DAZ|Studio F.A.Q (Last Updated: 2024 Sep 19 12:07 pm)
If I load everything but the river cottage and use a different sean set up, I get the shadows as needed. There are other props that will not cast shadown as well. If I can work this out I should be able to do it to other projects as well. There is somthing in the prop preventing it, I just do not know what it is. As to lighs, it matters not what ever lght setuo I use the same happens. The Ricer Cottage has a "pze3" set up and it too will not cast the needed shadows.
Poser lights don't load with shadow casting on - it's rarely worth trying them, or it hasn't been in the past. If I load the RiverCottage scene file, delete the supplied lights and add a new one set to cast shadows I get shadows - simply adding a new light without deleting some or all of the supplied lights probably wouldn't give much shadowing as the scene is way over-lit as imported.
Without knowing why the prop won't give shadows that's hard to answer - issues might be too many other lights, washing the shadows out, or nothing to catch the shadows, if the item loads with a 2D backdrop rather than a real environment, or simply having Cast Shadows turned off for the item. If you have some more examples I can see if I have them, or download them if they are freebies, to check for possible issues.
Hi Peeps,we have just a little shadow problem
I have all shadows set to on and lights to cast shadows yet when rendering none are seen on or from the props, no shadow casting from any thing. Any and all help is greatly welcomed. This does not happen in all my render just when I use seans like "The River Cottage, Eva, and Edipo."
