Sat, Feb 1, 4:40 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Subject: Variable Transparency
Paul Francis ( ) posted Tue, 18 September 2012 at 3:31 PM · edited Tue, 21 January 2025 at 9:19 PM
Hi folks - does anyone know how to obtain variable transparency using a transparency map? I want to make an object have an almost transparent area, say the top half of an egg, which gradually gives way way to a solid material further down.  I tried using a grey-scale tranparency map, but the results make me think Poser can only handle black/white i.e. transparent/solid with no in-between stages.  Any ideas?
My self-build system - Vista 64 on a Kingston 240GB SSD, Asus P5Q Pro MB, Quad 6600 CPU, 8 Gb Geil Black Dragon Ram, CoolerMaster HAF932 full tower chassis, EVGA Geforce GTX 750Ti Superclocked 2 Gb, Coolermaster V8 CPU aircooler, Enermax 600W Modular PSU, 240Gb SSD, 2Tb HDD storage, 28" LCD monitor, and more red LEDs than a grown man really needs.....I built it in 2008 and can't afford a new one, yet.....!
My Software - Poser Pro 2012, Photoshop, Bryce 6 and Borderlands......"Catch a  r--i---d-----e-----!"
Paul Francis ( ) posted Tue, 18 September 2012 at 4:03 PM
Sorted it now folks, thanks.
moriador ( ) posted Tue, 18 September 2012 at 4:08 PM
Care to share your discovery? It might end up being very useful to know. :)
wimvdb ( ) posted Tue, 18 September 2012 at 4:10 PM
Poser can handle a gradient. Just make sure you set the gamma correction of the transmap to 1.0 if you use Gamma in your render settings
Paul Francis ( ) posted Tue, 18 September 2012 at 4:11 PM
Quote - Care to share your discovery? It might end up being very useful to know. :)
Patience!  Still working on it!
lesbentley ( ) posted Tue, 18 September 2012 at 4:16 PM
Pug the Image_Map for the transparency into the the 'Transparency' input of the Poser Surface.
lesbentley ( ) posted Tue, 18 September 2012 at 4:23 PM · edited Tue, 18 September 2012 at 4:25 PM
Here a Poser one sided square has a transparency map applied to it. This is PP2012, but I think it should work the same in your P7 or P2010.
Paul Francis ( ) posted Tue, 18 September 2012 at 4:25 PM
Cheers Les, busy perfecting it as I type!
Paul Francis ( ) posted Tue, 18 September 2012 at 4:35 PM
Here's the effect I wanted, I cut a window, which is still specular and not fully transparent with soft edges in V4's skull, added non-transparent veins across it.  The base material is an SSS blue jade.  Inside the skull is a brain-type object, but it could be biomechanical.
Now for some Geiger-esque fun!  This is only a very rough test.
Miss Nancy ( ) posted Tue, 18 September 2012 at 5:55 PM
some trans mask fx may also be achieved with UV variable nodes et al.
