Sun, Feb 9, 12:42 AM CST
Subject: little black points on light shadows
xpdev ( ) posted Thu, 15 November 2012 at 6:22 AM · edited Sun, 09 February 2025 at 12:37 AM
Why this problem on the shadow borders ?
There is 1 only light from a windows.
This is in low resolution
Ideas ?
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
xpdev ( ) posted Thu, 15 November 2012 at 6:23 AM
This is in high resolution
xpdev ( ) posted Thu, 15 November 2012 at 6:24 AM
And this is the rendering setting.
xpdev ( ) posted Thu, 15 November 2012 at 7:17 AM · edited Thu, 15 November 2012 at 7:18 AM
the problem is created when light passes through the window (not the glass) and then create the shadow.
This is the external view.
xpdev ( ) posted Thu, 15 November 2012 at 7:18 AM
And the setting for the only light.
xpdev ( ) posted Thu, 15 November 2012 at 7:19 AM
Any ideas ?
Many thanks.
kalrua ( ) posted Thu, 15 November 2012 at 7:28 AM
1
Irradiance catching 39?
Try 64, 70, 80 or 90 - 97
2
For wall, in materials, check "normals forward".
3
Instal SR3.1, uncheck irradiace catching, set sample to 256
http://poser.smithmicro.com/updates.html
xpdev ( ) posted Thu, 15 November 2012 at 7:33 AM
Thanks, i do some tests then i came back.
xpdev ( ) posted Thu, 15 November 2012 at 8:34 AM
I followed your advice, no difference in the result.
any other ideas?
kalrua ( ) posted Thu, 15 November 2012 at 8:59 AM
Quote - I followed your advice, no difference in the result.
any other ideas?
Aww, no sorry.
xpdev ( ) posted Thu, 15 November 2012 at 9:10 AM
something happens with the only light outside, I have to keep "shadow blur radius" high to soften the shadows, but this causes the points blacks that you see ... I can not find solution ....
many thanks again...
waiting for help....
ghonma ( ) posted Thu, 15 November 2012 at 9:43 AM
Have you tried changing it to a spot light ?
Anyways, blurry shadows are really buggy in firefly for some reason. I also get lots of nasty artifacts if I set the blur radius higher then10-12. Dunno if there is any solution, sorry...
xpdev ( ) posted Thu, 15 November 2012 at 9:46 AM
this is only a test with a windows, but i need a scene with more windows and a spot light is not good for my work.
thanks the same....
ToxicWolf ( ) posted Thu, 15 November 2012 at 2:06 PM
I think this has to do with indirect light. You always get some strange things going on with shadows and indirect light. There are other people that know a lot more about it than I do. Maybe they will jump in.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
millighost ( ) posted Thu, 15 November 2012 at 8:45 PM
Quote - ...And the setting for the only light.
The larger your light's "shadow blur radius" is, the more "shadow samples" you will need to get a smooth shadow (the setting is in the light properties just below the blur radius). With a blur radius of 20, try with "shadow samples" set to e.g. 200 or so (makes render times longer, so you might want to set a high value only for the final render).
primorge ( ) posted Thu, 15 November 2012 at 9:08 PM
millighost, is a blur radius/samples calculation x10 ( i.e. if the blur were set to 6, set samples to 60) be a good starting point formula for RT shadows?
Latexluv ( ) posted Thu, 15 November 2012 at 9:25 PM
Erm, can I ask why you'd want a shadow blur to be 20? I'm looking around my rec room right now lit by a flourescent light and I guesstimate the blur to be no more than a 5. Is the only light for your scene coming from the window? I usually use a shadow blur of 3 or 4 and put my samples at 50 to 70 on each light.
Weapons of choice:
primorge ( ) posted Thu, 15 November 2012 at 9:53 PM
looks like I found my answer in a thereabouts yes from Latexluv, sorry for the hijack...
As an aside, the settings xpdev has in his screencap seemed rather unusual to me.
Miss Nancy ( ) posted Thu, 15 November 2012 at 10:00 PM
xpdev knows what he must do.  earth's sun and poser point-source ray-traced directional lights produce harsh direct shadow edges with some blurring that is a function of the distance from the shadow-casting edge to the shadowed surface, whilst a large diffuse-emitting surface will produce very soft shadows in poser.
luckybears ( ) posted Fri, 16 November 2012 at 5:44 PM
I think the hight the shadow blur  value the higher the pixel sampling should be set in render settings.
hborre ( ) posted Fri, 16 November 2012 at 6:53 PM
It was posted elsewhere that the rule of thumb for light shadow sampling should be 10x higher than the Shadow Blur Radius.
