Sat, Jan 25, 2:13 PM CST
Subject: uv mapper
MoonRose ( ) posted Sat, 08 September 2001 at 3:06 AM · edited Sat, 25 January 2025 at 2:11 PM
hello everyone i was just wondering when you map a model in uv mapper and save the model and texture map... whats the ideal settings for the options? i've just been leaving it on the default choises. thanks :)
SAMS3D ( ) posted Sat, 08 September 2001 at 3:19 AM
Steve Cox the creater of UV, says make the bit map 1024 x 1024 for the obj file you can leave the settings at the default unless when you import things to Poser and your stuff looks inside out you will have to check a setting that says, "reverse winding order". Those options have a lot to do with your normals and how they react to other software on import. Sharen
bloodsong ( ) posted Sat, 08 September 2001 at 7:09 AM
heyas; you should actually turn off 'export normals' when saving stuff for poser. makes your obj a bit smaller, and poser doesnt bother with them, anyway.
Spike ( ) posted Sat, 08 September 2001 at 1:08 PM
Blood is right, It says that in the PPP manual.
You can't call it work if you love it... Zen Tambour
Nance ( ) posted Sat, 08 September 2001 at 2:11 PM
Thats a handy bit of info!
Spike ( ) posted Sat, 08 September 2001 at 3:34 PM
I cut a model size down by 38% by that trick the other day.
MoonRose ( ) posted Sun, 09 September 2001 at 12:48 AM
thanks everyone :)
smerc ( ) posted Sun, 09 September 2001 at 4:05 PM
If you turn off normals, What happens when this model is brought into another program. like Bryce, Vue, Lightwave or Max?? smerc
Spike ( ) posted Mon, 10 September 2001 at 9:33 AM
I don't know. Good ? tho. Try it out and let us know. :)
wyrwulf ( ) posted Mon, 10 September 2001 at 11:04 AM
If you load any of the standard P4 OBJs in UVMapper, the don't have normals. Neither does Vicki and probably not Mike either.
Spike ( ) posted Mon, 10 September 2001 at 1:46 PM
This is good to know for anyone making models. This small step realy saves a lot in the way of file size. Thanks for checking that out there wyrwulf.
