Sun, Feb 16, 10:53 AM CST
Subject: EZSkin v2 official release
Snarlygribbly ( ) posted Fri, 10 August 2012 at 1:18 PM · edited Sun, 16 February 2025 at 10:49 AM
Yup. It's available for download with user guide and everything :-)
Especial thanks to Basicwiz for writing the bulk of the documentation.
Download from Snarly's Space
MATHelper and SceneFixer had minor updates today too, if you feel like grabbing those while you're there.
Moving on to some other projects now ... :-)
Free stuff @ https://poser.cobrablade.net/
foxylady1 ( ) posted Fri, 10 August 2012 at 1:21 PM
Hi Snarlygribbly,
I cannot imagine Scene Fixer any better than it is already, but thank you for the updates.  Especially, EZSkin.  I never knew Poser people could look so good.
3doutlaw ( ) posted Fri, 10 August 2012 at 1:26 PM
Thanks, appreciate the hard work, and great products!  By far, some of the best utilities out there!
(runs off to Snarly's space)
vilters ( ) posted Fri, 10 August 2012 at 1:34 PM
Thank you man.
Realy do.
Scenefixer gets daily use here.
Such a time saver.
Sa_raneth ( ) posted Fri, 10 August 2012 at 1:43 PM
thank you
stallion ( ) posted Fri, 10 August 2012 at 1:53 PM
Thank you
You might as well PAY attention, because you can't afford FREE speech
Kalypso ( ) posted Fri, 10 August 2012 at 1:56 PM
Site Admin
Thank you for this update, can't wait to try it out!   And thanks to basicwiz for providing such great documentation!
DCArt ( ) posted Fri, 10 August 2012 at 2:16 PM
Thank you so much!
Mazak ( ) posted Fri, 10 August 2012 at 2:26 PM
Thank you very much! :thumbupboth:
Mazak
Google+ Bodo Nittel
basicwiz ( ) posted Fri, 10 August 2012 at 3:05 PM
I'm with the rest, Snarley... Thanks to BagginsBill for figuring out how all of this works, and to you, for making it work for the rest of us! It was my honor to be on the beta test team.
ToxicWolf ( ) posted Fri, 10 August 2012 at 4:15 PM
So cool ... downloading now. Thanks Snarley!
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
vitachick ( ) posted Fri, 10 August 2012 at 5:00 PM
Me too!  Want to add another BIG THANK YOU!!
Win10  Poser 2014/Poser 11 Daz3D
richardson ( ) posted Fri, 10 August 2012 at 5:21 PM
scarfed, snarfed and grabbly'd,,;P
bwldrd ( ) posted Fri, 10 August 2012 at 5:48 PM
Thank you. :D
Consider me insane if you wish, but is your reality any better?
anupaum ( ) posted Fri, 10 August 2012 at 7:04 PM
Hurray!  Bless you, Snarly!
JohnDoe641 ( ) posted Fri, 10 August 2012 at 8:19 PM
Freaking awesome. Thanks Snarly, you've made my renders look amazing. :D
hborre ( ) posted Fri, 10 August 2012 at 8:34 PM
TY.
Paloth ( ) posted Fri, 10 August 2012 at 9:19 PM
Wow. That makes a world of difference! Thank you.
ashley9803 ( ) posted Fri, 10 August 2012 at 9:27 PM · edited Fri, 10 August 2012 at 9:28 PM
I haven't installed PPro SR2.1 yet. Will EZSkin v2 still work. What parts will work and what won't? Is there any benefit going to v2 without SR2.1?
Wonderful program Snarlygribbly BTW, just fantastic.
pokeydots ( ) posted Fri, 10 August 2012 at 10:57 PM
Thanks Snarly and bagginsbill :)  I have a question for you.... does the reset work just for the material settings, or does it set everything back to the default settings? Curious as I have messed with every setting, seeing what everything does, but my brain is old, and I can't remember what all the settings were when I first loaded EZSkin.  It would be nice if it set everything back to the defaults that you set up, so I have a starting point when something doesn't look the way I want it to. Thanks :)
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
System Ram:  8GB
Snarlygribbly ( ) posted Sat, 11 August 2012 at 12:42 AM
Quote - I haven't installed PPro SR2.1 yet. Will EZSkin v2 still work. What parts will work and what won't? Is there any benefit going to v2 without SR2.1?
SR2.1 is essential. Without it EZSKin would throw a wobbly, so I've placed a check in there for it before the script will even run ...
