Mon, Jan 13, 4:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: installing perfect v4 complete
michelvanspeybroeck ( ) posted Sat, 18 August 2012 at 9:12 PM · edited Sat, 11 January 2025 at 9:57 AM
Hey,
I watched the tutorial, i changed the general preferences loaded a fresh v4.2 buth when i hit the buton for inject all normally i would expect that a window would be displayed where i am asked to select the original cr2.
Well the only thing that happens is the circular moving ring from windows turning for a while and that is all.
Can somebody help me out? Using poser pro 2012.
Thanks.
Michel
Mark@poser ( ) posted Sat, 18 August 2012 at 10:26 PM
I'm not the vendor, but I did this last night and it went well.
I think you may have skipped a step. For a new figure, you need to hit the "Create perfect V4" button first in the outer folder directory, then under the "fixes" sub-folder hit the "Inject All Fixes Poser". It's the first button that asked for the cr location if I recall correctly. Did you watch the video?
http://www.youtube.com/watch?v=aeCsI39ntr4
If that's not, it, I'd write the vendor.
realistic ( ) posted Thu, 23 August 2012 at 9:40 PM
I have sort of the same problem, but i get an error of "NULL (or empty) script name passed to PEPythonEngine::DoScript()". I think the vendor forgot to include the python scripts.
realistic ( ) posted Thu, 23 August 2012 at 10:13 PM
OOPS, just discovered i downloaded the wrong version (daz), will try poser version.
Xameva ( ) posted Thu, 23 August 2012 at 10:16 PM · edited Thu, 23 August 2012 at 10:21 PM
Quote - I watched the tutorial, i changed the general preferences loaded a fresh v4.2 buth when i hit the buton for inject all normally i would expect that a window would be displayed where i am asked to select the original cr2.
 Hi there - I'm one of the creators of Perfect V4: sorry for the late response, I don't always check this forum. The next time you have a question you can contact me directly and I'll get back to you within a day. :) As for your question:  following the video, after loading a V4 - your next step is to double-click "Create Perfect V4", not the "Inject All". Be sure to follow the steps of the video tutorial in order. You delete the original V4 in the scene before loading your new "Perfect V4".
Quote - I have sort of the same problem, but i get an error of "NULL (or empty) script name passed to PEPythonEngine::DoScript()". I think the vendor forgot to include the python scripts.
 No we didn't forget it. :) You extracted the DAZ .zip instead of the Poser one - the DAZ .zip does not contain python scripts. To confirm this is the case, you can look at the "Inject All Fixes" icon and it'll have a "DAZ" in the bottom corner.
You'll want to delete the "XandM Perfect Complete" folder under Poses to get rid of the DAZ files (unless you use DAZ Studio too), and then extract the Poser .zip.
 I'm here if you have any other questions!
Xameva ( ) posted Thu, 23 August 2012 at 10:17 PM
Quote - OOPS, just discovered i downloaded the wrong version (daz), will try poser version.
 Lol I was a little late in my reply, I see you got it. Good luck!
