Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 11:57 pm)
Paul: I think you have to change every part to white color manualy. Then add it to your figure library and you can use it every time you want. If you have a multible figure there(Clothes and hair) you can save it as a PZ3 and then rename the file to ...CR2. That works! Hope that help you a little bit Christian
"It Is Useless To Resist!" - Darth Vader
I haven't been using my poser4 much yet -but i downloaded chris's awesome female texture and went to try it out-heres my question-i figure the texture should be applied over white-is ther a quick way to make all the body parts white? Poser gives all the parts like the lashes and eyes and stuff colors by default and all i know how to do is go through each part and change the color which takes time.Is there a way to make every part of the body white easily-and this map has beautiful lashes on it-but it seems that when i render there are always these real black blocky lashes even though i changed their colors to white-if anyone has used the map im talking about any tips on making it look its best would be appreciated-thanks
