Wed, Mar 4, 4:05 PM CST
Renderosity Forums / Poser Python Scripting
Welcome to the Poser Python Scripting Forum
Forum Moderators: Lobo3433, Staff Forum Coordinators: Anim8dtoon
Poser Python Scripting F.A.Q (Last Updated: 2026 Jan 04 1:47 pm)
We now have a ProPack Section in the Poser FreeStuff.
Check out the new Poser Python Wish List thread. If you have an idea for a script, jot it down and maybe someone can write it. If you're looking to write a script, check out this thread for useful suggestions.
Also, check out the official Python site for interpreters, sample code, applications, cool links and debuggers. This is THE central site for Python.
You can now attach text files to your posts to pass around scripts. Just attach the script as a txt file like you would a jpg or gif. Since the forum will use a random name for the file in the link, you should give instructions on what the file name should be and where to install it. Its a good idea to usually put that info right in the script file as well.
Subject: Toon ID#
witchdidi ( ) posted Sat, 18 August 2012 at 5:11 AM · edited Tue, 03 March 2026 at 3:59 PM
Hello,
I was hoping someone could help me with a script. I need a way to change toon ids easily with a colour picker as opposed to manually calculating a colour?
Stewer confirmed that to calulate it from RGB or more like hex numbers u needed to do the following:-
(RED * 65536) + (GREEN * 256) + BLUE
so pure green 00FF00 = 65280.
So is it possible for the script to let you use a colour picker and then internally do the calculation for the ID? I want to use the Toon Ids as an object Id for postwork and need a way to quickly change colours in the mat room to match what I need.
Regards,
Didi
Be mad...until proven genius.
Sitting quietly in the corner does not make one the class fool.
- Didi
RDNA Store
markschum ( ) posted Sat, 18 August 2012 at 2:23 PM · edited Sat, 18 August 2012 at 2:26 PM
Is this the toonid that determines if there is a line between the two materials ?
I dont quite follow what you are trying to do because the id for lines between materials does not affect the actual colors.
what I do if I need to use a specific set of colors is  save them in the pallette so I can just click on them as needed.
witchdidi ( ) posted Sat, 18 August 2012 at 2:37 PM
With PoserPro, when you save psds out you can select toonids in auxilliary options under render settings.
When it renders out, they come in various shades of blue usually. I want to be able to set the colours up in the material room so that when I choose to render with toonids, I can select colours better in photoshop through the psd file.
- Didi
RDNA Store
witchdidi ( ) posted Sat, 18 August 2012 at 2:42 PM · edited Sat, 18 August 2012 at 2:44 PM
This is an example of what I mean. This is the layer which poser renders out for ToonId. I use it to select bits and pieces to adjust better when doing postwork.
So I'm looking for a way to pick the colours quicker by being able to select whatever colour I need for whichever object or part.
- Didi
RDNA Store
semidieu ( ) posted Sun, 19 August 2012 at 3:14 AM
Attached Link: Simple ToonID Color
Here is a simple version :)
(Hope it's ok to post to a freebie somewhere else)
witchdidi ( ) posted Sun, 19 August 2012 at 3:39 AM · edited Sun, 19 August 2012 at 3:40 AM
Thank you very much Basil!!!!! I'll try it out.
I was wondering though if your Advanced Shaders would work also? Like the partial shaders so you can save different colours out...
- Didi
RDNA Store
witchdidi ( ) posted Sun, 19 August 2012 at 6:14 AM
Just tried it with props and also a scene with V4, hair and clothes. It works beautifully for what I need.
Thank you again! :D
- Didi
RDNA Store
semidieu ( ) posted Tue, 21 August 2012 at 4:06 AM
You're welcome :) And Advanced Shaders could do this... But I think the attached script above is more easy to use... :)
witchdidi ( ) posted Tue, 21 August 2012 at 7:21 AM
Yeah you're right the script is way easier. Now if only we could get down to materials level...
laughs manically
But seriously...thank you! :O)
- Didi
RDNA Store
semidieu ( ) posted Tue, 21 August 2012 at 9:49 AM
Fine tunning materials? Ok! As soon I'm back home, I'll do the script for materials level :)
witchdidi ( ) posted Tue, 21 August 2012 at 9:53 AM
sigh You just made my day!
Lifetime supply of chocolates? Third born son? What would adequately say it??
:D
- Didi
RDNA Store