Snarlygribbly ( ) posted Sat, 11 August 2012 at 12:46 AM
Quote - Thanks Snarly and bagginsbill :)  I have a question for you.... does the reset work just for the material settings, or does it set everything back to the default settings? Curious as I have messed with every setting, seeing what everything does, but my brain is old, and I can't remember what all the settings were when I first loaded EZSkin.  It would be nice if it set everything back to the defaults that you set up, so I have a starting point when something doesn't look the way I want it to. Thanks :)
No, 'Reset' does not do that.
There is a file called 'ezskin-presets.cfg' which contains a single preset ('Default settings') which you can import into EZSkin using the 'Presets/Import preset' menu option. That preset will then appear in your presets menu and you can use it to reset all values to their defaults.
In practise, you might want to save your own default preset, so that it includes the 'Special Effects' folder that you are using - otherwise the included preset will set that back to blank each time!
pokeydots ( ) posted Sat, 11 August 2012 at 12:53 AM
Thank you!
System Ram:  8GB
ashley9803 ( ) posted Sat, 11 August 2012 at 2:50 AM
Thanks for the reply Snarlygribbly.
Netherworks ( ) posted Sat, 11 August 2012 at 3:15 AM
Thank you Snarly!
Ometeotl ( ) posted Sat, 11 August 2012 at 3:57 AM
And just another: Thank you very much
adroge ( ) posted Sat, 11 August 2012 at 4:42 AM
Quote - Yup. It's available for download with user guide and everything :-)
Just wanted to say thanks to both of you.
parkdalegardener ( ) posted Sat, 11 August 2012 at 7:25 AM
Thanks so much
Fremmen ( ) posted Sat, 11 August 2012 at 10:15 AM
Thanks!!
grichter ( ) posted Sat, 11 August 2012 at 6:48 PM
Snarly is totally one Gnarly dude!
You da man! Thanks for all the effort and especially the fact they are free!!!!!!
Gary
monkeycloud ( ) posted Sat, 11 August 2012 at 7:32 PM
EZSkin2 is simply awesome - many thanks Snarlygribbly 😄
LilWolff ( ) posted Sat, 11 August 2012 at 9:46 PM
Thank you so much!
arrow1 ( ) posted Sat, 11 August 2012 at 11:29 PM
EzySkin 2 is great and works wonderful.Just a thought will there be any support for any other figures? I see Posette and Stephanie Petite amongst a few that are missing.Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
basicwiz ( ) posted Sat, 11 August 2012 at 11:44 PM
Stephanie is, I believe, covered under Daz Gen 3 characters.
Not where I can check it right now, but believe Posette is covered as a SM figure or some other very broad catagory.
I'll stand corrected if this isn't the case, or until Snarley gets in to give a more difinitive answer.
At any rate, give these a try and see if they work.
arrow1 ( ) posted Sun, 12 August 2012 at 12:00 AM
I tried an SP3 Petite and it said Unsupported Figure! Cheers
jartz ( ) posted Sun, 12 August 2012 at 12:04 AM
Thank you so much.
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
basicwiz ( ) posted Sun, 12 August 2012 at 12:07 AM
Quote - I tried an SP3 Petite and it said Unsupported Figure! Cheers
On my system it is (correctly) identified as "Daz Gen 3."
Let me suggest that you re-import the supported characters file and select "All". If it works after that, you know you did not get Daz Gen 3 installed.
arrow1 ( ) posted Sun, 12 August 2012 at 12:43 AM
Thanks for your reply. I will give it another go! Could I ask one more question? How can I warm up or make a tanned skinned tone in EzySkin2? Other than the special effects I cannot see any other settings that might help! Cheers
Snarlygribbly ( ) posted Sun, 12 August 2012 at 3:03 AM
Simple shifts in skin colour can be achieved using the 'Col' chip in the HSV settings found on the Skin tab.
You should choose a colour which is almost, but not quite white, as even a small change in the Col chip makes a very noticeable change in the skin colour. You may also need to very slightly increase the 'Value' parameter too to compensate for the darkening of the colour that occurs when you use anything other than white in the Col chip.
Note that once you have found some satisfactory vales for tanning the skin then you can save them as a preset for later use.
monkeycloud ( ) posted Sun, 12 August 2012 at 10:48 AM
The usability with non-preconfigured figures and, moreover, props... and the ease with which the material definition can be adjusted... is simply excellent I reckon...
It's great that it can work for things like Gray aliens or beetles, as well as it can human skin... the image below, my main concern was making the alien gray enough in an otherwise fairly pink toned environment. Just a slight tweak of the Col chip in the HSV section was all it took.
All I'd ask for in a future update, Snarly, is an option to set the scatter node preset to something other than skin (e.g. the other presets of "marble",  "potato", "apple", etc) from the EZSkin UI....
