Sat, Jan 25, 4:28 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: Anyone know what causes this - Vertices sticking
ToxicWolf ( ) posted Thu, 20 September 2012 at 3:07 PM · edited Thu, 23 January 2025 at 12:20 PM
Anyone know what causes this and how to fix it? I see this happen most often when V4s chest is twisted and moved hard to one side. I've seen it in several different conforming clothes figures.
Thanks up front for any input.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
primorge ( ) posted Thu, 20 September 2012 at 3:23 PM
Weird... post a wireframe, is the vertice aligned with a vertice on V4?
ToxicWolf ( ) posted Thu, 20 September 2012 at 3:32 PM
Slightly different pose but you can still see it.
Poser Pro 2012 SR3
24G RAM
ToxicWolf ( ) posted Thu, 20 September 2012 at 3:34 PM · edited Thu, 20 September 2012 at 3:45 PM
Here's the wireframe.
Actually, it looks more like an edge problem than problems with the vertices.
Poser Pro 2012 SR3
24G RAM
ToxicWolf ( ) posted Thu, 20 September 2012 at 5:31 PM
It just gets stranger. This only happens if you both twist the chest and move it side to side. And then it only happens if both are the same sign (both positive or both negative). If one is positive the the other is negative, it does not happen.
Poser Pro 2012 SR3
24G RAM
Teyon ( ) posted Thu, 20 September 2012 at 5:43 PM · edited Thu, 20 September 2012 at 5:44 PM
One of the weight maps (if it is weight mapped) is pulling on that point with less strength than it should. Check the rotations independently and increase the weight. OR it's not in one of the fall off zones (spherical or capsule) for a rotation (or multiple rotation) dials. Move the fall off so it includes the stray vert.
ToxicWolf ( ) posted Thu, 20 September 2012 at 5:48 PM
Thanks Teyon. It's not weight maped and adjusting the innerMatSphere and outerMateSphere has no effect. I've tried that individually on side to side and twist. There is something about them working together that I'm missing.
Poser Pro 2012 SR3
24G RAM
Teyon ( ) posted Thu, 20 September 2012 at 5:53 PM
Hmm. That's usually how I fix this when it happens to me. Pretty odd. Did you take a look at the bend, maybe that's the culprit? I don't know now....
ToxicWolf ( ) posted Thu, 20 September 2012 at 6:06 PM
You're right Teyon, I need to widen my search. I'll check on the abdomen too.
Poser Pro 2012 SR3
24G RAM
rokket ( ) posted Thu, 20 September 2012 at 6:42 PM · edited Thu, 20 September 2012 at 6:42 PM
Quote - Hmm. That's usually how I fix this when it happens to me. Pretty odd. Did you take a look at the bend, maybe that's the culprit? I don't know now....
Bend is usually the culprit. Had it happen to me when I was rigging a body suit for Sydney. Usually expanding the inner sphere on the bend in the joint editor fixed it.
ToxicWolf ( ) posted Thu, 20 September 2012 at 7:15 PM
Thank you everyone. This has been very frustrating. But, I found the solution. There are several things I know about doing, but never try because I've never needed them before. One of the things I've never needed to do before was to move the joint itself.
The fix was really easy once I gave it a try. I opened the joint editor and selected side-side. The joint with a center point and three legs appeared. I grabbed the center point with my mouse and pulled down on it very, very little. The point is gone. The amount of movement was so small I had to try it a second time just to see if that had fixed the problem. That was it. So, if you ever see something like this and the sphere props aren't doing it for you, give moving the actual joint a try.
Poser Pro 2012 SR3
24G RAM
