Wed, Jan 1, 1:19 PM CST
Forum Moderators: Staff
Subject: Can more props be merged down to one?
Zrincx ( ) posted Mon, 10 September 2001 at 5:09 PM · edited Sun, 29 December 2024 at 2:38 PM
Allright, the Subject line says it all, but an illustration attached will hopefully support what it is I try to say. Heres a short explanation: I made a 3ds model in ACad2000 of the "frame" of the gun, everything else cylinders and boxes etc, are simple props from Poser. IS it possible to "merge/melt" them all into one single prop ??? I cant find any subject on this in the manual. Thanks in advance. Zrincx.
dollpartz ( ) posted Mon, 10 September 2001 at 6:17 PM
U mean in Poser? I would guess u could build a hierarchy in the hierarchy editor. If I understand the question. :)
Zrincx ( ) posted Mon, 10 September 2001 at 6:27 PM
Thats right in Poser.. But I dont know the hierarchy editor :-(
dollpartz ( ) posted Mon, 10 September 2001 at 7:17 PM
Oh ... again I dunno if this is the best answer or nething, but ah, CLick WINDOW on the menu bar, and then Hierarchy editor, if yer props r loaded, u'll see em there (may have 2 scroll down some). Drag em one by one under the same parent (pick one of the parts 2 b the parent). That's what I would try.
dollpartz ( ) posted Mon, 10 September 2001 at 7:18 PM
Drag the names in the editor I mean ...
Miss Nancy ( ) posted Mon, 10 September 2001 at 7:57 PM
Just export it all as wavefront.obj it will be one merged object
Grey_cat ( ) posted Mon, 10 September 2001 at 8:59 PM
If you're talking about Autocad. Select all, expload, then go to File, export, 3ds. A dialog box will come up, make sure the weld check box is check, and it should come out as one piece