Is that a possibility?
Many thanks 😄
Snarlygribbly ( ) posted Sun, 12 August 2012 at 12:45 PM
Quote - All I'd ask for in a future update, Snarly, is an option to set the scatter node preset to something other than skin (e.g. the other presets of "marble",  "potato", "apple", etc) from the EZSkin UI....
Well, that is straying into EZSkin+ territory, but seeing as I was uploading a bugfix anyway, and because it was easy, I added it in :-)
v2.0.4 Has a drop down box to let you select the SSS preset for the skin shader.
It also fixes a bug whereby the Special Effects folder path would sometimes be inadvertantly overwritten with a blank path!
I also included a new ezskin-presets.cfg file with a set of defaults that includes the new drop down control.
monkeycloud ( ) posted Sun, 12 August 2012 at 1:06 PM
He he... EZSkin+ indeed! That's awesome... many thanks! 😄
JohnDoe641 ( ) posted Sun, 12 August 2012 at 3:35 PM
I've got a silly question for ya. In EZSkin v1 there were the Draft/Preview/Final settings, I don't see those in V2. When I first apply the shader to the figure, what would be the equivilent settings to the three options from v1?
Snarlygribbly ( ) posted Sun, 12 August 2012 at 3:57 PM
Quote - I've got a silly question for ya. In EZSkin v1 there were the Draft/Preview/Final settings, I don't see those in V2. When I first apply the shader to the figure, what would be the equivilent settings to the three options from v1?
Draft:
Add Fresnel reflection = OFF; SSS Quality = 40%; Reflect quality = 20%
Eye reflections = Reflection map or nothing
Preview:
Add Fresnel reflection = OFF; SSS Quality = 60%; Reflect quality = 20%
Eye reflections: Prefer reflection map
Final:
Add Fresnel reflection = ON; SSS Quality = 80%; Reflect quality = 60%
Eye reflections: Real reflections
EZSkin v2 lets you create your own presets, and as many as you want. They get added to the Presets menu for your convenience.
JohnDoe641 ( ) posted Sun, 12 August 2012 at 4:56 PM
Ah, awesome! Thanks Snarly. :)
WandW ( ) posted Thu, 15 November 2012 at 10:48 AM
Online Now!
I just gave it a go on the Millenium Horse; a rousing success!  I used the hair material on the coat, mane, tail and fetlocks, the nail material on the hooves, and the skin material on the inner ears, along with the appropriate eye and mouth materials.
Yee-Haw!!
monkeycloud ( ) posted Thu, 15 November 2012 at 11:10 AM
The hair shader looks great on animals doesn't it :-)
Haven't gotten round to the MilHorse myself yet... but that looks superb WandW!
So far I've done the MilDog and MilBigCat... Songbird Remix... and quite a few insects... oh and just been using it on an Alien Facehugger from Freestuff, for the render I'm doing at the moment.
danidh ( ) posted Fri, 16 November 2012 at 2:04 AM
Thanks for the suggestion for the animals...it really does look much nicer.  I wasn't sure so I just used "hair" on whiskers.  I'm also curious as to when/what you would use sclerasimple and skintrans.
monkeycloud ( ) posted Fri, 16 November 2012 at 2:12 AM
I've been using BB's Thin Glass shader on some whiskers... when they are modelled as tubes this seems to work quite well ;-)
Snarlygribbly ( ) posted Fri, 16 November 2012 at 2:39 AM · edited Fri, 16 November 2012 at 2:40 AM
Quote - Thanks for the suggestion for the animals...it really does look much nicer.  I wasn't sure so I just used "hair" on whiskers.  I'm also curious as to when/what you would use sclerasimple and skintrans.
Sclerasimple is a shader for the sclera that does NOT have reflections. The ordinary sclera shader does have reflections. This shader is for cases when other parts of the eye have reflections on them (typically the cornea) and additional reflectivity of the sclera would be overkill. Using the sclerasimple shader can make the eye look better and save a lot of rendering time too.
The skintrans shader is exactly the same as the 'maybe' shader, just with a different name. In early versions of EZSkin the names didn't matter as they were not exposed to the user. Now that they are, I wanted to give this shader a better name while keeping the original name for backwards compatibility. The shader takes into account transparency and transparency maps and is primarily intended for those strange 'eyebrow' zones on some DAZ figures and the genital addons for many male figures, but may be useful in other cases too.
danidh ( ) posted Fri, 16 November 2012 at 1:37 PM
Thank you, MonkeyCloud for the info and thank you, Snarly for answering my questions so nicely.  Much appreciated.  Dani
