Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2025 Jan 19 8:16 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered. Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Base Texture: Add an image (Clouds.png*) to the Base Texture’s diffuse color, specular color and displacement
Overlay Texture: Add tiling (3 tiles each way), ray-traced reflection, and a bump image (Noise.png*).
*Images in the same folder as the DBM, DUF, and DSA files - see readme.
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
After a bit of fiddling I got refraction to work with the existing network. You need to change two parameters in the 'Reflect And Refract' brick for the Base Texture or Overlay Texture, whichever you're using (you can only do this in Shader Mixer - I hid the parameters from the Surfaces tab on this beta, sorry!):
-Sample cone: Set this to 0, not 1
-Max distance: Start with it set at 1. If the refraction doesn’t work try 10, then 100, then 1000, etc.
I'm still working on the normals...
Also, while playing with the shader on the Surfaces tab, I realised that some way to invert and/or change brightness/contrast of the Overlay Mask image would be useful, and quite easy to implement. Working on this too.
Any other ideas?
Thanks to millighost I now know why my normals aren't working: the outputs of a Normal Map brick are the normals in camera-space after being applied to the object. I was incorrectly assuming that they were still in tangent-space. This makes the maths a bit more awkward, but at least I'm now on the right track with the normals!
A few further thoughts
Overlay Mask: Two sliders seem a good idea to make any mask image more flexible. Contrast + Brightness perhaps? Or Black Level and White Level?
Reflection: Perhaps only one Environment Colour Map/Trace/Mix brick network should be used? The base and overlay will be reflecting exactly the same thing, and it's only the reflection strength that is likely to differ.
Opacity: The overlay mask itself is the opacity of the overlay!
Refraction: Since the overlay is assumed to be a thin layer applied on top the base, the effect of overlay refraction depends on overlay thickness, which does not exist (except perhaps if we use bump/displacement). Could add a 0-100% slider to let the user set the value?
You know those kid's balloon with coloured designs on them? And when you look through the balloon at the back of the design it's just a flat opaque colour? Can't see a way to do that.
Other reminders to self:
I noticed when I was doing my tileable mail textures that normal maps didn't tile in DS3. They can easily be made to tile correctly using Shader Mixer.
If you combine two tileable Image Map bricks with a Mix brick, but set different tiling values (prime numbers) then the pattern repeat is increased to the product of the two numbers. Might be useful for large plain surfaces?
Most things work, except refraction and normal maps (see readme).
This is basically for situations where you have a single surface but want to use two separate materials (e.g. a shiny reflective gold paint design on a stone surface). Yes, you can already do this by creating separate images to plug into the diffuse, bump, and specular channels (and that’s not uncommon). But when you have two REALLY different materials that require separate values for glossiness, specular strength, reflection strength, etc, as well…
Seemed to me that specifying the two materials separately, and using a simple greyscale image to define which material is used where, was a simple solution. You can already do this in Poser’s Material Room (since Poser 6 at least), and now DAZ Studio has Shader Mixer, which can do this too. But many people don’t use Shader Mixer. So I’ve created a simple (but quite big!) shader network, and made all the important stuff accessible from the normal Surfaces tab.
Attached image shows the shader out-of-the-box applied to a sphere primitive. Not too impressive, eh? Just a very simplistic goldleaf on smooth stone effect - the only differences between the Base Texture and Overlay Texture are diffuse/specular colours, glossiness, and specular strength.
