Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 5:58 pm)
Does this happen with all the props (including the primitives)?
I just tried it, and it seems to work ok for me. Load a box primitive, changed the orgins, checked it with rotate, saved the prop. Restarted Poser, loaded the prop and the origin were where I had set them
But I am using PP2012, so P9 may be different
Hi Wim, yes it does happen with all props.
I just tried it with the box primitive, too. I changed the OriginY (from 0 to 1), saved the prop as well as the scene, and closed Poser.
Reopened Poser, loaded the box - OriginY = 0.
Closed Poser, loaded the saved scene - OriginY of the box = 0.
@ Laurie: Do you mean Edit -> Memorize -> Element? I tried that, too. Didn't seem to have any effect.
Attached Link: Memorize
This might help.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
No need to reinstall. I see the bug now.
If you change the origins with the dial, the changes are not saved.
If you change it with the mouse (which I did), then the changes are saved with the prop.
Try it out for yourself. Take the topview and move the origin. And save the prop.
I was suprised that it did not work because I use it a lot. But I always use the topview to move the origin to align with something else. That's why I did not see it
I filed a report at Smith Micro, maybe a fix will make it if there is a new update
Hi, I use P9 with SR3 and have encountered a little problem:
If I change the 'Origins' of a prop, save the item or the whole scene, close Poser and open the scene / prop again, the origins are re-setted.
If I do the same changes in P8 they will stick - even in P9.
Has anyone else encountered this problem?
