly difficult. But it was felt that Poser users deserve figures that take advantage of the full feature set of P9/PP2012. Many Poser people have a large investment in V4, and V4~WM is another compelling reason to update to Poser 9 and PoserPro 2012.
A great deal of work has been put into making sure that things work as simply as possible. The V4~WM Crew at PoserPlace has put an heroic amount of effort into this project on behalf of the entire Poser Community, and they deserve a big round of applause!
lmk
So V4~MM will not work in anything prior to Poser 9/PoserPro 2012?
Eddy
It's V4-WM, not -MM. -WM stands for Weight Mapped. And the point of it is to use the new Weight Mapping, introduced in Poser 9, PP2012.
So, no, you can't use weight mapping before Poser had weight mapping.
The links don't work for my ISP either- there is something you need to do to edit your DNS configuration (don't know what exactly) to make it accessible. Do some searches around the forums. The site is still there.
Quote - Hummm the download link doesn't work, can someone please post it? And also a link to the instructions for clothing if you don't mind?
Thanks
Something else, with those of us running W7 not allowing us to install things into the main program file.... what I found that works for me, at least, is to make a temporary folder on the desktop, unzip/unrar the files to that, then cut/paste the runtime into the main runtime folder. Works for me, every time.....
Quote - Something else, with those of us running W7 not allowing us to install things into the main program file.... what I found that works for me, at least, is to make a temporary folder on the desktop, unzip/unrar the files to that, then cut/paste the runtime into the main runtime folder. Works for me, every time.....
The easiest way is to put everything in a folder outside C:/Program Files, then there's no problem, even with old programs (at least 32 bit).
I installed this V4WM and tracked down Outfitter last night. Works great!
outfitter did a great job converting Lemonaide from Alfaseed and the AMP set arm tubes. really slick!!!
I loaded Morphs++ , Base, and Elite, and they worked perfectly too.
Although I did run into a head morph INJ issue where the eyes were poking outside the face after loading.
I thought after reading through the thread, that perhaps the Head morph might have needed Aiko or some other morph set loaded first that I forgot.... I'm gonna test that theory tonight.
Any other suggestions?
A big Thank You to the team that brought this WM character to us!!!!!!!!
Okay, bear with me since I only just got Poser Pro and have been using DAZ studio for a while. So V4 does NOT work in Poser Pro, but the new WM version will? Gee, I had just assumed that it would load into Poser.
I am definitely looking forward to it: so far V5 and the Poser native figures have not impressed me anywhere as much as V4. Specially V5 out of the box (as it were), it just looks, well, ugly to me, not quite human.
Yes, a lot of the best stuff I know of is done by little indie folks, so I am not at all surprised by this. I'll be getting it. :)
Well, I solved the morph issue I mentioned above, the face morph required A4 moprhs, so that's working great.
Unfortunately, since I set up the WMV4 and converted the clothes.... poser pro 2012 is crashing like crazy. I'm wondering if it might be that when I converted the clothes I did not desellect the body parts I did not need ( ex. for the gloves.... I just went with all the body parts).. could this be the problem?
I guess this is more of an Outfitter question that relates to WMV4 :)
Any help would be great.
Quote - Works . . . . better? in what way? better posing? more user adjustable?
Better bending wihtout JCMs and magnets, which also results in a less resource intensive figure. (the only magnets left in V4WM are in the torso for breast control).
Check out the first couple of pages of this thread for renders
EDIT; here are some more renders...
http://poserplace.phantom3d.net/V4.2WM/V4.2WM.html
Nearly all V4 clothing can be weight-mapped to fit V4WM using the Outfitter script...
http://poserplace.phantom3d.net/PP_Outfitter/pp_outfitter.html
"Oh - the manual says that? I have never read the manual - this must be why."Hi Can anyone tell me here what I am doing wrong, I am trying to set up a login for the poserplace forum
I get this message on the end of my set up. I think this is a test of tests as I put the correct answer but not accepted.
The question I must answer is
What is the first two and last four characters in this word? Her6Bema7*:
This question is a means of preventing automated form submissions by spambots.
My answer is Hea7*:
Maybe I don't understand it any help please, I feel stupit to have to ask here.
cheers Rowlando
Seek what you can never loose
Its not working and really to hard to mess around with, it is just a forum so i will ask here any questions related to outrigger etc.
After trying to answer the question many times I was finally told I had run out of attempts and should try again later, I have to laugh really how hard is it join a forum.
poserplace is not for me I guess, thanks very much for the help Bill.
cheers Rowlando
I had difficulty in installing the M4/V4 bases and morphs in the users/P9 content location because of Windows 7's idiotic protocols. New items mustn't be installed in Program Files (x86) - (and Daz figures literally throwing a strop over it all). I'll give it another go in that folder. I'm just unsure as to how to install V4-WM - as I say I've never dealt with it before so it's new to me :)
Gallery
Freebies
Music Vids
