Sun, Feb 16, 6:05 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Toon ID#
witchdidi ( ) posted Sat, 18 August 2012 at 5:11 AM · edited Sun, 16 February 2025 at 5:33 PM
Hello,
I was hoping someone could help me with a script. I need a way to change toon ids easily with a colour picker as opposed to manually calculating a colour?
Stewer confirmed that to calulate it from RGB or more like hex numbers u needed to do the following:-
(RED * 65536) + (GREEN * 256) + BLUE
so pure green 00FF00 = 65280.
So is it possible for the script to let you use a colour picker and then internally do the calculation for the ID? I want to use the Toon Ids as an object Id for postwork and need a way to quickly change colours in the mat room to match what I need.
Regards,
Didi
Be mad...until proven genius.
Sitting quietly in the corner does not make one the class fool.
- Didi
RDNA Store
markschum ( ) posted Sat, 18 August 2012 at 2:23 PM · edited Sat, 18 August 2012 at 2:26 PM
Is this the toonid that determines if there is a line between the two materials ?
I dont quite follow what you are trying to do because the id for lines between materials does not affect the actual colors.
what I do if I need to use a specific set of colors is  save them in the pallette so I can just click on them as needed.
witchdidi ( ) posted Sat, 18 August 2012 at 2:37 PM
With PoserPro, when you save psds out you can select toonids in auxilliary options under render settings.
When it renders out, they come in various shades of blue usually. I want to be able to set the colours up in the material room so that when I choose to render with toonids, I can select colours better in photoshop through the psd file.
- Didi
RDNA Store
witchdidi ( ) posted Sat, 18 August 2012 at 2:42 PM · edited Sat, 18 August 2012 at 2:44 PM
This is an example of what I mean. This is the layer which poser renders out for ToonId. I use it to select bits and pieces to adjust better when doing postwork.
So I'm looking for a way to pick the colours quicker by being able to select whatever colour I need for whichever object or part.
- Didi
RDNA Store
semidieu ( ) posted Sun, 19 August 2012 at 3:14 AM
Attached Link: Simple ToonID Color
Here is a simple version :)
(Hope it's ok to post to a freebie somewhere else)
witchdidi ( ) posted Sun, 19 August 2012 at 3:39 AM · edited Sun, 19 August 2012 at 3:40 AM
Thank you very much Basil!!!!! I'll try it out.
I was wondering though if your Advanced Shaders would work also? Like the partial shaders so you can save different colours out...
- Didi
RDNA Store
witchdidi ( ) posted Sun, 19 August 2012 at 6:14 AM
Just tried it with props and also a scene with V4, hair and clothes. It works beautifully for what I need.
Thank you again! :D
- Didi
RDNA Store
semidieu ( ) posted Tue, 21 August 2012 at 4:06 AM
You're welcome :) And Advanced Shaders could do this... But I think the attached script above is more easy to use... :)
witchdidi ( ) posted Tue, 21 August 2012 at 7:21 AM
Yeah you're right the script is way easier. Now if only we could get down to materials level...
laughs manically
But seriously...thank you! :O)
- Didi
RDNA Store
semidieu ( ) posted Tue, 21 August 2012 at 9:49 AM
Fine tunning materials? Ok! As soon I'm back home, I'll do the script for materials level :)
witchdidi ( ) posted Tue, 21 August 2012 at 9:53 AM
sigh You just made my day!
Lifetime supply of chocolates? Third born son? What would adequately say it??
:D
- Didi
RDNA Store
