That may be difficult to convey since flickering is a change of light value over time. Unless it is animated you are constrained to a single moment in time.
That said, could you do something to soften that hard line shadow. A flame is emitting light from its entire visible surface and not a a singular point.
You could try using some sort of gel with the light source. It will be difficult, indeed.
Thanks Much skiwillgee.
I was thinking that a candle might cast a flickering shadow so I did a test with a candle in the kitchen. As long as there's no air to move the flame it looks pretty much like the lighting in the image. Guess I was thinking sort of wrong. LOL . It did make hard shadows, a little sharper then the image ones, so I guess I'll just leave this alone.
Life may not be the party we hoped for but while we're here we should dance.
Attached Link: http://www.baument.com/restore/Tutorials/flameon.html
Try this, my fire material isn't suited for candles, but this should work for ya:-)Clay
Do atleast one thing a day that scares the hell outta ya!!
Thanks Much for the link Clay. I discovered right away that your fire didn't work. I use it a lot so it's the first one I tried. I ended up using one of the materials that came with Bryce but it's not showing up very good. I'll try that tutorial tomorrow. Maybe I'll get lucky & get it right the first time..LOL ..
