Tue, Jan 7, 12:44 AM CST
Subject: Poser Mapping
pa902 ( ) posted Wed, 17 November 1999 at 9:09 AM ยท edited Tue, 07 January 2025 at 12:24 AM
I haven't been using my poser4 much yet -but i downloaded chris's awesome female texture and went to try it out-heres my question-i figure the texture should be applied over white-is ther a quick way to make all the body parts white? Poser gives all the parts like the lashes and eyes and stuff colors by default and all i know how to do is go through each part and change the color which takes time.Is there a way to make every part of the body white easily-and this map has beautiful lashes on it-but it seems that when i render there are always these real black blocky lashes even though i changed their colors to white-if anyone has used the map im talking about any tips on making it look its best would be appreciated-thanks
Chris ( ) posted Wed, 17 November 1999 at 9:20 AM
You can d/l a trans map for the lashes. Staale has made a map. I cant post the link here (because adult site) but you can email me about it. Christian
"It Is Useless To Resist!" - Darth Vader
Chris ( ) posted Wed, 17 November 1999 at 9:32 AM
oops - forgot to give my email chris@3dgfx.de sorry... Chris
Nance ( ) posted Wed, 17 November 1999 at 10:44 AM
And for changing the whole figure at once, there is a check-box in the Surface Materials window which is labeled "Texture changes apply to entire figure". Be sure to remember to go back and uncheck it after you use it.
pa902 ( ) posted Wed, 17 November 1999 at 12:20 PM
but does that change the color of the models parts? I want the model all white without having to change every part-how do i do that?
Chris ( ) posted Wed, 17 November 1999 at 6:33 PM
Paul: I think you have to change every part to white color manualy. Then add it to your figure library and you can use it every time you want. If you have a multible figure there(Clothes and hair) you can save it as a PZ3 and then rename the file to ...CR2. That works! Hope that help you a little bit Christian
LoboUK ( ) posted Thu, 18 November 1999 at 3:31 AM
The method that Nance gave works fine, I use it all the time. Just click the little box Texture changes apply to whole figure and then change your colour to white. Voila! Paul
