I'm not clear which version of Poser Pro you have since the term was used since version 4. However before purchasing new content, suggest that you load the SimonG2 figure, select its BODY and set the Mesomorph dial to 1.000 and see if that suits your purpose.
If your version does not have that figure then look through the figure library and try others. Many of the Poser figures include some form of muscular morph.
Okay, for morphs, if you have the morphs++ over at daz, you should be fine for shape. I'm not really sure about max importer. If you want in poser realism, you could download VSS by bagginsbill (free, search forums for it) and then use his James or 240 shaders (search for those by him too).
Thing is, I don't know about the max part so if it doesn't pull over the mats then those last things won't help. It sounds like you can import into max via object format. If that is the case, morph and pose M4 first and then export him as an .obj file.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Okay, then ignore what I said about BB's shaders and VSS: that version wouldn't work with them. You can still export the obj file of a posed m4.
WARK!
I think you may be clicking on the morphing brush tool.
Select the body, then go to the parameter settings. There should be a section labeled FBM (Full Body Morph). That is where you will find the mesomorph dial. This is the body shape you should get (minus the pink speedo).
Sorry - cross-posted!
Poser 11 Pro, Windows 10
Hi Folks,
I have a Poser Pro, i rarely use it as I was concentrating on architectural work, now i need to bang out a character using Poser (and finally MAX). And have forgotten much of what i used to know about poser :-(
I need to create a bodybuilder with good detail on arms and legs- torso, head not important as i only need legs and arms.
I have Poser Pro and M4 along with the max importer.
Can someone point me in right direction to what I need to do, do i need to buy morphs, figures etc, What is a good workflow?
big thanks
